VATs problem?
Old Mar 2, 2025 | 02:24 PM
KristianHill14's Avatar
VATs problem?
We swapped another 3.1L into our 1992 rs, initially it would try to crank, then all the sudden it stopped and not it won’t even try to crank. Security light goes off after a few seconds however nothing is getting power other than the dash lights. New starter, distributor, spark plugs, checked timing. We have no idea what it could be. It sounds like a vats problem but our only concern is the security light doesn’t stay on. Not sure what to check next.
Old Mar 2, 2025 | 02:28 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: VATs problem?
Bypass the starter enable relay, then if it then crank consistently and doesn’t start. Fix the passkey system or bypass it.
chazman
Jan 9, 2024 11:56 PM
HeavyChevyWes
Mar 22, 2015 01:55 AM
92-Z28
Oct 15, 2012 02:00 PM
4simplertimes
Feb 21, 2006 05:49 PM
BIGJON
Dec 20, 2004 07:48 AM
