upgrades to my 86 2.8 engine
Old Mar 13, 2002 | 09:05 AM
onehotz's Avatar
Is there any good and cheap upgrades i can do to my 2.8 out of an 86 camaro?
Old Mar 13, 2002 | 09:16 AM
Bluerocket's Avatar
Home made ram air, and a tune up
Old Mar 13, 2002 | 11:03 AM
Camaro_hunter_d's Avatar
Also depends on what your definition of "cheap" is. My ram air system set me back about 90 bucks, and 2 weeks to get it done. and thats not even using K&N's.
you could cut out the bottom of the air box, thats free, you just have to own the dremel/air compressor & wizzer wheel for that though.
go to parts store and buy a spark plug gapper and gap all plugs to .050. It helps.
Could buy a MSD replacement coil pack. About 42 bucks all togeather with S&H from summit.
Though not all that cheap you could get the Dynomax cat back (140) and a Catco high flow cat (60) and pick something up too. You'd also sound better.
I'm sure the first thing tomP is gonna say is do the "complete tune up" so I will save you from that. Though he will probly post it anyway.... I swear he has a fetish for that tune up thing...
Old Mar 13, 2002 | 11:11 AM
Brian K's Avatar
Cheap.. Nothing for cheap will help the 2.8… Look into a dynomax cat back----139.99, a catco high flow converter----59.99, msd coil---39.99, msd 6a----169.99, crane 2030 cam 159.99, 4.10 rear gears 199.99, comp cam 1.52 roller tip rockers---109.99
Cheap ,I have it Port your own cylinder heads…
Old Mar 13, 2002 | 11:13 AM
actually you still have to pay what is it 40-50 bucks for the kit, and 20 for the intake gaskets, then another 30 on the head set gaskets.... LOL Just giving a hard time.
Old Mar 13, 2002 | 03:59 PM
86BIRD-MY FIRST CAR's Avatar
Hey i was thinking about getting that dynomax cat back for my cousins camaro as a gift for 150.00, but shipping is $60 bucks !, damn
Old Mar 14, 2002 | 12:13 AM
89camaroRSV6's Avatar
u have same dual intake as mine..
just open the air boxes in the front of the radiator... and cut the bottoms out.... thats cheapest to do...(get a saw blade for 3 bucks = hard way or easier is get a dremel ...
fastest way is a whizzer wheel thanx to cvamaro_hunter for that..
that ought to be the cheapest mod u can do...
(ahem ... there is no such thing as a free lunch)
Old Mar 14, 2002 | 02:13 AM
Ghour_Demon's Avatar
In case you didnt know this but edelbrock sells a cam and intake performance package for the 2.8, but that wouldnt be cheap compared to whats mentioned above...
Old Mar 14, 2002 | 08:37 AM
talkin about camshafts.... the cheapest cam is a wolverine blue racer.. that has the same grind pattern as crane (even better than crane atually...(same company) edelbrock is expensive but the same grind ,...)
the wolverine runs 119$ from jcwhitney.com
the crane runs 159...
i think edelbrock is even more..
hey Ghour i think the intake package is for carbed and TBI 2.8's
Old Mar 14, 2002 | 09:01 AM
Brian K's Avatar
Crane will work with the stock CPU and that is a major benefit. The other does not claim that.
Old Mar 14, 2002 | 09:05 AM
the blue racer is the same grind but with just a little more exhaust lift
the blue racer ...jcwhitney claims will work with tthe stock ECM
well both are crane subsidary companies for one ..wolverine and crane cams
but hte major diff is crane claims the 2030 is 50 state legal...
the other does not
Old Mar 14, 2002 | 03:00 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Like Bluerocket said, you better do a major tuneup FIRST, in order to get the most performance out of any power part you put on. Click on "search" at the upper right hand corner of this screen, and search for "Major Tuneup".
Old Mar 14, 2002 | 08:03 PM
What'd I tell ya?
Old Mar 14, 2002 | 08:42 PM
WaynesRS's Avatar
I second this !! You would really be surprised what a good tune-up would do to your car .It really wakes it up ! Plus it will help out all those mods you plan to do !
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
E Rod
Aug 28, 2015 05:17 AM
NinjaNife
Aug 23, 2015 11:49 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
