Got Vette Wheels??...Post pics here...!
Old May 30, 2011 | 09:41 PM
  #401
kenlamb3's Avatar
Car: 91 Z28 Convertible Camaro
Axle/Gears: Borg-warner 3:27 gears
Re: Got Vette Wheels??...Post pics here...!
Originally Posted by kazamh13
hi everybody, i just bought a set of 18x9.5 Z06 black with polished slip rims for my 87 Z28... does anybody knows if i will need something else to fix them on it and what's the size you recommend to use on it for a nice handle... i was thinking in something like 285/40/18 what do you thuink about it???
hey man im running the same rims with 2 inch spacers front and back with 245-40-18 tires, but did some research about tire size and 285-40-18 should be just fine.
Hope this helps, also im running them on a 91 Z28 Convertible
Old May 31, 2011 | 12:20 AM
  #402
CamKid1992's Avatar
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
im running 18 by 10.5 with 305 35 18 in rear and 17 by 9.5 275 45 17. i have 2in spacers in front and 1.5in in the rear. AND LOWERED 3in on sportlines. you will be ok. im rolling my fenders wenesday to keep my rears from peeling on my lip but other then that there awesome.
Old May 31, 2011 | 09:00 PM
  #403
83 Crossfire TA's Avatar
I have the same combination with rolled lips and 295/35-18's and I don't really see how anything larger is going to go in there.
Do you have pics?
Old May 31, 2011 | 09:50 PM
  #404
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
Do you have pics?
first one was fresh, the day i installed them
second with dropzone springs
third with sportlines.
043.jpg?t=1306896405
camarolowered1.jpg?t=1306896496
camarowarped.jpg?t=1306896548
Old May 31, 2011 | 11:04 PM
  #405
Boreen's Avatar
I'm wanting to put some C6 Z06 wheels in 18's all the way around on my car.
http://www.oewheelsllc.com/Wheels-fo...-p6902224.html
Now, i am running the 3rd Gen rear end, so i know i am gonna need the 2" Spacer, but what spacer do i need on the front?
Also, what size tires can i run? I'm not looking to go something really wide, but dont want pizza cutter's either. I'm thinking 245's or 255's all the way around, or 235's or 245's on the front with 275's on the back.
Be patient with me as i am new to car tires and their sizing's.
I was also thinking of dropping my car 1" to 1.75" all the way around to.
Might do 17" in the same wheel\s all the way around if it makes it easier.
Old Jun 1, 2011 | 12:00 AM
  #406
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
you will need 2in for the front. rears will be 1.5in of course it all goes with your backspacing at anytime. with the wheels listed are the same backspacing as mine. and this is the spacers that i used
Old Jun 1, 2011 | 12:19 AM
  #407
Huh, not exactly what I expected, yours stick out a lot more than mine... I just realized that the pictures that I had up on the forum are gone and the only ones that you can get any impression of how they fit were taken while right after bought the car and was attacking the crappy body work on it.
Here you can see both how they tuck in and if you look carefully you can see my rolled lips. I kind of debate cutting the spacers down another 1/8"-1/4" just to tuck it them in better. Oh, and these pics are not at ride height, the car is up on jack stands:
A slightly more normal view:
don't mind the bondo stripe on the door, I have another door for it, not even going to use that one even though I mostly fixed it:
Attached Thumbnails Got Vette Wheels??...Post pics here...!-tirefit_070407_3.jpg   Got Vette Wheels??...Post pics here...!-tirefit_070407_4.jpg   Got Vette Wheels??...Post pics here...!-tirefit_070407_5.jpg
Old Jun 1, 2011 | 12:32 AM
  #408
Wait, did you use other offset wheels on the back? Mine are the stock vette offset and I have a 2" rear spacer with my 295/35's and they're definitely more tucked in than yours with 1.5" spacers and the tires should only be about 3/8" narrower (probably about 3/16" per side).
1.5" spacers will not be enough for 56mm offset, that will put them almost 3/4" in from centered, most people end up with 0-1/2" offset, I'm at about .2" if I remember right
Old Jun 1, 2011 | 12:59 AM
  #409
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
my rear wheel offset is 58mm and its only the 1.5in spacer
Old Jun 1, 2011 | 05:45 AM
  #410
Demon355's Avatar
Man those looks beefy! I wanted to run 315 Nitto 555R's on my 01 SS rims with a 2" spacer. Think I could get away with a 1.5"? Being only 9-9.5 rim, 2" is probably what I need. Anything wider can run a 1.5".
