z06 rim question
Car: 1986/90 camaro
Engine: 350 tpi
Axle/Gears: 3.73 gears. POSI
z06 rim question
I have a set of 04 z06 rims 17x9.5 in front and 18x10.5 in the rear and i know i need spacers but not sure of what size spacer? and i have an adj panhard bar and i want to run 295/35/18 in the rear and i am wondering if they will fit with minor hammering lol? help is very appreciated
Car: 1992 Camaro z28
Engine: 350 HSR
Axle/Gears: 3.42's
Re: z06 rim question
I run 2" spacers with my z06 wheels, and ive got 285/35's out back with alittle room left. Id say maybe some lite hammering just to be safe but you should be ok.
Car: 1986/90 camaro
Engine: 350 tpi
Think i should run 285's to be safe? and are your rims 10.5 inches wide and are you running 2 inch spacers on the front to?
Engine: 350 HSR
Axle/Gears: 3.42's
yea 2" front and back but my rears are 18x9.5. Maybe someone with 10.5's will chim inn but I think you'll be fine with the 295's.
Car: 1986/90 camaro
Engine: 350 tpi
ok thanks man, appreciate it. were did you get your spacers from?
Engine: 350 HSR
Axle/Gears: 3.42's
Engine: 350 HSR
Axle/Gears: 3.42's
Car: 89 GTA
Engine: 5.7 TPI L98
Transmission: 700R4 w/ Stage 2 shift kit & stall
Car: 89 GTA
Engine: 5.7 TPI L98
They actually fit awesome and look amazing as well. Are yours chrome? I'll have to upload some pictures in a little bit. Mine fit pretty well all around. The 295's in the back fit with absolutley no trouble. If I decide to go to a 305 or 315 I may just need to hammer out the fender a little or use a 2.5" spacer. As for the fronts' nothing rubs but my tie rod is extremely close to the inner lip of the wheel. I am going to order 2.5" for the front just to give myself the extra clearence. Everything sits flush with the fenders and nothing sticks out. Like I said, I'll post pictures in a little bit. I'm at work right now and photoshop is blocked. lol.
Car: 91' Z28. 70' Dune Buggy
Engine: LSX Cam/Full Bolt ons
Axle/Gears: 4.10
Car: 89 GTA
Engine: 5.7 TPI L98
Car: 85 Camaro
Engine: 454 RamJet
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
17X9.5 w/54mm & 18X10.5 w/58mm offsets. I just got mine delivered and tried them with the 2" spacer that I had on my car (recomended size is 2.25" on the front and 2" on the rear) and its really close to the tie rod. I think if it wasnt for my c5 brake upgrade they would probrably hit the rim. I also would like to add that these clear my brake upgrae much better than the Konig Monsoons I had on that are the same size. The rear are also fairly close but nothing some hammering wont fix, I already have the rear lip rolled and have 295/35/18 to put on the rear. I will post pics once tires are on the car
Car: 85 Camaro
Engine: 454 RamJet
they clear without any issues at all, very tight though. still say i wouldnt try it without a brake upgrade in the front or with a 2.25" spacer in the front
Axle/Gears: 4.10
What backspacing are your z06 wheels? I was told there was absolutely no way I could fit my c6 Z06 wheels on my car.
1992rs/ss
16
Jan 28, 2016 09:58 PM
