widest tires I can put on my rs's rims without problems
Car: 91 rs
Engine: 305tbi
Axle/Gears: 3.27 9bolt
what is the widest tire that will fit correctily on my stock 16" rim and won't rub the body, cause problems. It has p245/60r15's on it now. you have to have the same front and rear widths on stock rims, like say i can run a wider tire on the backs can i keep the 245's on the front. what does each of the #'s mean? p245/60r15's first is diameter, second is width, third is rim size?
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
Re: widest tires I can put on my rs's rims without problems
First is sidewall to sidewall width in millimeters. Second is aspect ratio for sidewall width to sidewall height in percentage. 60% of 245. Third is rim size in inchs.
RS rims are 15x7 right? Stick with 245. Thats probably too wide already.
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Most RS wheels are 16x8's, and came stock with 235/55/16's, IROC's came with 16x8's as well and have 245/50/16's stock and fit quite well. The only bigger tire made for 16" wheels is the 255/50/16 and will also fit fine front and rear. Some guys have reported getting a bit of rub when turning to full lock, also a lot of guys get the same rubbing with the stock 245's as well so it's not really something to worry about.
If you do indeed have a 15" wheel (came on base model's) then they most likely had 215/65/15's stock, and a 235/60/15 fits the stock 7" width wheel well. You can squeez a 245 on there but the sidewalls start to buldge a bit and handling will begin to suffer. There seems to be a craze of stuffing 275's on stock 7" width wheels on these boards lately, and it's gonna get some one killed when the tire peels off the rim.
colton_carlson
Mar 8, 2019 12:21 PM
