Exhaust question?
Old Mar 8, 2002 | 11:01 AM
90_RS's Avatar
Exhaust question?
Just out of curiosity, what is better, Having straight pipes or getting flowmaster or some other type of exhaust? ( don't think i spelled this right , but oh well)! Oh and one more thing, torque converter, how much and how hard is it to install one?
Old Mar 8, 2002 | 12:01 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
A full catback is your best option. If you run straight pipes all the way to the back, it'll sound like crap, and the exhaust gasses will "back up" in the pipes. I ran with just a pipe to the back (original muffler fell off, oops), and the car was a dog.
A torque convertor's going to require you to drop the transmission to install it. It slides over the input shaft of the trans, and bolts onto the flywheel. The only way to get that TC off the input shaft is to drop the trans. You can remove your flywheel inspection plate to get a look at this. It's under the car, between the engine and trans, painted black, and held on with 4 screws; I believe two 15mm's and two 10mm's.
Old Mar 8, 2002 | 12:14 PM
90_RS's Avatar
sweet, thanks alot about how much does a good torque converter cost, for a good one thats gonna make a good improvement( going to cruisefest and i want to be able to do small burnouts while i'm there) ?????
Old Mar 8, 2002 | 12:23 PM
kessler89/2.8's Avatar
Car: sold the Z now i'm drivin a 81 toyota celica and an 01 Suzuki TL1000R
Engine: 90degree 998cc V twin
Transmission: 6 speed
yeah don't run straight pipes just get a catback system from dynomax or get a flowmaster bolt on from jeggs or summit
Vintageracer
Jan 10, 2020 05:33 PM
chazman
Aug 28, 2018 03:25 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
