can smashed gta rim be fixed?
i will take a pic in the am but when i wrecked my rear end my rim hit a curb and put i prety deep dent into the lip of it. Could someone good with metal fix it? or is it toast. Its hard to find a replacement all the ones ive found on ebay are rears and since the previous owner had the rears in front and fronts in rear i smashed a front rim. Is there actualy a difference between the front and rear rims on the gta rims? gold with chrome lip. If i was to get another rear rim would it work with a front on the other side?
Car: 87 GTA
Re: can smashed gta rim be fixed?
You tell us....Is your wheel worse than any of these before (& after) pics?
www.wheelsamerica.com
That is the shop I used to widen 2 of my 9" wide Snyper wheels into 11" wide wheels!
its a little more caved in than the third down on the right of the photo gallery to the site u just posted. The shop that replaced my rear end said its toast and good luck finding a replacement.
Car: 87 GTA
Dented is nothing compared to missing chunks....
Shoot them a pic & ask. Both of mine were widened & powdercoated, in like 3 days!
well im trying to see what would be better money wise, if i can use a front and rear up front i can get a gold gta rim on ebay for 75 to 100 bucks. thats cheaper than it will cost to repair the rim.
Car: 87 GTA
Fronts fit the rear, but rears don't fit the front. The deeper bs causes the wheel to rub. Well.....If you use a spacer, they will fit & not rub.
thats how my mechanic said they were setup, i guess previous owner swapped them and put spacers for them to work. But if i use a front and a rear with a spacer will it throw off my handling? or will it bassicly be like it site right where a front would?
Car: 87 GTA
Are you saying a front on one side & a rear + spacer on the other side? Might have some alignment/pulling issues, since one wheel would be sitting further out on one side than the other.
Fronts on the back & rears on the front (with spacers) does look good. And rears can be picked up cheap all day.
yes that is what i am refering to. Because as u said i can pick up a rear cheap but when i do find fronts they want twice the price for them. If i could run a front and a rear with spacer up front i could solve the problem with less than 100 bucks if i need to get another front im looking at over 200 for one rim. Could a spacer be used on the front tire to get it to sit where the rear one would be from the spacer?
so the local shop said its to bad for them to fix withought it cracking. Its dented in and the lip curved inward into the tire. So the hunts for the cheapest solution is still on. I realy do not like driving this thing with a little doughnut on it.
Car: 87 GTA
Pretty much anything CAN be fixed, if you REALLY want it to be.
Talk to Wheels America. Yours sounds like less damage that the wheels in the I posted, that they have already fixed before.
Car: 87 GTA
Definitely worse than the first pic I posted, but look at the 2nd pic of the wheel they fixed. Have you asked Wheels America? Send them the pics & ask. Never know until you ask.
Guest
Posts: n/a
Impressive.
Well you can try contacting some other places, see if they'll touch it. The lip on mine was actually bent that bad, but the part closer to the spokes was not bent up like that. That may have been why they did not want to touch it but someone else may give it a go.
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
I have a set of front and rears sitting in my garage if you're interested.
Street Lethal
Apr 30, 2019 12:14 PM
Djmathis123
Sep 29, 2015 01:36 AM
