How big of tires will fit my formula??
Old Feb 4, 2010 | 05:45 PM
keith#55's Avatar
Car: 92 Formula
Engine: stock 350
Ive been wondering how big of tires can i fit on my car. I dont know cause i am buying new tires for my car (92 formula) this spring when it comes out of storage....anyways i want to know if i can put wider tires on it without having to mess with spacing, etc. cause i dont want to put skinnier tires on the rear end (breaks loose too easy as it is lol) maybe less wide in the front and wider in the back? it has p245 50zr16's all around on it right now..thank you
Old Feb 9, 2010 | 10:34 PM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
Re: How big of tires will fit my formula??
im thinkin a 255/50/16 is as big as your gunna get on a stock wheel.
Old Feb 9, 2010 | 10:58 PM
firebird1992's Avatar
Car: 1992 firebird
Engine: V6
Axle/Gears: 10 open 3.42
yea that's the biggest on the 16in rims
Old Feb 16, 2010 | 02:01 AM
keith#55's Avatar
Car: 92 Formula
Engine: stock 350
Good news! I didnt think anything bigger would fit, this will save me the headache when i buy'em.
Old Mar 1, 2010 | 08:58 PM
Vortec_Formy's Avatar
Car: 89 Formula/94 z28
Engine: Vortec 350/ LT1
Transmission: WC T-5/ 4l60e
Axle/Gears: torsion posi 3.23s/auburn posi323s
my friend runs a 295/50/16 on his 90 formula with no problems, I'm going to run the same thing and he has them on the stock 16x8 wheels. well in the back only and 245's in the front. And kewl to know I'm not the only keith on this forum
Old Mar 2, 2010 | 11:28 PM
keith#55's Avatar
Car: 92 Formula
Engine: stock 350
Oh wow! I might have to look into that. That would help a lot when i go to the track.. ive tried just rolling up to the lights and ive tried warming up the tires before i get there and they always break loose when i launch... but wait, would that big of a tire fit without rubbing the wells? or when your turning? like i said i dont really want to mess with spacers or anything.....but yea i didnt think it was that common of a name either
Old Mar 4, 2010 | 03:17 AM
are you stock height? his car is slammed and the only problem is when he turns hard but hiss car has the springs cut and he has it slammed so decently lowered or stock height will be fine
Old Mar 4, 2010 | 08:30 PM
keith#55's Avatar
Car: 92 Formula
Engine: stock 350
Yea everything on it is stock. Even the tires too.. (suprisingly).
Old Mar 4, 2010 | 08:53 PM
Stephen's Avatar
Car: 87 GTA
I ran the BFG 295/50R16's on my lowered 92 with zero rubbing problems, years ago.
Sadly, this is the ONLY pic I have of it, that een remotely shows it.
As far as tire choices go, there are several stock 245s. Some 255s. The a jump up to the BFG 295, for street legal tires.
Old Mar 4, 2010 | 09:37 PM
CrimsonDragon's Avatar
Car: 89 IROC - 85 Z28
Engine: 350 / 305
Transmission: 700R4 / T5
Axle/Gears: Stock
The 295's worked on ours as well but we had to pound on the inner fenderwells a bit.
Old Mar 4, 2010 | 10:12 PM
hey stephen, what lowering kit did you use on that camaro? if you still remember
Old Mar 5, 2010 | 10:39 AM
Stephen's Avatar
Car: 87 GTA
A free one, called labor & a 3.5" grinder!
Yes, I cut the stock springs. Use a thin, metal cutting wheel & don't overheat the spring, and it is perfectly safe.
I used a 5 gal bucket of water. Put the spring in it, with just enough sticking out to cut, yet no worries about the grinder getting in the water. The water dissipated what heat built up. Is that overkill(the water)? Probably. But doing it that way I KNEW the springs wouldn't get overheated & sag any.
Old Mar 5, 2010 | 04:43 PM
lol yea i currently have the springs cut on my formula but i'm running 245/50/16s, how many coils did you cut in the rear? I know I will need to raise my car back up.
Street Lethal
Apr 30, 2019 12:14 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
overdriv
Aug 20, 2015 03:52 PM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
