v6 rear gears
v6 rear gears
what gears came in v6 cars was it all 3:42's or is that only in manual trannys? and are any of you guys using the slp posi unit the cheap one?? i might sound like a a** but i am thinking of putting a v6 rear in my car and want to have posi to..
Car: 1986 Firebird
Engine: 2.8 V6
Welcome to the "dark side", 89formula4life!
Yeah man, if you can find an I-4 2.5l f-body in the junkyard, it's got a 3.73/open/drum axle! The '84 Camaro H.O. (says so on right of rear bumper) also came with a 3.73/open/drum. A few 82-85 Trans Am's and Z28's (engine code on vin (eighth digit) is "G", with a manual trans) came with the 3.73/posi/disc, which is what I swapped into my car.
BUT: Take it from someone who's been there, done that, and doing it again. Are you sure you want to go this way? So far, my $150 bargain has cost me upwards of $700- and is now costing me MORE, since the posi took a dump, I have to buy another axle. (Check out my "Ford Taurus!" message.)
I should've bought NEW 3.73's for $200, found axleshafts somewhere for $100 (overestimate), the SLP take-off for $100, and had it installed for $200. I'd probably be much happer, and would've only spent $600.
TIP: If you're into this kind of thing, I used http://www.por-15.com on my axle. I bought the POR-15 "Super Starter Kit, semi-gloss", and it had just enough to cover my whole axle. It made the axle look brand new; I recommend it. For $20, it was well worth it- and it brushes on perfectly! It's so "thin" that you don't need to spray it, and the brush lets you cover every little bit of rust.
TIP2: Replace the rear wheel bearings & seals while the axle's on the ground. You'd have to take the axleshafts out to change the differential to the SLP unit anyway!
Car: 91 Camaro RS
Engine: GM PP crate 350
Axle/Gears: 3:42 spooled 10 bolt
hey please tell me something
i got a 700r4 tranny 3.1 LHO v6 91 RS
is it 342 rear or 323?
2 ppl told me i got 323 so now im reeeaallly confused
Car: 92 RS 25th Anniversary
Engine: 3.1
um i was wanting to swap from my 323 gears to 373 and was just wodering about the cost and everything i would need to do it, i heard something about a install kit but i dunno
help
help
Car: 1992 RS
Engine: 3.1L V6
From what I understand Berlyn, You have 3.23's. I heard only the 5 speeds have 3.42's. But I could be mistaken. See, I tested mine kind of, someone on this board told me to ride my car in 4th (5speed) until 70 and read the rpms. It was around 3230. Which means from what the guy told me I have 3.23 gears. If I had 3.42 gears the rpms should have been around 3420 rpms. You see what I'm saying? I guess the 4th gear in five speed cars are a 1 to 1 ratio. I don't know how to check in auto cars. Sorry I couldn't help you too much.
Car: 1989 C4
Axle/Gears: 307
Yep automatic transmission cars came with 3.23 and 5 speed 3.42. The 3.42 I have in my firebird came from an 88 or 86 (I forget) 5 speed I have an extra 3.42 open just in case. Some auto Z28's like my old one 5.0/carb came with a stock 3.42 posi drum brake system. Very nice but very rare.
I used the hammer finish paint for a base coat on my rear end build then painted the shafts black and the center section polished aluminum color, looks
. Thread
hectre13
Dec 11, 2023 08:14 AM
ambainb
Apr 25, 2016 09:21 PM
hectre13
Aug 26, 2015 08:17 AM