Old Jun 1, 2011 | 04:52 PM
  #411
Boreen's Avatar
What size tires are you running in the front and rear for your 18's and is your car lowered or stock height?
Old Jun 1, 2011 | 05:21 PM
  #412
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
17by 9.5 with 275 45 17's and 18by 10.5 with 305 35 18's
Old Jun 1, 2011 | 09:48 PM
  #413
Huh... Are you sure?
Mine aren't on the car right now and I just measured them (and double checked the recept), my spacers are definitly 2" and my wheels are front 17x9.5 with a +54mm offset and rear 18x10.5 with a +58mm offset. That should put your wheels farther in and it definitly looks like yours stick out and mine are significantly further in, like at least 1/2-3/4"
Something is not adding up. Do you have a 4th gen rear?
Old Jun 5, 2011 | 08:28 PM
  #414
sibelius126's Avatar
and i finally get to join the ranks of a 3rd gen with vette wheels i got 18x8.5 with 225/50/18 on front and 19x10 with 275/40/19 rear 2" adaptor and some massaging in rear and 2 and 5/16" spacer up front made the front wheels come out just the right amount it looks amazing
Attached Thumbnails Got Vette Wheels??...Post pics here...!-0604011403.jpg   Got Vette Wheels??...Post pics here...!-0605011620.jpg
Old Jun 5, 2011 | 11:11 PM
  #415
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
O and its Lowered on sportlines. Think you were at 3rd gen fest. It was there
Old Jun 9, 2011 | 02:50 PM
  #416
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Frickin' sick. Hands down, the best looking combo I've seen. Looks like they're SUPPOSED to be on the car. C5 Deep Dishes FTW.
I wonder about the rear spoiler....is it stock or is it a bit taller? Seems to be taller....but can't see it very well. I like it.
Originally Posted by Z28FAST1
Measurements are posted above per OE Wheels. I only have these pics from my phone for now.
Old Jun 12, 2011 | 08:38 PM
  #417
RPOL98's Avatar
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
repro 17x9.5 C4 wheels w/ 275/40/17 Sumitomo's.
Old Jul 17, 2011 | 01:50 PM
  #418
slow305's Avatar
Car: 1982 Z28
Engine: LC9
Transmission: AR5
C5 Z06 wheels and the 2" Skulte spacers with 295 Toyo T1Rs on the rear, 265s on the front. No rubbing although my fender lips have been rolled.
Pat
Old Jul 19, 2011 | 08:18 AM
  #419
Transmetal's Avatar
Car: 89 Trans Am GTA
Engine: 5.7 350 TPI L98
Axle/Gears: Borg-Warner 3.27
2" spacers, black C6 Z06 17X9.5" with Hankook 275 40 17 tires.
Old Jul 21, 2011 | 07:51 AM
  #420
tmroesle's Avatar
C6 powder-coated black
Old Jul 27, 2011 | 11:14 AM
  #421
bigdavesiroc's Avatar
Car: 87 iroc
Engine: 410 sbc
Transmission: tremec 3550
Axle/Gears: 30 spline 3.73
when i had my set up, my 285 almost rubbed on inner fender well. i could of used like 2 1/4 spacers. my dts 12 bolt is a little narrower then stock. 315 would be to wide of a tire for 17x9 also. tire would look like a fat roll hanging over the rim.
Old Jul 27, 2011 | 12:54 PM
  #422
Demon355's Avatar
I've seen 315's on these rims and it was just fine actually. No major tire buldge, just a little bit. If they are indeed bad, I will either find a set of 275/40's or just buy ZR1 rims
Old Aug 15, 2011 | 11:04 PM
  #423
jliroc's Avatar
Car: 1990 IROC Convertible
Engine: 5.7 TPI, L98 Heads w/roller rockers
88 third gen, so you have 3 inch spacers in the rear and what in the front? I just got a set of stock c6 wheels and am about to bolt them up but need spacers. Just want to know the best ones to get. 1990 iroc convert stock height. Thanks man.
Old Aug 16, 2011 | 07:16 AM
  #424
Transmetal's Avatar
2" spacers will probably work for ya.
