Emmissions Label
Old Mar 20, 2002 | 02:59 PM
stuart69427's Avatar
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
Emmissions Label
Where can I get one? Mine is no longer there, it wasn't there in the first place, everything always says, check your emmisssions lablel....
Old Mar 20, 2002 | 03:20 PM
KED85's Avatar
You'd be hard pressed to locate one.
GM stopped remaking them. BUT you CAN try, BUT I really doubt you'll succeed.
I tried once and was kinda laughed at, at the dealer parts counter.
Re: for my 1985 S-10 Blazer, Federal Version, trying to "pass" a Rooked Smog station test.
I hope that station got it just due!
Yes, my search was years ago, tho.
Your shop books do have all those answers, tho.
So do the smog stations.
Old Mar 20, 2002 | 07:32 PM
BitchinRS's Avatar
All your gonna find on the lable is your timing spec, how to disconect the EST, and what type of cat you use. The fan belt routing is on a different sicker so you cool if you need to replace a belt. All though having that sticker missing is a sign that your car was in a front end accident. The shops that replaced the hood and other crap didn't out a new one on when they were finished.
But like Karl said you will be hard pressed to find one from a dealer. If a dealer can get one for you it will cost $5.00
Old Mar 20, 2002 | 09:00 PM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
i just want the timing specs
Old Mar 20, 2002 | 11:53 PM
KED85's Avatar
ALL TOGETHER NOW
ALL TOGETHER NOW
10*.
There's only one way to go on the timing mark.
How many miles on your engine?
Old Mar 21, 2002 | 08:05 AM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
133,250 k
Old Mar 21, 2002 | 09:16 AM
KED85's Avatar
You need to replace your timing chain, my friend.
Ask us how.
It is so fun!
Ask us how to check for this thruth.
BUT return on performance is really worth the effort.
Better scoot
Better gas
Smoother running.
You win all around!
Old Mar 21, 2002 | 09:28 AM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
where To Get? How much? How Hard?
Anything to get it running right!
Old Mar 21, 2002 | 09:50 AM
KED85's Avatar
800-831-0884
Northern Auto Parts
Get Fel pro gaskets
Probably Speed Pro Chain
No-Name water pump
Delivered $50-ish.
Also get all the little things you said for the future.
Save the shipping costs & sales tax you don't pay!
You remove whole "nose" of engine and replace.
Test
17MM on crank socket, ratchet.
Pop off distributor cap, look how long crank moves until the rotor moves.
If crank movement is close to an inch (it will be) there's your problem.
Remove balancer, water pump, timing chain cover.
Pull off gears (flop chain first for fun! you're there!), align gears by block of wood, reverse procedure.
Oh so fun!
But, I've done it to my tired 2.8 & HELLO AGAIN!.
There is life after 100K. Very strong & subtle.
Compliment by distb rebuild, upgrade coil, wires. BOOM ZOOM! It'll perk you head up again.
Or really return your engine closer to original HP rating.
Old Mar 21, 2002 | 11:55 AM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
I already have an O2 sensor, thermostat, and PCV valve, just have to put them in. I get paid tommorow, so i am going to finish exhuast and do the timing chain and stuff.
Also is there a kit or something to rebuild my distributor, when I replaced my rtor/cap, I noticed that the upper portion that the rotor connects to is all rusted and the wires that coiled around the shaft are very brittle and falling apart. I need to get that fixed too.
Old Mar 21, 2002 | 03:56 PM
BitchinRS's Avatar
If that's the case, you should rebuild the distributor. You can buy all of the part indviualy (SP?), but I'm not sure if you can buy them as a kit. mainly you want to replace the pickup coil (that's the brittle thing). You can get away with useing 200 or + grit sand paper to clean every thing else. All though you can buy a new stator pole pice there really is no need. Just clean it and realign the poles. To realing you want to get them as close as possible to the pickup / stator with out touching. When I did mine a few were accually hiting. While you are there and if you have the spare cash get the Holly ignigtion mod and replace the stock one. It cost the same as stock, $60 or so, but will help delivery full spark through the entire RPM range and give smother idle and throttle respones. Slap it all back together and reset timing.
If you are going to tackle the timing chain and distributor I sugest getting a hold of both the Chilton's and Haynes repair book for your car. They will give step by step instructions. Or get the shop manule. It's covers way more stuff, but cost about $70 Vs. the $15 - $20 for the Chilton's and Hanyes.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
gta892000
Aug 11, 2019 11:16 AM
Thaney9
Oct 24, 2015 07:26 PM
mcgarnicle
Sep 24, 2015 07:18 PM
gta892000
Sep 16, 2015 12:37 AM
