easy fix for a leak?
Old Feb 14, 2002 | 03:11 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I bought a 85 celica gt for 100 bucks last week all it had was a blown headgasket 100 bucks in parts and 4 days workin on it it ran perfect. I put 20/50 oil in it and the rear main seal started leakin its basicly loosin a qt in about a hour you can wacth it come out of the seal. are there any cheap fiixes for this like any kind of seal expander stuff like stop leak or what ever that will actualy work for this. Otherwise the car runs great
Old Feb 14, 2002 | 04:23 PM
Camaro_hunter_d's Avatar
Well you COULD use some stop leak, but remember that stuff clogs any hole. It does not discriminate. So you COULD [possibly fix the reear main, but you clog several passages in your block. I would replace the bad seal, its your choice.
Old Feb 14, 2002 | 06:13 PM
KED85's Avatar
You do know the right answer.
You are so far ahead, money wise in the car.
Spend the $$ for the right work & parts.
Old Feb 14, 2002 | 06:49 PM
FAST RS's Avatar
see i bought it to fix it and sell t for a quick buck i dont wana be pumping money i dont really have into a car i dont want lol. I tapped into my firebird money for this car lol just wna fix it and sell it
Old Feb 14, 2002 | 11:23 PM
KED85's Avatar
One of my friends just had her Honda Oil Pan fixed in two hours for $160.
I'd find out what it takes to fix the cars leak.
Old Feb 14, 2002 | 11:25 PM
FAST RS's Avatar
i know the gasket is 12 bucks oh yah one more problem well 2 actualy the car is over heating dono why when i took apart the car there was no Tstat in it so i ut one in and my frind was driving the car and said it was boiling over. does the radiator need to be cleaned? also the brake lights are awalys on when the headlights are on any ideas on that. Sorry i know this isnt thirdgen related
Old Feb 14, 2002 | 11:38 PM
KED85's Avatar
Radiator sounds clogged up
Bet lots of rust stains around that area.
Lights?
Good luck with that Gremlin
I'd worry about the raditor.
Put hand over it to feel heat area.
How about hoses?
Ya know, all this is third gen
It's a car w/cooling problems.
Not many parts to go wrong.
Was the head warped?
Toyotas known for that problem.
Old Feb 15, 2002 | 02:51 AM
FAST RS's Avatar
me and my frind thinkit might actualy be the radiator cap it seems to be leaking and i read that water boils when it doenst have enough pressure so im gonna try that first. simplest to harerst. I herd that you can clean the radiator well if you use tilex i think it was i read it in CHP or hotrod i think not sure which magazine
Old Feb 15, 2002 | 01:20 PM
KED85's Avatar
I got ya one better.
TRY THE CAP
BUT
for real cheap, go to the yards and get a Celica radiator for $30!
I went and got 5 selections of radiators for my Firebird.
Chose one.
Been perfect. Best Thirty I ever spent!!
Old Feb 16, 2002 | 01:04 PM
I Cant Drive 55's Avatar
Has the car overheated since you replaced the headgasket?
a blown headgasket will cause a car to overheat and boil over.
Old Feb 16, 2002 | 03:57 PM
FAST RS's Avatar
My friends brother said it over heated since the first day her bought it i took it to my mechanic yesturday he looked at it anf said there is no sign of a blown headgasket again. Im goin back today cuz hes going to do a block test on it. He said it dosent seem liek the radiator is clogged there was some air in the radiator but it still boild over. hopeuly today we wil figure it out
Old Feb 18, 2002 | 03:54 PM
FAST RS's Avatar
KED you were right we took the car to my mechanic he check it out said it was the radiator
Old Feb 18, 2002 | 04:35 PM
KED85's Avatar
Glad to offer a good suggestion.
I've seen it before, so much junk, from trying to stop water leaks, it does in the radiator
In othere word's I'VE DONE IT TO MYSELF!!
Don't forget heater core, too.
Pick Your Part Time!!
Hope you score on an easy fix!
You need to finish the Firebird!
evan555222
Sep 20, 2016 02:51 AM
Dkelz313
Apr 7, 2016 10:38 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
evan555222
Aug 22, 2015 07:14 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
