wheel noob....
Old Jul 5, 2011 | 12:34 AM
87 ws6 TA's Avatar
wheel noob....
I know about nuthing when it comes to rims and tires...whats the widest rim I can run with out any mods on a stock rearend...any info would be great thanks!
Old Jul 5, 2011 | 12:38 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: wheel noob....
There is a Sticky at the very top of this Forum that has your answer.
https://www.thirdgen.org/forums/whee...er-wanted.html
Old Jul 5, 2011 | 12:54 AM
87 ws6 TA's Avatar
Re: wheel noob....
I was just hoping someone could tell me real quick cause im kinda in a hurry and dident wanna read alot sorry :/
Old Jul 5, 2011 | 01:09 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: wheel noob....
Delete/edit = I was going to mention something about the difference between a wheel and a rim but seems there are some on this site using the terms interchangeably.
Old Jul 5, 2011 | 08:53 AM
Guest
Guest
Posts: n/a
Re: wheel noob....
In a hurry? You can't buy rims in a hurry. What, was an e-bay auction about to end?
It's not just width, it's also the backspacing or offset, and the bolt pattern.
You need to know what fits BEFORE looking at e-bay or Craig's list, or any other source of wheels.
Also, what do you mean by no mods? No hammering? Or just no having to buy expensive parts? Or just no mini-tubs?
And why did you only mention the rear? Going to mix wide rear wheels with stock front wheels?
Old Jul 5, 2011 | 04:14 PM
87 ws6 TA's Avatar
Re: wheel noob....
by no mods i meant just throw on and drive moneys tight...its an 87 trans am with the stock 10 bolt...i found a set of 15x10's with 4.5 backspacing from a guy in my town just wondering if they would work or if ill have to just go with 15x8's
Old Jul 5, 2011 | 05:19 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: wheel noob....
do you have any wheels now? best way to tell whats going on as far as fitment is concerned is to measure the BS of what you have and go from there.
15x10 with 4.5 will bolt on rear, but will stick out of the fenderswells big time, no pass on those. 15x8 with 4.5" of BS will work fine though. be sure to get the right bolt pattern though.
and DO NOT RUSH to buy wheels just because something it available. take your time, find something you really like, not just whats cheap, and make sure everything is right before you buy. Its a lot more expensive to buy wheels twice if you miss a detail and buyt something that wont fit.
If you used the search feature, you could have found all this info already posted a billion times a year in various places. especially in the 15" size.
FWIW, if you at least looked at the sticky what was linked to you in the first post, you would see what would fit before you get half way down the page.
Old Jul 5, 2011 | 05:45 PM
Guest
Guest
Posts: n/a
Re: wheel noob....
For zero mods period, probably a 17x9" with zero offset. At all 4 corners. The cheapest ones are steel Cragars, at $76 each, new.
I say probably, because maybe would be a 17x9.5", if the '92 Firehawks didn't have some clearancing. IDK. Those had a +10mm offset.
Old Jul 5, 2011 | 11:05 PM
87 ws6 TA's Avatar
Re: wheel noob....
ok thanks for the info guys and sorry for being a pain in the *** lol and is it safe to run a 275 M/T on a 15x8 rim?
Old Jul 6, 2011 | 02:27 PM
Guest
Guest
Posts: n/a
Re: wheel noob....
If you get the backspacing just right, then no problem at all.
Old Jul 6, 2011 | 05:01 PM
87 ws6 TA's Avatar
Re: wheel noob....
Ok iv decided to get the jegs II rims 15x8 with 4.5BS and on the m/T ET radials should I get 26" or 28" tall tire?
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
drptop70ss
Oct 4, 2015 09:44 PM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
