? about Rebuilding Distributor
Old Mar 26, 2002 | 04:14 PM
stuart69427's Avatar
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
Ok I read all the old posts with TomP and Ked's wonderfull description, but I am confused on one thing, is a spark module the same thing as a ignition module ( aka MSD 6AL box ) ???
Thanks in advanve guys!
Old Mar 26, 2002 | 06:29 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Well, a spark module is the same as an ignition module, but I don't think the MSD 6-series boxes count as ignition modules. I usually call them ignition boxes. Here's a picture of our ignition module:
'Course, you can't click for a fullsize picture, find that thru the http://www.holley.com site, click on annihilator ignition system, then click on accessories, then click on 891-103. For info; the small two-pins exiting the back of the module go to the "pick-up-coil" inside the distributor. The external (GM weatherpack) two-pin connector goes to the spark coil. The external 4-pin connector goes to our computer.
Older HEI systems, specifically, those with the coil inside the top of the distributor cap, used a 4-pin module. This 4-pin module can be entirely REPLACED by an MSD 6-series box! If you want to see that kind of module, here's a picture: http://store.summitracing.com/partim...t=22694&page=1
But, we're not so lucky. We can't replace our module with the MSD box, but we can still add an MSD box on. We disconnect the spark coil, and connect that engine harness into the MSD box. Then the MSD box connects to the spark coil. So for us, the MSD box "interprets" a spark signal. For the older 4-pin HEI's, the MSD box "creates" a spark signal.
Hope that helped!
Old Mar 26, 2002 | 08:31 PM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
thanks that helped out a lot, i love you man
Is this all I need to do the rebuild?
Pick-up Coil
Holley Spark Module
Distributor Gear ? maybe ?
As far as tools and misc:
Feeler Guage
Heat Sink Grease
1 inch O-Ring(s) (from PepBoys)
Sand Paper (Got plenty)
Black RTV (Will weatherstrip addhesive work? never used RTV before? )
Brake Cleaner
Axle Grease
Old Mar 26, 2002 | 11:38 PM
KED85's Avatar
Feeler gauge.
NOPE!
Gear
NOPE (if it engaged before why not now?)!!
BLACK RTV & CHEVY SMALL BLOCK DISTRIBUTOR GASKET!
Lay a film on both sides of gasket and lay in distb.
Say good bye to oil leaks!
Need a punch to remove the roll pin!
It truly is a very simple job once distb in your hands.
Old Mar 27, 2002 | 12:48 AM
BitchinRS's Avatar
If you opt to go with the o-ring rather then the gasket get the 1 and 1/8 inch o-ring. 1 inch is slightly to small and will be harder to get on.
Old Mar 27, 2002 | 07:04 AM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
ok I ordered a Holley spark module and Ill be picking up the other parts from PepBoys and others between jobs, let ya know when I have time to tackle it, maybe sat or sun, i dunno
fyi - I will try to pick up a phone and order the stuff to the timing chain too, if I get a chance
still debating on a Gasket or an O-ring, but I'll look at them both and campare if I can, then decide.
Old Mar 27, 2002 | 09:42 AM
KED85's Avatar
800-831-0884
Northern Auto Parts
has it all & cheaper than anyone.
Free call
ALL NAME PARTS
My chain gasket was $50-ish delivered
Speed Pro & fel pro parts.
GET WATER PUMP TOO
Only extra $20.
Summer is coming!
Get both.
FOR SURE NO LEAK!
Old Mar 27, 2002 | 09:59 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Btchin, is that 1 1/8" outside diameter, or inside diameter? If it's outside diameter, than my 1" inside diameter o-ring is the same as your 1 1/8" outside diameter o-ring! I had a 1" outside diameter o-ring given to me once by accident; it looked too small to even try.
Old Mar 27, 2002 | 11:40 AM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
tomP,
what thickness of O-rings did you get? I dont really like the quality of the ones at pepboys, might go gasket
Old Mar 27, 2002 | 03:03 PM
KED85's Avatar
The small block chevy one is only $1.
Add it, can't hurt!
Cheap insurance against a PIA job.
Old Mar 27, 2002 | 03:31 PM
BitchinRS's Avatar
Here are the specs on the bag of o-rings I picked up, bag of 5 for $0.98.
Width 1/8"
I.D. 1"
O.D. 1 and 1/4" (not one 1/8 SORRY!!!)
Manufactured by Motormite part number 84214 at Kregan's Auto Parts.
I thought about useing the gasket and the o-ring to provide double insurance against future leaks, but when I replaced mine I didn't have much time and forgot to pick one up.
Old Mar 27, 2002 | 03:39 PM
KED85's Avatar
First time I used the gasket, I didn't know about those O ring things.
I had a Chevy gasket hanging around, instead and it fit!
Old Mar 27, 2002 | 04:00 PM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
thanx guys, now all I need is the axle grease, heat sink stuff and an O-ring, then wait for my holley spark module and i'll do this sun afternoon
Old Mar 28, 2002 | 03:29 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I found this old message by 89V6FBIRD, which mentions a part # by Pep Boys:
Originally posted by 89V6FBIRD
The O-ring you need is, yes tomp is right with the 1 inch inside diameter (always go w/ him), the width is 1/8 inch and the Outside diameter is 1 1/4 inches. hope that helps. Oh and the number on the Pep Boys bag is 64214 if that helps any.
Old Mar 28, 2002 | 03:52 PM
WaynesRS's Avatar
I think this coil works to , Summit has it , ACC-35362 . Its $43.95 .
Whats your oppinion on this coil guys ? What you think Tom and Karl ? I know you guys like Accel products .
Old Mar 28, 2002 | 04:35 PM
KED85's Avatar
Hi Wayne,
Being in LA, we got lots of options (kinda like women ,
I called local parts houses.
I wanted Accel.
I got one for $36 + tax.
If I needed to, I would have been able to grab one at a swap meet for $20.
Old Mar 28, 2002 | 05:20 PM
WaynesRS's Avatar
ahh , lol I typed coil , what I meant was IGNITION CONTROL MODULE ....ACC-35362 dont know why the heck i typed coil
Old Mar 28, 2002 | 09:56 PM
KED85's Avatar
That's a fair price!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
amargari
Nov 10, 2015 02:09 PM
camarohelp
Sep 22, 2015 03:19 PM
WhteRbt
Sep 21, 2015 09:48 AM
eduardosac
Sep 16, 2015 02:18 PM
