Questions about 2.8, 3.1, 3.4
Old Feb 6, 2002 | 09:56 AM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
Ok correct me if I'm wrong but is this right.
2.8L............ 140HP........... 8.5 to 1 compression stock
3.1L.............150HP........... 8.5 to 1 compression stock
3.4...............160HP........... 9.3 to 1 compression stock
2.8L............ bore 3.5"
3.1L............ bore 3.5"
3.4L..............bore 3.675"
3.4 and 3.1 share rods and crank
3.4 has better heads
2.8 and 3.1 share heads and intake
Please feel free to add details.....
Old Feb 6, 2002 | 10:07 AM
KED85's Avatar
Ryan,
THE CHEAPEST & MOST SECURE ANSWERS TO YOUR QUESTIONS
reside in the pages of the GM Performance Parts Book for a measly $6. ANY GM dealer.
BUT, I believe you are correct in many statements. Finding a used running low milage 3.4 is the wisest solution, too.
Planning & waiting is the key.
When mine went (I blew the the 2.8) I was under pressure to get it running.
Out in LA we have lots of wrecking yard options. My 3.4 came from out of the LA area (like upper CA state).
Old Feb 6, 2002 | 12:24 PM
loomdog32's Avatar
Car: 82 Camaro Z28
Engine: LU5 - Crossfire 305
Transmission: 200c - 3 Speed Automatic
those numbers seem pretty close. the mpfi (85-89 lb8) and carb (82-84 lc1) 2.8 had diff heads and cam and the cam on the 3.4 (93-95 l36, i think) is more aggressive.
mike (loomdog)
Old Feb 6, 2002 | 12:35 PM
Brian K's Avatar
I read in 4X4 off road Ford Races a 2.8 @ 275HP in the Soda Series... They used a 2.8 because it can REV.. Ever see a 2.8 with 4.10's.. It like them a lot...
Old Feb 7, 2002 | 11:17 PM
fatass's Avatar
Car: 1986 Sport Coupe
Engine: 2.8l V6
Transmission: 3 speed auto
some jeep cherokees had the lb8
Old Feb 8, 2002 | 10:05 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
2.8l vin code "S" (85-89 LB8) has compression of 8.9:1. The 82-84 LC1 (carb'd) motors might have 8.5:1 compression.
I think the 2.8's stroke is 3.3 inches... can anyone confirm this?
Cleotiz
Jan 6, 2018 08:56 PM
redmaroz
Aug 16, 2015 11:40 PM
the_nikfive
Aug 11, 2015 02:46 AM
guy76767
Aug 6, 2015 05:58 PM
92projectcamaro
Aug 6, 2015 01:20 PM
