Right front wheel rubbing after 4th gen wheel install
Old Oct 13, 2011 | 08:49 PM
zz's z28's Avatar
Car: 1987 Iroc Z
Engine: 383 Mini ram
Axle/Gears: borg warner 9 bolt
So i just installed new 17x9.5 zr1 wheels.
It is now rubbing on the right hand front side on some sort of ball joint.
Any idea why this is?
ONLY on the right side. Ican upload pics if necessary
Old Oct 13, 2011 | 09:11 PM
zz's z28's Avatar
Car: 1987 Iroc Z
Re: Right front wheel rubbing after 4th gen wheel install
Tie rod is rubbing on the passenger side only
Old Oct 14, 2011 | 04:30 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
you have spacers, are they the same? measure and make sure
any other suspension work?
its possible the steering arm is bent, but i really doubt it.
Old Oct 14, 2011 | 04:36 PM
zz's z28's Avatar
Car: 1987 Iroc Z
I just put on the Hawks third gen wheel spacers.
theyre designed for this application.
Ive always noticed that when making right turns, say into a parking lot, the front end kind of hops.
Maybe thats a sign?
I dont know, its kind of beyond me!
Old Oct 14, 2011 | 04:37 PM
zz's z28's Avatar
Car: 1987 Iroc Z
car is stock otherwise
Old Oct 14, 2011 | 04:44 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
so are the wheels rubbing, grinding the wheel, or is the front end just hopping when turning tight and slow, because thats normal.
Old Oct 14, 2011 | 07:13 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
That the scrub effect of our cars that is designed into the front suspension (kind of a flaw, really). The wider the wheels get, the worse it will scrub. There are ways to 'fix' this but that requires a ton of adjustable pieces and fiddling with SAI and IA at an alignment shop for hours for such a minimal thing.
Old Oct 15, 2011 | 03:05 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
thats suckish -___- lol..i was just gonna post up about that..never knew
Old Oct 15, 2011 | 04:57 PM
Got that info from Dean back when he posted in his thread "Ultimate Suspension" ..
Old Oct 15, 2011 | 06:29 PM
zz's z28's Avatar
Car: 1987 Iroc Z
Ahah thanks guys,
I cant get my head around it though.
It only rubs on one side.
Really killin me here!
the wheels look so good, but i cant drive it!
Old Oct 15, 2011 | 06:32 PM
RPOL98's Avatar
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
what's your total wheel backspacing (wheel + spacer)? if it's more than, say appx five-and-a-quarter inch (5-1/4"), then IMHO, you're in the danger zone with the C4 ZR1 17x9.5" wheels.
I presume your pass side wheel rubbing is occurring only on steering wheel all-the-way-over right turns?
Old Oct 15, 2011 | 06:43 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Originally Posted by zz's z28
Ahah thanks guys,
if its rubbing, something is wrong with the wheel or the spacer.
take the wheels off, and swap the spacers to the opposite side, see if that helps.
while its apart, measure the thickness of the spacer and the backspacing of the wheel and see what they are. If something is different between the two, it will become apparent.
If they all measure the same, you would have a bent steering arm, if thats what rubbing, but you seem to have some contradicting info here.
take a picture of the tie rod to tire clearance if you can. And while you are down there, how much room do you have to the tie rod on the side that does not rub?
Old Oct 16, 2011 | 07:12 AM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
My son put some wide spacers and 4th gen camaro/corvetter type 17" wheels/tires on his 91 RS. The left fron wheel barely rubbed that lip that sticks out from the strut (about 1/4 to 3/8" up from the lip of the wheel). A couple of passes with an angle grinder took a 1/4" off that lip and no more rubbing.
Old Oct 18, 2011 | 08:20 PM
zz's z28's Avatar
Car: 1987 Iroc Z
Thanks for all the help everyone!
Got it all to workout, ended up putting the wrong spacers on the front...
Anyway, It worked out and heres a video of what it looks like now.
http://www.youtube.com/watch?v=cRQltJ4gaFM
I think its a good look, still getting used to the handling aspect
Old Oct 19, 2011 | 01:00 AM
92camaroz28ss's Avatar
Car: 92 z28
Engine: fast burn 385
Transmission: t56
where in md?
Old Oct 20, 2011 | 10:43 PM
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
Transmission: Megaraptor
i had the same problem. i had switched out the right tie rod end and the replacement was quite a bit thicker on than the original. my ZR1's were rubbing/grinding pretty bad on it. i used the little spacer used for the rear tires on the front. problem solved...
BlueIroc-Z
Jun 9, 2019 03:22 AM
Omega
Oct 1, 2015 02:20 PM
kah992
Aug 19, 2015 02:55 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
TMZIrocZ350
Exterior Parts for Sale
Aug 8, 2015 05:55 PM
