tire preasure question...
Old Sep 4, 2011 | 08:22 PM
1roc89z28's Avatar
i have 2 different tires in the back, different brands....there both new...well i bought them new...and both are the same size...245/50/16...one says 51 psi and the other is like 31 psi...since there both the same size, should i put the same amount of air on both? or one has to have more then the other??
Old Sep 4, 2011 | 08:26 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
Re: tire preasure question...
I would just run 35 to 38 PSI and call it a day.
Old Sep 4, 2011 | 08:29 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
is the 51 psi tire a truck tire ???
Old Sep 4, 2011 | 08:39 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The side wall reading is the max pressure, not the ideal pressure. For example, IIRC, the max pressure on my tires is 41. The door placard calls for 32.
JamesC
Old Sep 5, 2011 | 03:39 PM
1roc89z28's Avatar
i wouldnt know....but honestly the thread does look like truck status...
Old Sep 5, 2011 | 03:42 PM
1roc89z28's Avatar
JamesC
yeah but my question.... is that since there so apart in the max psi it could handle... should i fill them up whit the same preassure???
Old Sep 5, 2011 | 04:37 PM
corlando52's Avatar
Car: 1984 Firebird SE
Engine: 2.8 L
Transmission: Automatic
My tire placard is long gone. I have a 1984 Firebird SE, 2.8L. Is 32 psi standard tire pressure with these cars?
Chris
Old Sep 5, 2011 | 06:43 PM
JamesC's Avatar
Below.
Old Sep 5, 2011 | 06:44 PM
JamesC's Avatar
I would.
The above is for 16" wheels.
JamesC
Old Sep 5, 2011 | 06:59 PM
corlando52's Avatar
Engine: 2.8 L
I would.
JamesC
James,
Mine has 14" wheels. Should I go below? The max tire pressure on the wheels is 35psi, but I read you should always go with the pressure on the placard.
Chris
Old Sep 7, 2011 | 09:00 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
My Kumho 245/50/16's also says 51 psi max pressure, but I keep them at 32 psi and it seems plenty enough air.
51 psi would be like riding on concrete tires.
Old Sep 8, 2011 | 06:43 AM
JamesC's Avatar
James,
For the best ride comfort and tire wear on a DD, I'd go with the recommended pressure.
JamesC
Old Sep 8, 2011 | 09:49 AM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
my kumo tires handle best at 34 psi on cold tires...
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
