19" Axis Hiro
Old Nov 22, 2009 | 02:44 PM
Alain2's Avatar
Car: 1991 Z28
Engine: 5.0
19" Axis Hiro
I had those wheels on my 350Z, I sold it this summer and kept the wheels. The specs are:
Front wheels:
19 x 8.5
offset 20 mm
tires 245-35-19 BFGoodrich g-Force T/A KDW 2
Rear wheels:
19 x 9.5
offset 25 mm
tires 285-35-19 BFGoodrich g-Force T/A KDW 2
I was thinking I could buy 1" adapters. I took some pics with a rear wheels in place to see what it would look like. It is very aggresive, what do you think?
Attached Thumbnails 19" Axis Hiro-20091122_14m.jpg   19" Axis Hiro-20091122_08m.jpg   19" Axis Hiro-20091122_07m.jpg
Old Nov 22, 2009 | 03:49 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 19" Axis Hiro
spacers could work, but im sure the bolt pattern is different, so they would have to be adapters. Are you sure you only need a 1" spacer?
Old Nov 22, 2009 | 03:58 PM
Stephen's Avatar
Car: 87 GTA
Re: 19" Axis Hiro
I'd ty 3/4", but not sure how thin adapters could be made. If the wheels/tires hit, sheetmetal can be moved.
Old Nov 22, 2009 | 04:50 PM
Alain2's Avatar
Car: 1991 Z28
Engine: 5.0
Re: 19" Axis Hiro
The bolt pattern is different so it would be adapters, not spacers.
They make 0.75" adapters, but I will have to cut the wheels studs. I'm not sure I want to do that because I want to be able to switch to my stock wheels.
With 1" adapters I don't have to cut anything.
Old Nov 22, 2009 | 05:00 PM
Blind Driver's Avatar
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
Re: 19" Axis Hiro
I wouldn't do anything that would space those wheels out any further.
Old Apr 20, 2010 | 12:40 PM
Alain2's Avatar
Car: 1991 Z28
Engine: 5.0
Re: 19" Axis Hiro
Here we go!
1" adapters.
Old Apr 20, 2010 | 06:02 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: 19" Axis Hiro
how 'bout a shot of how far they stick out? or are they about where they were inthe earlier pics?
looks good though
Old Apr 20, 2010 | 06:45 PM
Alain2's Avatar
Car: 1991 Z28
Engine: 5.0
Re: 19" Axis Hiro
It doesn't really stick out. I like it.
Attached Thumbnails 19&quot; Axis Hiro-20100420_01_01m.jpg   19&quot; Axis Hiro-20100420_04_01m.jpg
Old Apr 20, 2010 | 06:50 PM
Stephen's Avatar
Car: 87 GTA
Re: 19" Axis Hiro
Looks like you would benefit from an adjustable Panhard Bar though.
Seems to be offset to the Driver's side.
Old Apr 24, 2010 | 01:39 AM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Re: 19" Axis Hiro
Looking good, hows the fitment on the front?
Old May 2, 2010 | 02:48 PM
530transam's Avatar
Re: 19" Axis Hiro
looks great but if it were me, i would lower the car about another inch. "lips were made to be kissed"
Old May 23, 2010 | 01:22 PM
Alain2's Avatar
Car: 1991 Z28
Engine: 5.0
Re: 19" Axis Hiro
Here is the front fitment. Just perfect.
Attached Thumbnails 19&quot; Axis Hiro-20100522_25m.jpg   19&quot; Axis Hiro-20100522_33m.jpg
Old May 29, 2010 | 04:24 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: 19" Axis Hiro
I have to admit that when I read the title and saw 19" wheels mentioned, I cringed a little, but those actually look very good on there!
MASON1259
Wheels and Tires
Dec 16, 2013 07:27 PM
EagleMark
Dec 13, 2011 11:40 AM
JeremyNYR
Members Firebirds
Jul 23, 2009 03:18 PM
iiiluckyboyiii
Aug 24, 2006 04:05 PM
Mangus
66
Dec 26, 2005 07:46 PM
