MAF Connector
Old Apr 11, 2002 | 01:48 PM
mvftw's Avatar
MAF Connector
My MAF Connector might be flacky. It looks good. Is there a magical fix to this connector. The wires look tight in it. Is there a fix without taking it apart? I tried connect cleaner already.
Old Apr 11, 2002 | 02:49 PM
Camaro_hunter_d's Avatar
are the wires snug in the connector? can't be pulled out?. are the wires covered properly? Meaning no cracks or anything in the insulation? might try some dialectric grease...
Old Apr 11, 2002 | 03:12 PM
mvftw's Avatar
They look good, I have the grease. I'll try trhat first.
Old Apr 11, 2002 | 03:19 PM
I have seen dilectric gresae conduct voltage through some serious *hit... water included... so...
Old Apr 11, 2002 | 03:30 PM
mvftw's Avatar
Thanks for the heads up!
Old Apr 11, 2002 | 05:54 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
A new connector is about $15 from Pep Boys. If you want a part #, it's by Motormite.. here's the detail I posted up a while ago:
Originally posted by TomP
Okay guys, I knew I've seen that 5-pin pigtail at Pep Boys, and since I'm such a nice guy, I went there, and got the info:
Manufacturer: Motormite
Website: http://www.rbinc.com
Phone # (PA Office): 215-997-1800
85-89 5 pin MAF pigtail
Part # 85133
Pep Boys Price: $19.95
85-89 3 pin MAF pigtail
Part # 85111
Pep Boys Price: $15.95
So, there you go, it does exist! Of course, it's not through Bosch or GM. Have fun!
https://www.thirdgen.org/techbb2/sho...threadid=19872
Of course, you want the 3-pin pigtail...
Old Apr 12, 2002 | 07:40 AM
mvftw's Avatar
Thanks TomP. I replaced the MAF, it runs better, but not perfect. I think I have a vacuum leak. I'm ruuning at 14". I the old days 18-22" was normal, is that the same on these MPFI cars? If so that might be it. I checked the hoses they look good. The Purge Canister lines are very hard. Do they stay in the engine compartment or do they extend under the car?
Old Apr 12, 2002 | 12:30 PM
89camaroRSV6's Avatar
hey mvftw,
didya change ur cam???
cos cam changes the vacuum...level
Old Apr 12, 2002 | 08:23 PM
mvftw's Avatar
Stock Engine. What should the vaccuum be on a stock 2.8?
Old Apr 14, 2002 | 03:24 PM
yep 18 is normal...in idle when i was stock it was like 18-20
BumpaD82
Feb 26, 2016 02:57 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
Nick McCardle
Sep 10, 2015 08:36 PM