Old Aug 18, 2011 | 11:31 AM
  #425
C-Titan's Avatar
Car: 91 Z-28
Engine: 360TPI
Transmission: PA Racing 700r4
Axle/Gears: 3:73
Old Aug 18, 2011 | 11:54 PM
  #426
1991 Z28's Avatar
Car: 1991 Camaro Z28
Axle/Gears: LS1 3.23
Anyone have these corvette wheels on their thirdgen?
Got Vette Wheels??...Post pics here...!-oe-vette-zo7-c
Old Aug 19, 2011 | 06:41 PM
  #427
jliroc's Avatar
Just installed today!
Attached Thumbnails Got Vette Wheels??...Post pics here...!-photo-4.jpg   Got Vette Wheels??...Post pics here...!-photo-3.jpg   Got Vette Wheels??...Post pics here...!-photo-1.jpg
Old Aug 22, 2011 | 06:30 PM
  #428
Boreen's Avatar
Finally got my car back, and got my new C6 Z06 wheels installed (18's with 245/40's all around). I wish i went a little fatter in the back but these are gonna do for now. I went with 2" spacers all around to and its close on the front, but no rubbing.
Now, i have a bigger gap in the back than the front between tire and fender lip so i need a lowering kit, but dont wanna go to crazy on price or a huge drop. Also, will lowering it make my tires come closer in the front at full steering lock?
BTW, How do i post a picture?
Old Aug 23, 2011 | 09:00 AM
  #429
Transmetal's Avatar
Attachment 224313
Attachment 224314
Attachment 224312
^The guy above u does and I have em in black with a polished lip.
Old Aug 23, 2011 | 06:23 PM
  #430
jvaughn's Avatar
Car: 91 RS 305 TBI 5 Spd
Engine: 5.0 TBI
Transmission: 5 Spd
Axle/Gears: 323
18" all around with 2" spacers
Attached Thumbnails Got Vette Wheels??...Post pics here...!-2011-06-28-rudys   Got Vette Wheels??...Post pics here...!-250093_227057053987752_100000503767471_949194_1200506_n.jpg   Got Vette Wheels??...Post pics here...!-253593_227057133987744_100000503767471_949200_1797484_n.jpg
Old Aug 27, 2011 | 06:08 PM
  #431
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
Transmission: Megaraptor
ok, ive gone through this whole thread, as well as the post you z06 wheels thread and search button and have not found my answer. please help
Is anyone running the stock C6 Z06 rims on a third gen.
They are 18x9.5 and 19x12. will they fit.
those guys running the 19x10 c6, is there any more clearance in there??
I want to change out my current c5 setup
[IMG][/IMG]
Old Aug 27, 2011 | 06:22 PM
  #432
jvaughn's Avatar
Engine: 5.0 TBI
Transmission: 5 Spd
Axle/Gears: 323
Yes they will fit, you will need 2" spacers all around. The rears will be tight, but should clear. I have 18" C6 replicas and I have plenty of space.
Old Aug 27, 2011 | 09:54 PM
  #433
jliroc's Avatar
Not sure, I just got done installing factory c6 wheels on my car with 2.5 inch spacers on the back and 2.25 inch spacers on the front. The rears just barely cleared and the fronts were ok. 2 inch spacers in the rear would not work for me at all. That's with 19x10 rears 19x 12 I'm sure would need some crazy 3.5 or 4 inch spacer which is crazy, would work much easier if you have a fourth gen rear end to start with. In my opinion, stock c6 z06 wheels will not work on a stock third gen. Would look badass though!!!
Old Aug 28, 2011 | 12:10 AM
  #434
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
does anyone know if C6 z06 rims fit on a 4th gen??
the oem size i mean. 19x12 rear
Old Aug 28, 2011 | 03:31 PM
  #435
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I would be really surprised if 19x12s fit. I think I only have an extra 1-1.5" inches between my 19x10s and the inner fenderwell and the wheels I have are flush with the fender.
A 4thgen rear makes it a bit more difficult I think, I still have to run a 1" bolt on spacer so the wheels don't hit the inner fenderwell. 3.5-4" spacer even on a thirdgen rear would put the wheels outside of the fenders...
Old Aug 28, 2011 | 03:36 PM
  #436
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
never in a million years will they fit without sticking way outside the wells. I have 18x12's on my 86 and they needed a minitub to clear properly and sit properly int he wheels wells.
spacers dont magically make the car wider....
