New Wheels? Opinions, please!
Old Feb 3, 2012 | 08:11 AM
Hewmanoid's Avatar
Car: 1988 IROC-Z
Engine: L98 (for now!)
Transmission: TH700-R4
Axle/Gears: 9-Bolt BW; 2.77
Hi guys. I'm thinking about ordering some new wheels in the near future. I'm going with 18" all around, and with a staggered setup. I'm trying to go 18x8.5 in the front and 18x10 in the rear. I currently have two sets that I really like, but not sure which one to choose. This is where you guys come in.
Oh, I almost forgot. I have a 1988 IROC, Medium Orange Metallic, that's getting repainted shortly as well. Currently has stock, gold, 16" wheels. Getting rid of the gold striping and decal on the door and replacing it with silver.
First (and the one I'm slightly leaning towards) is the XXR 006 with Copper lip.
They don't make these in 18x10, so I'd have to settle for 18x9.5. I want to get about a 295 tire in the back. They are as follows:
Front: 18x8.5 w/ 2" lip
Back: 18x9.5 w/ 3.5" lip.
Next is the XXR 521, black with machined, stepped lip. These come with removable rivets, which I would probably get painted MMO to match the car.
Front: 18x8.5 w/1.75" lip (picture below)
Back: 18x10 w/3.5" lip
Again, any input is greatly appreciated. I always wanted this car to have a "Halloween" feel; orange and black. It has a black interior. I've attached two pics of the wheels mocked up.
Thanks for reading! -Matt
Attached Thumbnails New Wheels? Opinions, please!-iroccopper.jpg   New Wheels? Opinions, please!-irocmachined.jpg
Old Feb 3, 2012 | 08:51 AM
3rd Coast Z's Avatar
Car: 1987 IROC Z / 1999 Suburban 2WD
Engine: Lingenfelter 383 / Vortec 350
Transmission: 700R4 / Built 4L65E
Axle/Gears: Stock / 4.56 Locker
Re: New Wheels? Opinions, please!
I'm digging the copper lip wheels. If you are keeping the car the same color my opinion is those. Do you have to run spacers with these?
Old Feb 3, 2012 | 09:27 AM
Hewmanoid's Avatar
Car: 1988 IROC-Z
Thanks! I may have to use small ones. The front has a little over 6" bs, and the back has a little over 6.5" bs. I'm going to figure that out when I have them in my possession, simply because I don't know where I want them to sit. But yeah, probably .5" all around.
Old Feb 3, 2012 | 10:19 AM
KMK454's Avatar
Car: 1991 Camaro B4C
I love those XXR wheels, but wish they didn't have a million holes drilled in them.
Old Feb 4, 2012 | 10:34 AM
LivinLarge's Avatar
I love those mesh wheels. But x2 on wish they didnt have 10 holes drilled in the center
And would these fit our cars?
http://www.nlmotoring.com/product-p/52188149.htm
Old Feb 4, 2012 | 01:46 PM
Hewmanoid's Avatar
Car: 1988 IROC-Z
I agree with both of you about the bolt holes. I'm going with the copper ones. As for those wheels you posted, yes they will. They should bolt right on, no spacers. But you'll probably want some for the front. Probably 1", but it's up to your preference.
Old Feb 4, 2012 | 03:36 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
you will need a spacer about 1" or so front and rear to keep them in the stock location. that requires longer wheel studs and hubcentric slip on spacers.
all these wheel, above and the OP's are the 5x120 pattern. not "correct", as stock is 120.65, but people use them.
Old Feb 4, 2012 | 04:15 PM
Ronnie Brennan's Avatar
Car: 1986 Camaro
Engine: 355 N/A mind 400hp build
sadly enough... the first thing I think when I see these wheels are honda's and mazda's..... Its too bad really because they are nice wheels... just doesnt screen muscle car to me. but that.. is my own personal opinion and most likely not shared by many. They do look nice though.
Old Feb 5, 2012 | 12:52 PM
LivinLarge's Avatar
Can anyone photoshop these wheels on this car??
this is not my car
Old Feb 5, 2012 | 05:10 PM
Hewmanoid's Avatar
Car: 1988 IROC-Z
This is true. I forgot to say about the hub centric rings. The longer studs may not need to be used, depending on if you have bolt-on adapter spacers with the new studs on them already, unless those are too short as well. And yeah, they are off 0.65mm. Just make sure they're torqued correctly and check on them once in a while.
Old Feb 5, 2012 | 05:32 PM
Hewmanoid's Avatar
Car: 1988 IROC-Z
this is not my car
The back wheel could be a little better, but the front looks ok.
Old Feb 5, 2012 | 06:05 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
A 285 is about the limit on a 9.5 according to most tire makers.
18x8.5 245/40 front
18x9.5 285/35 rear
Attached Thumbnails New Wheels? Opinions, please!-dscf1606-medium-.jpg   New Wheels? Opinions, please!-dscf1609-medium-.jpg   New Wheels? Opinions, please!-dscf1610-medium-.jpg
Old Feb 5, 2012 | 06:56 PM
LivinLarge's Avatar
Would this be a better pic to do it on?
again not my car
Old Feb 6, 2012 | 06:18 PM
FNFAL308's Avatar
Car: 91 Bird
Engine: TPI 350
Transmission: 5-Speed
Axle/Gears: 2.77 posi
I like the copper wheels but I must say I don't think the color goes with your paint. not close enough to the same color and not enough different to contrast. Of course what we like doesn't matter as long as you like them.
Can you photoshop some stripes at the botton of the gfx maybe with a darker one at bottom, color of wheels in center and something lighter just above that? Kinda like the factory stripes on some camaros but in different colors? That would give the wheels something to match to like matching a tie to a shirt/pants with just a little bit of color that matches
Old Feb 8, 2012 | 07:49 AM
Hewmanoid's Avatar
Car: 1988 IROC-Z
18x8.5 245/40 front
18x9.5 285/35 rear
Thanks! Nice pics, too!
again not my car
It wasn't the picture I was talking about. I was saying that my editing could have been a little better. Sorry for the mix-up!
This photo shows what it looks like in the sunlight. This color changes a lot, depending on given sunlight. I looked at the wheels on different cars, and in the right light, it changes much like my paint.
Anyway, thanks everyone. I'm actually not buying wheels at the moment now. Working on the drivetrain first.
88rscamar0
Sep 23, 2015 09:08 PM
Jlanz55
Sep 8, 2015 11:28 PM
scottmoyer
Sep 7, 2015 07:06 PM
TheExaminer
Sep 7, 2015 08:34 AM
84 TA NV
Sep 6, 2015 08:02 PM
