smog test values
Old Feb 7, 2025 | 11:51 AM
mikiman's Avatar
smog test values
Hello.
What are the normal values ​​that the 3.1 has in the smoog tests if the catalyst does not work or if it is empty? And which ones with a correct catalytic converter ?
thanks
Old Feb 9, 2025 | 04:56 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: smog test values
Originally Posted by mikiman
Hello.
thanks
Do you have high nox ? Your local test facility should tell you the acceptable amount for your county.
Old Feb 16, 2025 | 02:35 PM
mikiman's Avatar
Hello. I'm writing from Spain. Here the maximum allowed is C0 0.5 if it is catalyzed. Or the amount declared by the manufacturer. And the garage tells me that this car has a much higher value. I have a 3.1 v6 but the hood is from a 5.0 and it has this sticker. It only says that it complies with the EPA regulations, but it doesn't say the value. Without a catalytic converter it gave me CO 3.5 and I don't know if I have to improve it before putting in the new catalytic converter.
Old Feb 16, 2025 | 02:37 PM
mikiman's Avatar
Maybe It s better that i write It in the exhaust tech board?
Old Feb 17, 2025 | 12:58 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
The 3.1 was not installed in 1986, so the sticker has no meaning. An 86 with 3.1 might still be tested a 2.8 unless an engine changeover is reported to the state. My (U.S. relevant) statements may not mean anything in Spain. I can tell you what my 305 engines' CO test results have been, but I don't know if 3.5 is high for 86 or 92 without a reference.
Old Feb 17, 2025 | 10:52 AM
mikiman's Avatar
Hello. This hood It is not the original. Then I have not the sticker for a 3.1 v6.
It Will be great if someone can do a photo of this sticker
Old Feb 17, 2025 | 11:18 PM
jmd's Avatar
jmd
Is the 0.5 CO a percentage or gm/km or something else for your test?
An 87 third gen would be subject to dyno roller testing in Maricopa County Arizona U.S. and the limits would be
HC grams/mile: 1.60
CO grams/mile: 15.00
NOx grams/mile: 2.50
I don't think it will help, but I hope you get success in testing.
Old Feb 18, 2025 | 12:32 PM
mikiman's Avatar
Hello. Yes, CO 0.5 is the %. The test in Spain is with the car stopped. A probe is placed in the tailpipe and they measure the % of gases with the engine idling and accelerating. and the value of the lambda probe. Thanks
BlueWrath92
Jun 16, 2012 08:24 PM
91formulaSS
Jun 24, 2008 05:14 PM
Shadygrady
South East Region
Apr 25, 2008 03:49 AM
sol_searcher
South West Region
Apr 16, 2008 12:37 AM
TELLEZ
Southern California Area
Jun 5, 2002 12:14 AM