Old Aug 28, 2011 | 03:48 PM
  #437
jliroc's Avatar
spacers that size are nuts anyways
I already feel that over 2 is alot, I'm gunna fix that asap.
Old Aug 28, 2011 | 03:49 PM
  #438
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
thats what i was thinking. i was hoping someone here had actually tried them or had them on and could explain what they did.
im getting a good deal on these rims, but i dont want to spend the money and have them not fit.
hopefully i can find someone locally to try them out.....
Old Aug 28, 2011 | 08:02 PM
  #439
Kraz-z's Avatar
Car: 91 z28
Engine: 305 tpi
<a href="http://s1181.photobucket.com/albums/...27_1605311.jpg" target="_blank"><img src="http://i1181.photobucket.com/albums/...27_1605311.jpg" border="0" alt="Photobucket"></a>
Old Aug 28, 2011 | 08:03 PM
  #440
Kraz-z's Avatar
Car: 91 z28
Engine: 305 tpi
Old Aug 29, 2011 | 08:25 PM
  #441
1987CamaroZ28's Avatar
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
Axle/Gears: factory 9 bolt with 3.45 gears
Originally Posted by keeslinger31
I got vette wheels too!
Ths looks fantastic.
Old Sep 2, 2011 | 10:05 PM
  #442
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Originally Posted by 396l35
Here is some pictures of my 87 with 96 Grand Sport wheels...
And the money shot...
Damn that looks good.............Love the money shot...Those tires look so tight from the back....WOW
Old Sep 3, 2011 | 01:32 AM
  #443
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Hey gang quick question, What is the name of these wheels and what trim was it avail on Corvettes?
Here are the wheels:
http://cgi.ebay.com/ebaymotors/17-18...item2556a42746
Really digging these wheels and are a option for me right now. Please let me know if anyone is running these im in love with these wheels at the moment.
Old Sep 3, 2011 | 05:43 AM
  #444
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
They came on newer Zo6 corvettes (I think '09+). They're called the "spyder" wheel. I think in black/gunmetal they look AMAZING and I'd love to run them but no aftermarket company makes them in sizes large enough for me yet.
Old Sep 3, 2011 | 07:24 AM
  #445
3318RS's Avatar
Car: 1990 RS
Transmission: Built-700R4
Originally Posted by jaygt
i have another exact same set i want to use on my 89 formula. im hoping i can use a 295 on this wheel. what width wheel do you guys normally use with a 295.
The 295's tire size came on the rear of the C5 Z06 from the factory. The wheels were 17x9.5 & 18x10.5 (OEM)
Again the tires were 265 up front (odd size) & 295 in the rear. I hope this helps.
Old Sep 9, 2011 | 08:27 PM
  #446
humalag's Avatar
my piece of junk, was thinkig of c6 standard wheels, but got this ones for $200, with goodyear tires...
gr2's and eibach's waiting for my day off,
Old Sep 26, 2011 | 11:43 PM
  #447
caffeine's Avatar
Car: 89 Firebird Formula
Engine: 3500T
Axle/Gears: 9 bolt/4.11
Got some 17" Z06 wheels on my car with 2" spacers all around. Looks nice in this pic with the car freshly washed. Good thing you can't see the clear coat peeling on the roof and hood :P. Front's lowered as far as it goes with Spohn coil-overs and rear is stock height.
Old Sep 27, 2011 | 02:36 AM
  #448
Fords88Bird's Avatar
Car: '88 Firebird Z20
Engine: 305 TBI w/TBI mods
Axle/Gears: Stock
The ZO6's look nice on there, just got to bring it down some. Can't believe that's all the drop you got from coil overs. Later.
Old Sep 27, 2011 | 02:42 AM
  #449
caffeine's Avatar
Engine: 3500T
Yes I really think they suit 3rd gens. As for the coil-overs I was disappointed a little as well but I guess it could be that the front-end is lighter than stock after my engine swap. I'm planning on getting some drop spindles and/or shorter/stiffer springs from QA-1 (which is the brand of the current springs) and also some coil-overs for the rear.
Old Sep 27, 2011 | 03:00 AM
  #450
Axle/Gears: Stock
Just get some new Moogs and cut to height and be done with it and cheaper too. Later.
