F*ck me.....who sells Bondo-type materials?
Old Feb 5, 2002 | 12:20 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Well, I hit a g0ddamn tire on my way home from school and it f*cked up the paint on my front spoiler lip.
The thing has some cracks from previous curb encounters so I've decided I'm gonna pull it off, strip the paint, bondo the cracks and have it repainted at work.
So....who actually sells bondo? I've never seen it in a store before......
Old Feb 5, 2002 | 02:53 AM
BitchinRS's Avatar
I know how you feel! The same thing happened to me one day. Pissed me off to no end!!
Will bondo even work on the rubber/plastic front clip? Just about any auto store should have some sort of body repair goo.
Old Feb 5, 2002 | 06:27 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
use the fiberglass repair kit. will hold up better than bondo, even goriila hair bondo. the best repair is to replace the clip though.
All good auto parts stores should have all of these, even walsmart, kamart, meijer, .....
Old Feb 5, 2002 | 08:52 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
That rubber/plastic front clip is made out of urethane. To repair the urethane bumper cover, you should hunt down the Bondo Urethane Repair Kit. It's a two-part epoxy that acts like regular Bondo does. If you have a tear, you should sand the tear so it's slightly indented, so you won't just be gluing the tear together (like you would use superglue on a ceramic figurine), you'll also be filling the area in. The stuff works great, sands easy, and makes an undetectable repair that's just as strong as the original - until you smack another object!
Don't use a power drill to sand the bumper; use a d/a sander. If you don't have air tools, you can glue sandpaper to a random orbital buffer's pad, or even use one of those little square woodworking sanders. A drill will cut into the bumper and leave you with a rippled bumper.
To prime, you need the proper stuff. I think Plastikote sells it... it's a two part system. First part is "flexible bumper adhesion promoter"; spray it on a naked urethane bumper. When that dries, you put on the "flexible bumper primer".
I used to buy my Bondo from Strauss auto; I know I've seen it in Pep Boys, too. If all else fails, get some similar stuff (different manufacturer but probably better than Bondo) from http://www.eastwoodcompany.com .
Old Feb 5, 2002 | 08:57 AM
snowbird's Avatar
I recomend 3M P.R.O Fill/Bond Rigid Parts Repair Kit. My uncle works at a body shop and that's what they use. I've also used it on snowmobile hoods (same type of material) and has worked very well. Also very easy to work with. 3M part # is 05883. I ordered it from Bumper to Bumper.
Old Feb 5, 2002 | 09:25 AM
Engine: LH0 3.1L
Thanks guys, my clip needing "rebuilding" anyways......so maybe hitting the tire was a good thing.
Old Feb 5, 2002 | 04:31 PM
KED85's Avatar
Dan, my patch kit from Pep boys was about $25-ish
Of Course, since my move, I can't locate it, as it's not important!
It is just as described.
Mine front rear cover has tears/rips.
I am supporting from behind with sheet aluminum, bent to hold, counter sinking pop rivets, making a "V" grove gouge in the rip line, then the two stage epoxy stuff. I do have duplicolor clear primer for the urathane bumper. I found out "Body Shop Beige" Pep Boys spray can paint is ALMOST AN EXACT MATCH.
My fender turned out quite decent for the one large spray paint can I used to paint a white/then primer/then beige fender.
And Fender repaints lower than "I'll paint any fender for $29.95" works fine for me!
My car is almost one color again!
Old Feb 5, 2002 | 04:46 PM
I Cant Drive 55's Avatar
I had a couple tears in my front spoiler , I used 3M weather strip adhesive and ran it down the crack pushed it back together held it with tape . It hasnt come apart yet.
Old Feb 6, 2002 | 02:56 AM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Re: F*ck me.....who sells Bondo-type materials?
F*ck me man, F*uck me....
Walmart carries the stuff...
Stangski09
Nov 14, 2015 01:27 PM
89-91fun
South West Region
Sep 12, 2015 03:06 PM
scottmoyer
Sep 7, 2015 07:06 PM
Street Lethal
Sep 7, 2015 01:09 PM
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
