Need help quick
Old Mar 29, 2002 | 08:57 PM
88MARO's Avatar
Need help quick
My car has been having trouble starting once in a while so i went to replace the ignition module, cap and rotor today. I had no problems doing it, and when i put everything back on i went to start it and it wouldnt start. It was worse then before. My voltage was fine and it would start cranking fine, but then my voltage would drop like the battery was dead and the cranking would slow down, lights dim, then go back up, then back down, then back up. I still cant get it to start. It was too late to put the old stuff back in. What could be the problem. this was the first time ive done this, but im pretty sure i did it ok. i'm at school and i have to go home tomorrow. this sucks. i should have left it alone, it was starting all day. thanks guys.
Chris
Old Mar 29, 2002 | 09:10 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Is your timing off? That what it sounds to me. The normal timing is 10degrees but many of us have ours set at 12 or 13 degrees
Old Mar 29, 2002 | 09:21 PM
KED85's Avatar
I'll bet, 100%, you screwed up plug wires on cap.
Old Mar 29, 2002 | 10:29 PM
88MARO's Avatar
I am almost positive that i put the plug wires on right, but i'll double check. I followed just how my chiltons manual said to. i dont think i did anything to my timing either, but who knows, i messed up something doin it. thanks
Old Mar 29, 2002 | 11:14 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
next time, draw a diagram of how all the wires are before replaceing all wires at once. it sux even more when it hapens on an 8 cyl
is the ig module hooked up? all connectors tight?
recharge the batt so you have a full charge when starting again.
Old Mar 29, 2002 | 11:22 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
I hear ya....
Damn Monte Carlo
Old Mar 30, 2002 | 12:48 AM
89BlackBirdKid's Avatar
85sportcoupe its fun to see your car progress more and more.. I love seeing the pics on the sig as its updated. Looking like a nice ride so far. good luck.
Old Mar 30, 2002 | 08:50 AM
KED85's Avatar
How to swap plugs at cap like an idiot.
Because I am one & I did it WRONG & no start.
Remove old cap with all plug wires on it.
Move it forward/flip over, etc.
Insert new cap on dist.
Take one wire at a time and put on new cap, now on dist.
Simply match position for position.
Go to start car.
IF IT starts:
Then start on rest of your distb replacement part list.
ALWAYS check plug/wire swapping instantly, while your error is fresh in your mind.
You need fresh battery, now, too.
You need the pics for fixing.
#1 cylinder/plug is Passenger front.
While charging battery, find that plug wire/distributor pic and look at your work.
You'll make it run again.
Old Mar 30, 2002 | 01:42 PM
88MARO's Avatar
Thanks for the help guys. It turns out that it was the plug wires. i did have them right according to chiltons. but my mechanic said that my distributor was off a tooth and the wires were compensated because of it. so the wires were one off too. thanks for all the help.
Chris
Old Mar 30, 2002 | 02:28 PM
KED85's Avatar
BUBBA THE PREVIOUS OWNERS MECHANIC STRIKES AGAIN!!!:lala: :lala:
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
