Whats the largest rim that will fit a 3rd gen?
Car: 1992 Firebird
Engine: L03 : \
Axle/Gears: 10 bolt
What is the widest rim that will fit a third gen with No spacers, no fender/tire contact problems, and the most modification being the use of a BFH?
I know nothing of wheel fitment, and I want to get the biggest 17 inch TT2's I can get on my car without spacers.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Whats the largest rim that will fit a 3rd gen?
a 17x10 should fit fine, want sometihng like 6.5" of backspacing. Shouldnt have any issues with fender rolling unless the car is lowered a lot
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
wheels that WILL fit? or biggest wheels that SHOULD fit? 17's. no bigger
Car: 1992 Firebird
Engine: L03 : \
Axle/Gears: 10 bolt
WILL fit. I know nothing of offsets, backspacing ETC. I know I want to buy a set of TT2's at the end of the winter and I need to know which ones to get. Tirerack can't help here. They're not selling them anymore
Car: 87 GTA
17" x 9"/5"bs front
17" x 10"/6" bs rear with BFH work 6" may also require tubular LCAs, for the extra bit of tire clearance. 5"bs out back is a no brainer, no mods, direct fit.
But don't be scared to do what you need to get what you WANT to fit.
Car: 1988 Pontiac trans am
ha!, i found this post through google , as i was looking for an answer to question mentioned by mikey , anywho , so if 17 is the biggest you can go , whats the widest you can go without mods to the rear section of a 3d gen , i was looking at weld rims and i liked the weldstar , if possible i would like to get the rears with the big lip and i would like them wide , whats the widest i can go , and if possible , anyone know who else makes 5 spoke start rims like weld ?
Car: 1985 Camaro Sport Coupe
Engine: 355cid
Transmission: TH350
Axle/Gears: 3.73 Open Rear
Birdstheword909-
Jeg's has a Weld style 5-star wheel and is available with 15x10 w/ 5.5 BS good for up to 12"+ tire int eh back with minimal or no trimming.
thanks c10crewchief , i took a look at them , i like them but do you know if they have the big outter lip , like the rear weld stars?
Car: 1982 Z28, 1983 Z28
Engine: 5.7L 530hp, 5.7L 430hp
Transmission: TH350, 700R4
Axle/Gears: Ford 9", 10 Bolt 3.23
So 18x9 front and 18x10 rears are no good for straight swap?
Car: 88 TPI formula
Engine: L98 Vortech
Transmission: TH700r4
P265/50R15 and they don't seem to rub. Prev Owner had them on there, and I'm growing used to the old school look. It would appear they would rub if pushed up far enough? If someone is seriously interested in knowing I can look at my tires again for rub marks but I didn't notice any last time I looked.
Car: 91 Z-28
Engine: 360TPI
Transmission: PA Racing 700r4
Axle/Gears: 3:73
I have had stock P235/60/R15s, P245/45/R17s, and I am gonna assume as long as the math lines up with whatever size you put on, they will work as long as bachspacing is good.
It looks like P235/35/R20's with an 8" width wheel would fit in the same space as the above wheels being a total of only .4" bigger in diameter total. My vehicles rides at stock hight, so I don't see any issues with that. Only thing at this point is the back spacing.
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
i just threw on some ford anthracite FR500 17x 10.5" rims with 315/35/r17 sumoto tires on my rear without any issues... they have 6.8" backpacing. +1.10" positive offset. but this wont work on yours. right now i have ok clerance but im waiting to drop the car to see how they really fit. im running a ford 8.8" tho which is 1.5" wider in each wheel well than the stock rear.
http://www.americanmuscle.com/deep-d...l-17x10-5.html
Well I have an 82 with a Ford 9" rear as well. This is why I was looking at 5th gen Camaro wheels. I think I can get a set of them on the rear without spacers, however the fronts would require some.
Car: 92 RS, 02 SS leather seats, eibach
Engine: Stock 305 at the moment.
Transmission: Stock M5.
I run 18x10 on the rear with about 6 inches of BS. Fronts are 18x8.5.
