Whats wrong with my car
Old Jan 23, 2002 | 02:40 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
This morning i started my car herd a loud sqeeling sound so i drove to work hearing the sound in the center of my dash. on my brake at work i check out my car and concluded the sound is coming from the distributor. Iit sounds like a very quiet horn beeping and goes away as u rev up the engine. I put my hand on the Dist and i could feel the vibrations comming off the distributor. Any ideas what it is? and how to fix it
Old Jan 23, 2002 | 10:55 PM
CHVYPWR's Avatar
Car: 1978 El Camino SS
Transmission: T-5 & 3.73's
Sounds like the bushings are smoked. Take off the dist. cap and grab the rotor, see if it has side to side play in the shaft. If it does, your in need of a new dist.
Old Jan 23, 2002 | 11:09 PM
FAST RS's Avatar
can i rebuild it??? do they come with bushings in the kits? if so do they make any high performance ones and how do i rebuild it. Never done it before
Old Jan 23, 2002 | 11:31 PM
fiream's Avatar
Car: 1983 Pontiac Firebird
Engine: 400HP 350
I'll sell you mine
i just replaced my old one with a vacuum advacne distributor.
Old Jan 24, 2002 | 04:12 AM
FAST RS's Avatar
what years your car??? i dono if it makes any difference from year to year or not but mines a 91 but if it will wokr on my car and it has the electric advance consider it sold. *** i just had the best feelin wakeing up and thinking it was saturday damn 2 more days of work
Old Jan 24, 2002 | 03:28 PM
Camaro_hunter_d's Avatar
Re: Whats wrong with my car
Is there a puddle of oil at the distrib?. The Bushings will lead to a puddle being there, as it allows the distrib to move around alot and fry the seal.
When you "found" the source the car was running right?. if not or even if so get a LONG SOLID peice of metal and place it against different objects on the engine. Its basically a stethoscope. You can really pin point Cam bearing, distrib bushings ect like that.
Now I am not saying its not the bushings, just make sure before you go to pull the distrib to replace them and your cars down for a couple days-week.
Old Jan 24, 2002 | 03:58 PM
FAST RS's Avatar
I noticed it only does it when the car is cold in the mornign this moring i startd it up herd the noise for about 10 seconds went away. Its comming from the distrubtor area and like i said you can feel the vibration from the sound in the dist cap if u put your hand on it. Any other ideas or is it still probly the dist? also im pretty sure its gettin oil weell the pressure guage shows 40-60 psi when i start up my car.
Old Jan 24, 2002 | 05:07 PM
If the noise is only for that short a time its more then likely NOT the bushings. Maybe something internal though. Or it could be lack of oil at startup on the bearings...
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
fonzie85
Exterior Parts for Sale
Oct 10, 2015 10:55 PM
dhonda200
Aug 11, 2015 11:50 PM
