has anyone seen this on a 2.8??
Old Feb 25, 2002 | 06:57 AM
loomdog32's Avatar
Car: 82 Camaro Z28
Engine: LU5 - Crossfire 305
Transmission: 200c - 3 Speed Automatic
i got bored today and tok apart my knocking 2.8.. it turned out to be a lifter knock.. it was puched up above the vaulve gasket and the its internals were sitting ontop of the cam.. it was the middle cylinder on the driver side.. the rocker arms were VERY badly burned/rusted looking.. as far as i can tell there is/was nothing else knocking.. im goi to take it complety apart tommorrow (take off the heads and oil pan).. whoever sold me the car knew exactly what was wrong with it too .. the vaulve over and intake were barly on hand tight!! there probably was at least 20 oz of silicone make-ur-own gasket stuff holding on the intake (good thing i had a pry bar handy )
just thought i would share that with u guys.. anyone think this is worth fixing?? oh well...
lala always has the answers :hail: :lala: :hail: :lala:
mike (loomdog)
Old Feb 25, 2002 | 09:25 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
look @ my engine bay pics, you too will have that. I'm doing the 3.4 swap. will be selling the heads & what not that's left over. Damn, I sound like Karl :nono: , & we even have the same yr/color car too.
Old Feb 25, 2002 | 10:40 AM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
How far is it apart? if you replace the lifter and the other burnt part and put her together and she runs -- is there a need to go any further? I tend to adhere to the "Keep it Cheap" method. Of course, if this is your "fun" car and a project to be built upon -- then do the 3.4 or other motor swap.
Old Feb 25, 2002 | 10:59 AM
KED85's Avatar
IF it ran ok, TRY the repair.
IF NOT RAN WELL, consider it dead.
OR take pics and sue the guy in small claims court.
That may obtain funds for a better engine.
BUt look around for the best opotion.
Including using your time, too.
Old Feb 25, 2002 | 11:01 AM
Engine: 5.7 / 7.4
my drivers side head had this. whow is your oil/ what color? might have leaking head gasket/cracked block. no fun
rust on valves/springs/rocker arms aint pretty.
Old Feb 25, 2002 | 01:28 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
That "burned" look might just be age...
Old Feb 25, 2002 | 11:58 PM
loomdog32's Avatar
Car: 82 Camaro Z28
well.. i replaced the lifter and pushrod (yes only the lifter and pushrod).. then reasembled the engine.. its running pretty good now.. slowest car ive ever driven tho (slower than the 4 banger '98 s-10 i used to have).. im goin to be swapping in a 3.4 in the near future.. i found a l36 from a 94 maro that im gonna be rebuilding..
has anyone ever got a t56 to mate to a 3.4? is 6th gear usable?
mike (loomdog)
Old Feb 26, 2002 | 08:32 AM
KED85's Avatar
I know one guy that have the 3.4 & stick set up.
I know Dan is hoping to do the 3.4 & stick set up , too.
The answer is ALWAYS include new clutch work for the tranny.
Good going on the band aid!!
Hope it holds up well!
Let me know if I can help with 3.4 engine location.
86maro_252
Oct 10, 2015 06:52 PM
usafirebird
Sep 29, 2015 11:58 PM
spartanreaper
Sep 25, 2015 07:22 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
89bird2.8
Sep 18, 2015 07:46 PM