Car: a red 86 camaro z28
Engine: 5.7 350 tpi
Transmission: i think 700r4
Axle/Gears: limited slip possibly
depending on ride height, 17x11's fit, and with the proper backspacing you dont need spacers. You may have to do a little more than just hammering, you probably wont find the correct backspacing though, would be 7 or 7.5. You will most likely have to cut off the bumpstop area and maybe need tubular control arms.
is that in the front? i have a set of 15x 8 and i was wondering if theyd fit on the front wid no modifications
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
I am planning to get a pair of the wheels widened to 11" as a demonstration, by adding another 1.5" inside (will be 6.6" BS) - which will just clear the control arms (maybe not), will require removal of the bumpstops, and perfect alignment of the rearend with an adjustable PHR, and possibly some sheet metal massaging.
Car: 1986 camaro
Engine: 305 4barrel
Hello I was going through and I want to know if I can fit a P275/40R17 in all four corners with out any modifications and with no problems I have a bone stock 86 sports coupe Camaro with P215/65R15 and I want to put the fattest tires I can with out changing the size from front to rear thanks
Yea I don't see why it wouldn't work for you. I have 20inch rims on the back and 18imch on the front.
You should only put the 275 on the back and stick to a smaller size on the front.
Car: 1992 Camaro RS
Engine: 402 LS
Transmission: RPM 4L65
Axle/Gears: Moser 9" ~ 3.50:1
Would a set of 17 x 9 rims fit with 6.75" of backspace?
Any help is greatly appreciated.
Car: 1992 Camaro RS
Engine: 402 LS
Would a set of 17 x 9 rims fit with 6.75" of backspace fit a Third Gen with 1.5" or 2" spacers?
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
If you go to a 18x10.5, the wheel should clear the steering knuckle and fit a 295 tire. just keep your overall tire diameter under 26".
17x9 will fit easybut I'm not sure on that backspacing but it sounds too deep. What wheel is it? 4thgen wheels and c4 and newer vette wheels are 2" deeper than thirdgen wheels and can be mounted with 2" bolt on spacers. If you really like the wheels you're considering and they are priced right you can always buy some bolt on spacers to make them work. A little measuring goes a long way! it needs to clear the steering knuckle and the strut.
Car: 1985 IROC Z
Engine: 305 TPI?
Axle/Gears: 9 bolt 3.08
275-305/50r18 for the rear end? I'm going to put my rears up front so I need a new pair of rears. I'm hoping to use 50r18 for the rears to give it the muscle car rake. I haven't seen anyone mention this size yet.
Will that work? I'm hoping for 255/50r17 front then 275+/50r18 rear. Maybe a on a 4th gen rear axle too. Wheels are gonna be a set of American Racing TorqueThrust II.
Car: 87 TA clone
i got 275/45/18 on all four corners. C6 reproduction 18x9.5s. Rear is ford 8.8 but it's spaced out for 4th gen width. Like the tires a lot actually. Just enough sidewall to help with road bumps etc.
305 will fit but u need to verify wheel backspacing etc. I'm also lowered on vogtland springs in the pic
i had 315 35/17 on the rears for a couple of years and it was ok. Not worth it if you don't want the headaches associated with wide tires. But I have contemplated going with 18x10.5 and a 305/315 version on the rear. I had trimmed the rear bump stop already but 1" closer to the frame would be tight!
Car: 92 Camaro RS
Maybe you don't understand how tire sizes work.
275 - width of tire in mm (millimeters)
40 - means the sidewall is 40% as tall as the tire is wide. So it will be shorter on a 225 and taller on a 305 regardless of rim.
R17 - 17" Rim.
Search on tire rack and look at the specs of the tires. It will tell you the over all diameter. A 50 series would be pretty tall in any of those sizes.
Car: '85 Camaro
Engine: LG4
Transmission: 4L80E
Axle/Gears: 3.42:1
Tire Rack is a dud anyway, they won't sell you anything their "book" doesn't say fits. Until they see it themselves, in their own shop, or have an OE spec, it's no sale. They used to let you cheat if you claimed it was a "kit car", probably not anymore. I learned this the hard way helping a friend with a Fiero. We ended up tucking 17x8s up front and 17x9s under the back, on 235/40s and 265/40s, and we posted pics, but Tire Rack called him a liar.
Street Lethal
Apr 30, 2019 12:14 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
