Original Tire Sizes?
Hey can anyone tell me the original tire sizes for an 86 camaro?
Reason is, we are restoring this 86 iroc-z and it is going to need new tires, the info tag on the door is rubbed off so i can only read 245/.. we have an irocz with a 305 tpi, the tire size now is 225/60/16.. the rims have the front and rear specific labels..
i dont know if we should try to find 245 and if they will fit the iroc rims.. or if we should replace the size it has now and say good enuff...
this is not a full restoration, we are trying to get it road legal first, then do the extra stuff, i wish we took pictures of the work we have done so far, new motor from an 89 tpi and made it work in this 86, just needs minor things and some body work...
thanks for the help...
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Original Tire Sizes?
245/50/16 is stock diameter and will fit perfectly on the factory 16x8 wheels, front and back
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Car: 1985 Trans Am
Engine: 6.6 at least
Transmission: T-56 (waiting)
Axle/Gears: 9" w/4.56 & spool (4 now)
According to the RPO book for 1986:
QAC P235/60R15 blackwall (Z28 only)
QDX P195/70R14 Eagle GT (Berlinetta only)
QHX P205/70R14 blackwall (Berlinetta only)
QHY P205/70R14 white stripe (Berlinetta only)
QYH P215/65R15 white letter (no cost Z28)
QYZ P215/65R15 blackwall ($92 credit w/ Z)
toronto formula
Nov 10, 2015 06:17 AM
knight72
Aug 10, 2015 09:32 PM
