315/30r18 Anyone running this size?
COTM Editor
315/30r18 Anyone running this size? I'm looking at running this size in the BFG drag radial, or the 295/35r18... but would like to go wider than taller if possile...
PICS!?!
PICS!?!
Guest
Posts: n/a
Re: 315/30r18 Anyone running this size?
Fitting a 315/30R18x11 should be the exact same as fitting a 315/35R17x11, and I've seen several old threads showing and telling how to do that. In fact, your overall diameter should be a hair less, making it slightly easier for you.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Yep should be the same. I got 295/30/19's on the car with plenty of room to go abit wider. I want to swap to 18's so I can get a good drag radial like a 315/30 or 305/35 or something.
COTM Editor
Thanks guys.
I think I should make my first post a little clearer. I understand the measurements of the two tires and know that I can make them work under there... I'm really looking for a pic of the 315 so I can see which sidewall height I'm gonna like better... Trying to visualize how they will sit in the fenderwell.
I think I should make my first post a little clearer. I understand the measurements of the two tires and know that I can make them work under there... I'm really looking for a pic of the 315 so I can see which sidewall height I'm gonna like better... Trying to visualize how they will sit in the fenderwell. Joined: Aug 2006
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i can get pics tommorow of a 335/30/18 bfg tire, same height, so the sidewall will be the same if that helps. None that i have show the side wall very well, all are angle shots
the sidewall bulge would be the same as this if you use a 18x11
the 295/30 is pretty short, only 25" tall, i defiantly would no go that route.
COTM Editor
From my measurements the 315 should like up almost perfectly even with the fender lip. I will need to roll the inner edge.
The sidewall of a 335/30 is gonna be taller than a 315/30... Post a pic for me to see how you stuffing the 335s anyway... but still looking for pics of 315/30r18
Car: 86 Trans Am
yeah they are taller, but its about .2 or somthing overall taller, so its close enough?
i dont remember how old that pic is, so that may still be the 245/40/18, but it sits in the same spot and the current wheel, since i just had 4" added to the inside of those exact wheels to make the 12"...
the car is minitubbed, the wheels are 18x12 with 8.5" of BS. so the outside of the wheel is where a stock 16x8 "front" would be. In reality, they are only 1/2" in from the quarter panel lip, it looks like more, but if you use a straight edge, its really not.
a little bit of clearancing is needed...
the 315/30 is a odd size, i dont think i have ever seen anybody here use that size. generally, the large rear tire people use 15x10's or 17x11's.
what wheel are you using? i think you would be looking for something like 7" of BS to be flush?
COTM Editor
Yeah I was just surprised where the tire sat in there. Most guys on the site (or at least since I have been back) aren't mini tubbed to be able to run that kind of back spacing, and or a 335! I wanna run a 335 so bad LOL!
Yeah I'm pretty sure that the size is a newer size in the BFG line cause last time I looked 3 years ago it went from a 295 straight to a 335 in the 18" sizes.
I haven't been around or paying much attention to my Camaro and who has the new cool **** for it, so I asked, just incase
Guess I might have to be the first one!
COTM Editor
Well I couldn't find any pics of third gens, but here is a couple pics mounted up on a cobra on a 18x10... A little bit of bulge, but not horrible.
The new pics you put up look nice man!
Car: 1987 Camaro
Engine: 2.8 V6
Quite an old post but I was just wondering how your search went. I just picked up some wheels with 315/30r18s on them and trying to get a little info on what all I need to do to get them to fit.
toronto formula
Nov 10, 2015 06:17 AM
knight72
Aug 10, 2015 09:32 PM
