Help
Old Sep 7, 2010 | 03:34 PM
Road Rash Ninja's Avatar
Car: 1988 Chevrolet Camaro IROC-Z
Engine: TPI 350
Transmission: Beefy 700R4
Axle/Gears: Stock, don't have a clue
Help
I have a 88 Iroc-Z. But I have 15" wheels. Everywhere I'm reading says I'm supposed to have 16" wheels. I'm trying to figure out this whole rubbing til I stop when going slow. Meaning, I can turn until my tire is locked due to rubbing. I thought it was cause I had my rears installed on the front, but I do not see any markings. I do see that my wheels installed on the front is 6mm offset. But again according to my searchings, it's either supposed to be 0 or 16mm. I am running 245/60r15 tires on it. And it rubs on the rear plastic fenders, my sway bar, and the inner fender.
I have replaced my idler arm, inner and outer tie rods, new tie rod sleeves, new drag link, new ball joints, new lower control arm bushings. Even tightened my steering using the adjustment screw.
I'm stumped. I can take a picture of my wheel if it helps people identify it.
FYI, all 4 of my wheels are 15x7 with 6mm offset.
Last edited by Road Rash Ninja; Sep 7, 2010 at 03:59 PM. Reason: Updated information
Old Sep 7, 2010 | 04:07 PM
DeathMetalTony's Avatar
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
Re: Help
wow now thats a weird problem you got there. I believe some of those 15 inch stock wheels had marks that would indicate whick rim goes on the front or back. Double check on that hopefully that would fix that problem.
I was running the same tire size when I had my 15 inch rims on the car and I never had any rubbing problems thats kinda ackward.
You should try to post some pictures of the rims you have.
Tony.
Old Sep 7, 2010 | 04:13 PM
Engine: TPI 350
Re: Help
I will. Headed to work now. Was the stock size, according to wikipedia, the 215/65R15? then the larger tires plus saggy suspension could be the culprit. I'll have pictures posted after I get home. 4am pst.
Old Sep 7, 2010 | 04:27 PM
Engine: TPI 350
Re: Help
this is actually my rear rubbing. i have alot of rubbing going on.
tell me if you want better pics of the wheels.
Old Sep 7, 2010 | 05:16 PM
affliction1's Avatar
Car: 89 chevy camaro rs
Re: Help
why monte wheels?
Old Sep 7, 2010 | 05:39 PM
Engine: TPI 350
Re: Help
Monte? As in Monte Carlo wheels. Those were the wheels that came on the car when I bought it. Could it be I have the wrong bs and offset? Plus the bigger tires?
Old Sep 7, 2010 | 08:29 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Help
yes .
Old Sep 7, 2010 | 08:30 PM
Maeryk's Avatar
Car: 89 Formula 350
Engine: 355 long block TPI
Transmission: auto
Axle/Gears: Richmond 4:10 Eaton Posi
Re: Help
Originally Posted by affliction1
why monte wheels?
THATS what they are! Thanks! I've been racking my brain trying to remember where I saw them.
Old Sep 8, 2010 | 11:39 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Help
Sure not 15" stock IROC wheels.
