corvette rims problems!!!
Old May 25, 2011 | 10:10 PM
sibelius126's Avatar
i got a set of c6 rims 18x8.5" and 19x10" i have got the 2" adapters and trying to get them on now... the fronts fir fine but the rears... i put the adapters on and the new wheels and it rubs like hell i then went out and bought some more spacers i got another 5/16" spacer back there with the 2" they are still rubbing on the inside of the wheel well i dont know the name of the area where it is rubbing but it at the bottom inside of the wheel well what should i do? suggestions on spacers? or scrap the project and resell all these parts ive gotten? the wheels and tires and spacers
the tires on the rears are 275/40/19
Old May 25, 2011 | 11:16 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: corvette rims problems!!!
Hard to say from your somewhat vague description. WHAT is rubbing WHERE? Wheel rub? Tire rub? Car lowered? Car stock height?
If the car is lowered a good deal, that could point towards tire rub on the inner fenderwell.
Old May 26, 2011 | 04:59 AM
car is stock height and its wheel rub i'll try to do some work on it today after work and ill takepictures of where its rubbing and all
Old May 26, 2011 | 07:33 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
4th gen rear or 3rd gen?
I have the 17x9.5 in the rear with 2" spacers on a 3rd gen rear and i just can snag a finger inbetween the wheel well wall and tire on a 275/40/17
so sounds about right, you might either have to get a 4th gen rear or open the well wall more
Old May 26, 2011 | 07:35 PM
its the 3rd gen rear... so you think i should hammer the **** out of wheel well until it doesnt rub anymore?
Old May 26, 2011 | 08:40 PM
canadiancarguy's Avatar
Take the wheel off and look at where the spring is and that rubber thing (pinion snubber??) that the rear end hits if bottomed out. You can cut some of that crap out, this is what I am doing to fit the same size wheels that you have. Did you get em from oewheels? That should gain you nearly an inch long as you are not worried about cutting. I have a 91 z28, not sure if all 3rd gens are the same setup. I can get a picture of what I am talking about later tonight.
Old May 26, 2011 | 08:42 PM
At least that is the part I think you are talking about. It protrudes further out than the actual wheel well.
Old May 26, 2011 | 09:53 PM
yea im pretty sure we are talking about the same thing its just that one little spot that rubs other than that with just the 2" adapter the wheel fits very nicely into the wheel well as far as under the lip and gut the perfect stance just cant drive with it rubbing it rained pretty bad here so i couldnt go out and work on it after work i am going to try and get something accomplished this weekend thanks for the advice
Old May 27, 2011 | 03:38 PM
karl's-92'-z28's Avatar
Car: Too many cars
Take some pics, cause i got the exact same size rims im gonna put on? What size tires are you using front & back?
Old May 27, 2011 | 04:17 PM
sid rs91's Avatar
Car: 91 RS TBI 91 Z28 TPI
Transmission: wc T5
had same issue had just beat the inner fender with bf hammer until it didnt rub any more
Old May 27, 2011 | 07:41 PM
i beat and beat i got them on with no rubbing at all whew finally i got 2" adapters on back and i got 2 and 5/16 on front so they stand out a little bit more it looks great i got 225/50/18 on front and 275/40/19 on the rear
Old May 27, 2011 | 08:11 PM
Car: Too many cars
Post some pics!!!!!!
Old May 27, 2011 | 09:41 PM
this is my first time uploading pictures i hope i done them right
Attached Thumbnails corvette rims problems!!!-0527011100.jpg   corvette rims problems!!!-0527012032.jpg   corvette rims problems!!!-0526010615.jpg
Old May 27, 2011 | 09:42 PM
tell me what you think
Old May 28, 2011 | 12:06 AM
Car: Too many cars
now thats sexy!!!!!! To bad the last pic is kinda dark, other than that looks good. Cant wait to put mines on.
Old May 28, 2011 | 06:08 PM
Can we see a pic of the back of the car? Just wanna see how the width in the back looks. Also wouldn't mind seeing a pic of the side of the car to see how far out the rims sit. Just wanna get an idea of how my rims will look and if I need to trim the outer fenders a little.
Old Jun 11, 2011 | 04:09 PM
minitaz's Avatar
Car: 1987 Camaro
Engine: 2.8 V6
will 4th gen wheels work on a 3rd gen
Frozer!!!
Jan 19, 2024 04:55 PM
Djmathis123
Sep 29, 2015 01:36 AM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
BlackMagic1984
Wheels and Tires
Aug 24, 2015 06:35 AM
g.l.mos
Aug 22, 2015 12:02 AM
