Will a 215/60/16 on iroc wheel look dumb?
Old Jul 8, 2010 | 02:26 PM
elano's Avatar
Car: 86 IROC-Z, 82 z28
Engine: 383 Stroker
Transmission: TH-350
Axle/Gears: 3.73 Torsen, 4.56 Auburn
I have an almost free pair of michelin 215/60/16s I am thinking of putting on my FRONT IROC wheels since my current 245s are bald. I currently have BFG 295/50/16s in the back right now.Would this look dumb?
Old Jul 8, 2010 | 02:29 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: Will a 215/60/16 on iroc wheel look dumb?
It wont look that bad. I have 215's up front becuase I also got mine for free. I can say that I dont like the way they look, but its not extremely bad. Next time your driving around and you see a taurus, look at the tires. Thats the size they use.
Old Jul 8, 2010 | 02:50 PM
elano's Avatar
Engine: 383 Stroker
I'm mostly worried that that skinny of a tire would look funny mounted on an 8" wheel. Like buldge at the bottom and get narrow at the top.
Old Jul 8, 2010 | 05:30 PM
HOBBS's Avatar
Car: 1982 Z28 (work in progress)
Engine: 305 cu -H-
Transmission: Metric 200 (blah)
Axle/Gears: 3.23's
If you can get the 215 to air up on the 8" rim it won't be very good for the tire it won't wear even, and will bead chafe because it's stretched too far...
Old Jul 9, 2010 | 01:15 AM
elano's Avatar
Engine: 383 Stroker
Dang. Thanks man, I guess I'll need to find something else. Any idea what the most common tire size for these? I need to buy used or cheap new ones temporarily. My 245/50/16s are trashed.
Old Jul 9, 2010 | 02:14 AM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
I run 245s up front just because I like the look of the wide tires and the hey help me have better traction and keep my car in contact with the road. I use 255s in the back because like I said I like the look of the wide tires but anything over 275 is ridiculous and they allow me to still do decent burnouts. When I first saw this I thought if you were asking if you should put 215s on the back which would not only look wierd but every time you stomp the gas you would leave behind about a half tires worth of tread. They put 215s on the back of V6 04 mustangs because anything more and they would not be able to spin the tires I know because my mom has them.
Old Jul 9, 2010 | 11:28 AM
elano's Avatar
Engine: 383 Stroker
Haha, nah I have 295/50/16s on the back now. Just need to find a pair of good cheap tires to mount on the front for the time being. I had an allignment issue that ate them up.
Here's what the car looks like now
I just don't want it to look goofy. What about a 225/60 up front?
Old Jul 9, 2010 | 12:20 PM
built91Z28's Avatar
Here is what they look like. They went on easy. I didnt have to stretch them or fight with them to get them to bead so there is no safety issue with them. They basically sit even with the rim and dont bulge out or in.
Old Jul 9, 2010 | 01:22 PM
HOBBS's Avatar
Engine: 305 cu -H-
Axle/Gears: 3.23's
the 245's are the norm, or lay your fingers on some 235/55's, or 255/50's even going down to a 225/50 is going to be a bit of a stretch on 8" rims..
Old Jul 9, 2010 | 01:42 PM
88 5.7 Iroc-Z's Avatar
Car: 88 Iroc Z, 00 SS
Engine: 5.7 HSR, 5.7 LS1
Transmission: 700r4, T56
Axle/Gears: 3.23, 3.42
225/55 is what I had up front when I got them for free, the side wall will be the same width as your rim and look flat, doesn't look bad at all
Old Jul 9, 2010 | 05:49 PM
elano's Avatar
Engine: 383 Stroker
And those are 215/60s or 225/55s?? Those don't look bad at all!! The tread width looks wider than mine tho what tire is that? Also, THANKS for posting pictures!!!!!
Edit: Okay I blew up the pictures and read the numbers, it is a 215/60 goodyear. Thanks again man!!!!!!
Old Jul 9, 2010 | 05:52 PM
elano's Avatar
Engine: 383 Stroker
Sweet now I know another size I can use. Thanks!!!!
Old Jul 9, 2010 | 11:02 PM
Dont go any higher than 245 on the front because the 255s start to rub the well everytime you turn. I know becuase when I bought my IROC the front and rear was 255 and as I drove home from the dealership all I could hear were the tires rubbing. So now that I replaced them with 245s I got an extra set of tires for the rear! Can anyone say burnout.
Old Jul 9, 2010 | 11:15 PM
Stephen's Avatar
Car: 87 GTA
I've run 255s on stock 16" x 8"s and had no rub. I run 275s on 17" wheels w/5" bs and STILL don't rub. The bs is the key to making wide tires fit witout rubbing.
The 60s series of those 215s are why they fit. The tall sidewall allows the tires to "reach" the beads & seat good. But they are almost 1/2" taller, so watch for tire rub, especially on a lowered car or bumps/dips in the road & especially when turning.
Old Jul 10, 2010 | 01:06 AM
elano's Avatar
Engine: 383 Stroker
Thanks for the info!
I will get them mounted tomorrow and post a pic. I was actually starting to like the stagared look of the 295/50 rear and 245/50 front. Oh well, I'm only out $35 if I don't like these so I might as well try them.
Old Jul 10, 2010 | 08:07 AM
built91Z28's Avatar
Stephen is right that its the taller sidewall that allows them to fit. A 215/50 would not fit I dont think. I had the front of my car a little lower than stock, with no rubbing.
As far as 255's rubbing, you must have had either a tall sidewall, or the wrong back spacing as Stephen said. My brother has 275/50/15's up front and they dont rub.
Old Jul 10, 2010 | 04:45 PM
elano's Avatar
Engine: 383 Stroker
Well they're on, and I don't really think I like the way it looks. Something about the 60 sidewall makes it look goofy I think. I might put stock ones back on it. Here's pics.
Old Jul 11, 2010 | 12:04 AM
oscarsrs's Avatar
Car: 91 RS/ QX56/Altima 3.5 SE
Transmission: AUTO
Axle/Gears: ?
They look good and they were free! enjoy them and just save for your next set so you can get what you want.
Old Jul 11, 2010 | 12:01 PM
elano's Avatar
Engine: 383 Stroker
Yea, I'm now I'm starting to think they look okay. Thanks Oscars!
BlueIroc-Z
Jun 9, 2019 03:22 AM
NinjaNife
Aug 23, 2015 11:49 AM
kah992
Aug 19, 2015 02:55 PM
mustangman65_79
Aug 11, 2015 03:17 PM
