Got Vette Wheels??...Post pics here...!
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Re: Got Vette Wheels??...Post pics here...!
Amazing looking car Thomas!
Bump for an excellent thread. I just bought a set of stock C-5 Polished thin spokes 17/18's for my 91 Z28.. Seems the consensus is that 2" spacers front and rear work well for this application? Car's suspension and drive train is all stock, with no plans to lower it, change calipers, brakes, etc.
2" on all 4 seem to be correct?
Car: 2008 C6 / 1982 Trans Am
Engine: LS3 / Hybrid LS1-406 SBC
Transmission: 6L80 / 4L60E
Axle/Gears: 2.56:1 / 3.23:1 4th gen Posi
Car: 1986 Z28/1984 Z28
Engine: 350 TPI/305 HO
Transmission: 700r4/TH-350
Axle/Gears: 3.23/3.42
Car: 86' IROC-Z
Axle/Gears: 3 sumthin
I finally got my C6 wheels on. 2" spacers up front, 2.5" in back. With the stock corvette size tires. I still have the stock springs in too. All I had to do was beat in the front part of the rear fenderwell with a hammer.
It's amazing how our cars make bigger rims still look small. And this winter I'm going to take off the gold decals.
Hi!
Looked through all the posts and does nobody have this combo ?
255/50R16 rear
245/50R16 front
some sort spacers used.... just bought it and havent chance to investigate all ....
255/50R16 rear
245/50R16 front
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I posted a friend's Camaro with those wheels a while back, with a little searching I might find it.
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
I'm betting that those aren't a really popular choice on these cars. In fact that's the first one I've ever seen with them.
Anyone else? I´d like to see how this car coud look with these wheels. I do not have the budget to buy any other wheels(car itself cost me 3000dollars).
So dig in your pile of photos and post them.
Car: 91 Z28 Convertible Camaro
Axle/Gears: Borg-warner 3:27 gears
Heres a picture of my 91 camaro fineally got the rims put on this past saturday. Im using 2 inch spacers all the way around with 245-45-18 and i dont have any issues with these.
Car: camaro84.87iroc,91vert
Engine: Lt1, 383tpi,350tbi
Transmission: t56,T5,T5
Axle/Gears: 4thgenunknown,373,323?
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
Awsome looking car though all it needs now is for you to lower it.
Tony.
thanks, I got the rims off ebay for like 500 shipped so they were not to exspensive and they look amazing in person.
I was thinking about lowering the car but it low enough for the roads around here,plus i have air shocks in the back so i can atleast lower the back at any time....lol
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
Rims 18x10.5 replicas with 56mm offset.
Tires 315/30-18 Hoosier A6.
2" spacers all the way around.
Relocated rear bump stop (just the driver side for now), increased the steering stops to keep the rim off the control arm at full lock, rolled the quarters, hammered the rear inner fender wells, and did some minor work to the fenders.
I love it!
Car: 3 1969's and original owner 1987
P315/35R17 on 17x11 with a 7.8" back space and 2" spacers. P275/40ZR17 on 17x9.5 with a 7.1" back space and 2.25 spacers but I think I have to push it out another .25" so I dont hit the drag link. No rubbing in the rear and slightly touching the inner fender in the front with stock suspension. The wheels were listed as 17x11 50mm and 17x9.5 53mm if you dont want to convert from metric. I hope this helps, Mark
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
So if I'm understanding all of this... For the C5/C6 wheels (or the ZR1 style as many of you have), you simply need at least a 2" spacer on the front and a 2" on the back if you've got a stock rear? If you have a 4thgen rear, you only need the two front spacers?
Car: 1989 TA
Engine: 305, 5.0
I had to use a 2.25'' in the rear and it still hits on little bumps and hard cornering. I just got them on and i will have to bang the inner wheel well to make it better. I used 2'' on the front and i can turn my wheel all the way and no rubbing at all.
Car: '91 TA vert
Engine: turboLSx
I have a 4thgen rear and 1" spacer and they're perfectly inline with the fenderlip. I'd go more than a regular 2" with a stock rear.
Car: 87 iroc z28
Engine: 89 C4 TPI ,
Transmission: ZF6 speed , 89 C4
Axle/Gears: 89 corvette rear end
89 Vette wheels would look good in flat silver and coverd lugs ,remember them.I think I you needed a 2inch spacer,with separate lugs. I still have the spacers somewhere $650!! at the time, custom made....
Car: 87 iroc z28
Engine: 89 C4 TPI ,
are they legal to stick out that far!!!don't lower it or you will lose your fenders!!!
Car: Trans Am
Engine: 383 Accel ProRam single plain EFI
Transmission: t-56 Spec #3
Axle/Gears: 4 gen 3.73:1
front have 1.75 spacers, left rear w/o spacer, right need 0.05'' spacer but i have 4gen rear
Car: '91 TA vert
Engine: turboLSx
I want to see gunmetal ZR1 wheels.
Mine's lowered 2.5" inches. I'd drop it a bit more but fenderwells are smaller on 'verts than coupes.
Car: Trans Am
Car: 2001 Camaro SS
Engine: no engine yet :)
Transmission: T-56 with z06 drive gears
Axle/Gears: most likely 12 bolt or 9" with 3.91
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
Axle/Gears: disk rear, 10bolt.
mine has 2.25 front and 2.5 rear, 18/10 wheels getting ready to drop it as soon as i get time
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
17x8.5 /18x9.5, 2"spacer on rear, 1.7" spacer up front, I have C5 brakes on the front, thus the need for the thinner spacer. Dean
Car: '91 TA vert
Engine: turboLSx
Car: '91 TA vert
Engine: turboLSx
Car: 2001 Camaro SS
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
Car: Trans Am
Engine: V8 350 TPI
Im selling my BRAND NEW C6
https://www.thirdgen.org/forums/exte...eels-sale.html
Car: 90 Camaro RS
Engine: 6.3L 383 V8
Couple pics of mine with C5's. Honestly, I think stock 16 IROC's are the best looking. Saw a dude on here that had powdercoated some black, they were awesome!
Car: '88 Formula
It kind of copies it. I got it from Fiber Concepts in PA.
http://www.fiberpartsconcepts.com/1289627.html
The fit is OK at best, it isn't bad for a race car and I'm sure someone with more body work skill could make it look better. I'm not disappointed with, but pickier people may be.
I did,, by the way this is my 1st post on the forum
I have just installed them very recently ,, they look cool but I'm still trying to get used to them though, these are ZR1 replica Set, 19x10 285.30.19 rear & 18x8.5 255.40.18 up front, the next available size was the 20/19 combo, the rear is 12'' wide which was almost impossible to fit,, so had no much of the choice but to go for 19/18, I still think the 20/19 set would had looked even much nicer.. anyway here is the link:http://www.cardomain.com/ride/444784/1
what do you guys think?
For some reason, it was not as good as I thought it would be. Looks similar to pwdbychevys style rims, and I actually like his better.
Car: '91 TA vert
Engine: turboLSx
Car: 92 camaro
Engine: stroker
Transmission: Megaraptor
http://www.corvette-wheels.com/media...f/i/file_1.jpg
http://www.corvette-wheels.com/media...d_face_1_2.jpg
http://carphotos.cardomain.com/ride_...0356_large.jpg
Can someone please photochop the vette wheels in the first pic (or second) to dbernalz's white camaro in the second pic.
Sorry i borrowed your car, but my car is in the shop and yours is the closest i can get to mine.
