18x10.5s all around?
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: 18x10.5s all around?
you will never get them to fit up front
Car: 88 rs
Engine: twin turbo blow through 350
Transmission: t56
Axle/Gears: 7.5 worn posi pretty sure 3.23s
i wouldnt say you could NEVER get it done, but i will say good luck. lol i run around a 1.5/2 inch drop with 17x9.5s with a 255/45 upfront and they rub at a lil before full lock. i need to get some 255/35's really tho, as i have 18x10.5s with 315/30/18s in the back. good luck, maybe somebody will chime in whos got 18s up front.
COTM Editor
I got 18x9s up front and there is some room, but not much... trial and error is probably your only choice.
Really do you need to rotate them that bad?? Plus your gonna wanna put drag radials on the back anyway, and you know that those will never see the front.
Car: '91 TA vert
Engine: turboLSx
You can fit 10's up without that classic trailerpark look. I had 18x9.5's with 275's for quite a while. Even dropped 2.5" I never rubbed. It's all about where the wheel is sitting in the fender. I jumped to a narrower wheel, 8.5" with the same width tire and now when I reverse quickly at full lock I'll get a little rubbage. If my rear tires were shorter, (they're a ~27" tall) I'd try fitting up my 19x10's but oh well.
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
LOL! That may look trailer park, but at that view point it looks all business, especially with the driver wearing a helmet!
it was an auto cross car, the wheels were for sale on ebay a while back thats where i got the pics
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
It can be done, with some work, and the right wheels.
Here is a picture of Karl Hunters car at the Knox Hillclimb, he was sporting 18x11 CCW's on all 4 corners.
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
Car: 1990 Camaro RS
It took some searching, but here is another picture.
https://www.thirdgen.org/forums/post...20-post20.html
Here was his quote later in the thread.
The wheels are from Complete Custom Wheel in Florida.
They are all 18" X 11" wide. The backspace is the same on all 4 wheels, but I use spacers on all 4 wheels to achieve the "perfect" fit front and rear. CCW makes wheels to the 1/4" in backspace and width, but you never know "exactly" where the clearance issues will be until you get the car on the track. It is amazing what flexes and bends on these cars. Downright frightening in some cases.
Modifications are required on both ends of the car to get this big of a wheel under the fenders. Prodigious use of a BFH is necessary. Trimming of the front fenders is necessary. Rolling of all the lips is necessary. Fender liners optional.
I would never recommend anything this big for the street. Maybe on the rear, but never on the front. 9.5" wide is the largest wheel I would put on the front for the street.
I run Good Year Eagle Radial Slicks - road race. Not street legal. 25.5X11.5-18 front and 25.5X12.5-18 rear.
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
I had 18x10's all they way around on the vert in my sig. Just added 2" spacers and never had a problem unless at full lock. Adam :-)
Car: 85 Camaro
Engine: forged 383 11:1
Transmission: T56 TDP STAGE 2
Axle/Gears: 99 ws6 3.42 posi rear
Car: 87 IROC
Engine: 5.3L
Transmission: Jerico
Axle/Gears: Aluminum 8.6 w/ T2R
yeah, IIRC it one pair of wheels was 58mm and the other was 56.
Did you look at the pictures on photobucket?
The tires *might* touch the inner fender at full lock, but I'm not that concerned. I never checked that with the car on the ground.
1 Post
Car: 1992 GTA
Axle/Gears: 4.10
i have y2k 18"s for my rear and im looking at widest size tires I can fit with out too much work...you said your running 315/30/18 did you need any tubbing or anything special done to make that tire fit? Pm me because I dont mean to hijack this thread but im very interested.
I run 18x9.5 Y2K's all around with a 1.6"-2" drop. On the back I have MT Sportsman SR's that are 18x26x12 and up front I currently run a 245/40/18 .
With a proper allignment and spacing I have zero issues with front tires touching on full lock. The car also has the bump stops removed from the rear and some vewry slight massaging of the rear inner wheel wells. I will be going to a 275/35/18 on the front this spring when the car comes out from its engine modfest.
Car: 87 IROC
Engine: 5.3L
The tires are Hoosier Grand Am Cups, 275/35/18, but in reality they are probably more like a 295. They are a spec tire for (guess what?) the Grand Am Cup series. They call for a 10-10.5" rim. I had them on a 9.5 before, and the worked, but were pinched pretty good. So I got the 10.5's.
ambainb
04-25-2016 09:21 PM
Grifter757
Exterior Parts for Sale
08-01-2011 09:33 PM
dust3r
05-31-2010 08:27 PM
dust3r
04-29-2010 07:10 PM
