SLP's response on 9" wide ZR1's
Old Jan 7, 2005 | 01:42 PM
BumpaD82's Avatar
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
BUMMMER :
"Hi Dave,
From what I've heard I don't think we will be doing a 9" wide rim for
the
third gen cars.
Dana P. Kermes
SLP Performance Parts Technical/Sales
732-349-2109 ext 146
m-f 8:30-5:00 lunch 12:00-1:00"
I'm running 9" wides now and I don't want to go to 8's makes me MAD !
Old Jan 8, 2005 | 09:51 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
A 9" wide wheel is silly - its only 0.5" wider than the 8.5" they presently have. If you were to say 9.5" to accomodate a 275-40-17 tire, they might get enough buyers (I would get a set stat).
Old Jan 9, 2005 | 07:26 PM
25THRSS's Avatar
It's not an 8.5 inch, it's an 8 inch wheel that they offer. If I was going to buy a set of aftermarket wheels you better bet they would be 10 inch in the rear. Not worth the money IMO, unless you don't care about performance at all and are only going for "style."
Old Jan 10, 2005 | 06:02 AM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
an 8 inch wide wheel is stupid... biggest tire you can fit is a 245 or you could squeez in a 255.
9 inch wide wheel would run a 275, which is what all 4thgens run with their 17" wheels...
this wheel is for anybody who is intrested in upgrading for asthetics only, and not any kind of performance advantage.
Old Jan 10, 2005 | 07:49 PM
Shagwell's Avatar
Car: projects.......
If you're spending the money, and want performance, go all out. 11" wide and 315's on the back. They'll fit in the wheel well w/o mods.
Old Jan 10, 2005 | 11:49 PM
85 roc it's Avatar
Car: 85 IROC
Engine: 385AFR head, Mini Ram Intake
Transmission: 6 Sp.
It you want wider, just get a set of new rims and buy the spacers, I did, but I put a newer rearend in also, but 2 in spacer will work for 9.5 rim, I had 275 on a set of 8 inch rims, them fit just fine also, but rubbed when went over big bumps because car was lower
Old Jan 11, 2005 | 12:17 AM
85 roc it's Avatar
Car: 85 IROC
Transmission: 6 Sp.
Old Jan 11, 2005 | 09:05 AM
BumpaD82's Avatar
Well unfortunatley I've seen wheels fall off / break off in the autocross with spacers SO taking that into account and my "normal" style of driving... spacers aren't and option.... too much leverage on the studs IMHO... and yes I know that people get away with it all the time it's just not for me
Old Jan 11, 2005 | 10:27 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you're confusing a slip on spacer with a bolt on.
a slip on spacer, like you said, puts ALOT more stress on the studs. unless its really thin (like the ones that came stock on 3rdgens) they're not that safe.
now a BOLT ON spacer is atleast a inch thick.
it bolts onto the car like the wheel does. full stud engagement and all... so it becomes part of the axle, with no additional stress.
it has its own studs, and the wheel bolts to thoes studs
when using cast alloy wheels, the spacer is actually stronger then if it was cast into the wheel.. lol nice strong billet.. no additional stress to the axles, studs or bearings.
Old Jan 11, 2005 | 11:10 AM
BumpaD82's Avatar
NOPE I'm not confusing the two And I have seen BOLT ON spacers break / pull studs / fall off / etc. etc. etc.
Like I said they work for LOTS of people just not for my driving style
Old Jan 11, 2005 | 01:54 PM
fb305svs's Avatar
your driving style cannot possibly be any worse than mine and i have a bunch of autocross runs on my car with 285/335's.... The reason you see them break studs is because you have to periodically check them, like before each race to make sure the studs the spacer bolts to are tight...
any bolt on spacer that causes breakage is because of crappy studs, or because of user error, like its loose...
Old Jan 11, 2005 | 02:04 PM
BumpaD82's Avatar
LIKE I SAID: LOTS of people get away with it all the time, IT IS JUST NOT FOR ME, as in MYSELF
And I carry a Torque wrench and check before, during and after each race....
So anyway now that the spacer argument is over, I'm still bummed out you can't get a 9" + ZR1 rim that fits the car without a bandade....
Old Jan 11, 2005 | 02:37 PM
88IROCs's Avatar
Has anyone inquired if the Sport Edition "5055" wheels are available in fitments for our cars. TireRack sells their lines, but I couldn't find contact info for the manufacturer.
This is what the "5055"s look like:
CHROME
PAINTED
Old Jan 11, 2005 | 02:46 PM
fb305svs's Avatar
looks exactly like my zr1 wheels
Linson
Oct 24, 2025 02:00 PM
no green
Jan 9, 2016 09:22 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
meeklay812
Oct 1, 2015 03:46 PM
Royal_Z
Sep 30, 2015 08:45 PM
