Dynomax Cat
Old Feb 25, 2002 | 08:54 PM
87Bandit's Avatar
Car: 1987 Pontiac Firebird
Engine: 2.8lt V6
Transmission: TH700R4
Dynomax Cat
Does anybody run a dynomax highflow cat. I found one in jegs with the part #289-15735. It says that it is for a 5.0 ( engine codes H and G). I thought that those engines ran the same cat and exhaust as the v6's. Am I right?
Old Feb 25, 2002 | 09:17 PM
Setzer's Avatar
Actually, if you are going with JEGS I believe the part number is 289-17493. I am running it but I got mine through Summit. Hope you enjoy it, I sure do.
~Josh~
Old Feb 26, 2002 | 03:54 PM
87Bandit's Avatar
Engine: 2.8lt V6
i ment a dynomax high flow catalytic converter. I was already planning on getting a cat-back exhaust. Does anybody have a dynomax high flow catalytic converter.
Old Feb 26, 2002 | 07:44 PM
RPS's Avatar
RPS
om my 92 3.1 camaro, i got Catco converter... i like it allot
Old Feb 27, 2002 | 12:38 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Search for my old post mentioning the Catco convertor part number. (Click on "search" on the upper right of this screen, type something in to search for, type TomP as the author, and choose the V6 forum). Then use that # at SummitRacing.com to look up the CatCo, and see if it's also spec'd for engine codes H & G.
Old Feb 27, 2002 | 01:41 PM
SAEspinz80's Avatar
i am pretty sure the exhaust setup on the 8 is exactly the same as the six. the only reason why it is probably spec'ed for the 8's is cause of tube diameter. stock the 6's came with 2.25 and the 8's came with 2.5". so technically if you were going to put it onto a stock exhaust on a six it wouldn't fit.
my hooker muffler i bought is actually spec'ed by hooker for a 4th gen but had the same dimensions as the 3rd gen muffler. the difference = the 4th gen had a 2.5" i-pipe input while the 3rd gen had 2.25".....so i bought the 4th gen and sounds and runs like a charm. i am yet to do my cat.
Old Feb 27, 2002 | 05:01 PM
maverick544's Avatar
just go with dynomax cat back and you'll be ok.
Old Feb 28, 2002 | 07:39 AM
SAEspinz80's Avatar
he's not talking about a catback....he is talking about the CAT itself. and was wondering if anyone has it already....
as long as the diameter on the cat matches the diameter of you exhaust you will be ok. the cats should be exactly the same on the 6 and 8 cars.
Old Feb 28, 2002 | 10:07 AM
Red88RS's Avatar
Catco hi flow direct fit converter
part # CTO-4115
http://www.summitracing.com
put it in mine, bolts right in, no fuss no muss
Old Feb 28, 2002 | 11:26 AM
CC_HotRod's Avatar
Car: 1984 Camaro
Engine: V6
Transmission: 700 R4
OK I did a search for my old post concerning the Dynomax Catylictic Converters. It is here:
https://www.thirdgen.org/techbb2/sho...threadid=75801
Check it out.
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
