for those who have 18's on camaro
Car: 1989 Camaro RS Convertible
Engine: Need help identifying
i wanna get these rims on my 89 camaro
http://wheelstudio.com/catalog/produ...-40r18&t2=&t3=
i was wondering what size tires do i need to get if i'm gunna get 18's
i know the rear ones are bigger
but does it have to be the rim or the tires???
thanks....
thanks....
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: for those who have 18's on camaro
they look fine, but 7.5 is pretty narrow. I would go larger, at least 8" in the front, maybe wider in the rear. The site gives no info as far as fitment, bolt spacing ect.
so should i get bigger rims for the rear or just tires
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
It would look better if you get wider tires in the rear then in the front i think that is what he is saying
would i have too get wider rims then??
for the back ones?? or just the tires and same size rims??
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
I think you would have to get both wider tires and rims in the back then in the front
Car: '91 camaro z28,imsa widebody
Engine: 383 ci l98,lt1 induction
Transmission: race built 700r4 , ratchet shifter
Axle/Gears: 342;1 detroit true trac diff
hi ya . im running bmw M6 rims on my z28 they are 8.0 front, 9.0 rear. with 265/30/19 and 295/30/19. the trick is to workout the same rolling radius to keep the speedo correct. this is why ive gone 30 profile tyres. plus 295 tyres are the largest you can go before you stick out the arches, which aint cool!!!!
Car: 91 Z-28
Engine: 360TPI
Transmission: PA Racing 700r4
Axle/Gears: 3:73
I would keep searching for wheels with a larger width, 7.5 just seems way to narrow... I'm running 18x8.5's on all four corners with a 235\40 up-front and a 255\40 out back... the thing has grip for days...
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
You can use 18x9.5 on all four corners with a 6in back spacing. My tires are 275/35/18front, 285/35/18rear. All the tires are inside the fender well and the car has 2in drop springs.
[IMG][/IMG]
[IMG][/IMG]
Car: 1988 Camaro Iroc / 1989 Firebird TA
Engine: Camaro 350 cid / Firebird 305 cid
Transmission: Soon T56 D&D Viper (WC T5) / WC T5
Axle/Gears: 9 bolts; 3.45>3.89 / 10 bolts; 3.08
VincentZ28, did you run with adapters or spacers on 4 corners with these 18x9.5" rims with 6" back space?
1 Post
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
Buy the same size tires for all 4 corners. This way you can actually rotate the tires. Be sure to get an alignment.
1 Post
Car: 88 GTA/86 C20 Burb/91 325i
Engine: L98/454/M20
Transmission: 700R4/NV4500/Getrag
Axle/Gears: 3.27 9-bolt/3.73 14 Bolt/3.73 IRS
Don't go narrower than an 18x8" rim on the front. That's what I've got on mine, and it's just enough to run a 245-40-18. You might be able to cram a 255 series on it. IMHO, anything narrower would not only look silly, but wouldn't put the rubber to the pavement you're going to need with such a stiff low profile tire to stick.
-Levi
-Levi
Car: 91 Z-28
Engine: 360TPI
Axle/Gears: 3:73
-Levi
-Levi
For some reason, up front, I was having issues running a 245\40\18... I couldn't fully turn the wheel without rubbing immensely on the fender well...
Car: 89 RS Camaro
Engine: 350 ci
Axle/Gears: 3:42
If you really like those rima just go 245/40 18 on the front and widen the rears plus 2.5" and put 295 /35 18 on the rears and you have a good look and road holding!
I did this to my car!
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
thanks....
thanks....
1 Post
Engine: L98/454/M20
That's odd C-Titan... What is the offset on your rims? Mine rubs a smidge at full lock, but that's because I'm missing a few clips for the inner fender that I haven't gotten in yet. Mine's a 3mm offset rim. You're supposed to be able to fit up to a 275-35-18 under the front fender before problems are encountered.
-Levi
-Levi
Car: 91 Z-28
Engine: 360TPI
Axle/Gears: 3:73
-Levi
-Levi
The wheels are 10 mm in the back and 5 mm up front... I wanted the front wheels to be dead flush with the lines of the front end and the side-skirts... Had to massage the dust caps just right to keep the center caps on... I dont know why I needed them flush tho but I just did, ... Gives the whole line of the car a nice clean\mean look IMO...
You can kinda see what i'm talking about in this pic... Keep in mind this was before the car was painted...
P.S. Dig the wheels you just put on your Formy... They look mean as hell, perfect match...
1 Post
Engine: L98/454/M20
Yeah,
Those plastic inner fenders should go between the ground effects and the fender. A lot of the cars that I've seen them on had them running outside of the fender AND the ground effects, not how it should be done. A lot of the rubbing problems can be addressed just by attaching them correctly. If you've still got issues after that, a little heat gun might be necessary, but I don't see why as you've got almost the same exact setup as me.
I like the flush mount too, it's the only reason I decided to run a spacer on the front of mine. It's a good temporary fix for now, It'll be set just about perfect when I do the C4 brake conversion next spring.
-Levi
-Levi
Car: 91 Z-28
Engine: 360TPI
Axle/Gears: 3:73
Word, mine are def. mounted properly on the inside - but wouldnt be surprised if i'm missing a clip or two... What kind of spacer are you running up front??
84z96L31vortec
08-20-2017 12:16 AM
