Fitment Thread
Old May 23, 2012 | 12:55 AM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Fitment Thread
Everyone post your aftermarket wheel setups with specs on the sizes and offset..
please try not to clutter this thread up with TOO much talk..take it to the PM's
include
Front
Wheel diameter:
Wheel width:
Wheel offset:
Wheel backspace:
Tire size:
Front brakes:
Special modifications required:
Notes:
Rear
Wheel diameter:
Wheel width:
Wheel offset:
Wheel backspace:
Tire size:
Rear brakes:
Differential:
Notes:
Old May 24, 2012 | 06:46 PM
robg91z's Avatar
Car: 1991 Camaro Z28
Engine: 350ci TPI
Transmission: built 700r4
Axle/Gears: 4th gen rear end
Re: Fitment Thread
^ yeah that.. especially those with 4th gen rears!!!!!!
Old May 24, 2012 | 06:55 PM
87350IROC's Avatar
Car: 87' IROC
Re: Fitment Thread
This thread is a really good idea. So let do it right.
If you post, include
Front
Wheel diameter:
Wheel width:
Wheel offset:
Wheel backspace:
Tire size:
Front brakes:
Notes:
Rear
Wheel diameter:
Wheel width:
Wheel offset:
Wheel backspace:
Tire size:
Rear brakes:
Differential:
Notes:
Also include a general picture as well as a picture or two to show how they sit with the fender.
Old May 24, 2012 | 07:12 PM
87350IROC's Avatar
Car: 87' IROC
Re: Fitment Thread
I will start.
HRE 560R
Front
Wheel diameter: 19"
Wheel width: 10"
Wheel offset: +22mm
Wheel backspace: 6.4"
Tire size: 285/35/19
Front brakes: 2009+ CTS-V (+0.3" track over stock)
Special modifications required: spindle dust cap needs to be removed in order for wheel center cap to fit.
Notes: Some reduced turning circle due to rim touching rear a-arm bar. Need to make sure wheel is centered in wheel well to eliminate rubbing due to taller than stock tires.
Rear
Wheel diameter: 19"
Wheel width: 10"
Wheel offset: +21mm
Wheel backspace: 6.3"
Rear brakes: 2009+ CTS-V (same track as stock)
Differential: Dana 44 (stock width)
Special modifications required: none
Notes: Need to make sure differential is centered to eliminate any rubbing.
Car is not on the ground yet. So no great pictures. But here is what I have.
General Pictures:
Front Fitment (not actual wheel, but fits exactly the same):
Rear Fitment (not actual wheel, but fits exactly the same):
Old May 24, 2012 | 08:56 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
Re: Fitment Thread
ugh..i fricken love your setup very very nice sir
adding the requirements to OP
Old May 29, 2012 | 01:32 PM
robg91z's Avatar
Engine: 350ci TPI
Re: Fitment Thread
Where r all the rest!!!!! Come on guys lets see those crazy 3rd gens
Old May 29, 2012 | 01:36 PM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
Axle/Gears: 4.10's / Strange LSD
Re: Fitment Thread
Sorry to get off subject but wow your car is just sexy 87350IROC.
Mark.
Old Jun 6, 2012 | 04:19 PM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Re: Fitment Thread
Corvette Y2K thin spoke wheels.
Front
Wheel diameter: 17"
Wheel width: 8.5"
Wheel offset: +58 (effectively +7)
Wheel backspace:
Tire size: 245/45/17 Falken FK452
Front brakes: stock
Special modifications required: 2" bolt on spacers
Notes: wheel is super tucked and very close to the tie rod end. Could possible use 2.5-3" adapters.
Rear
Wheel diameter: 18"
Wheel width: 9.5"
Wheel offset: +65 (effectively +14)
Wheel backspace:
Tire size: 275/40/18
Rear brakes: stock PBR disc's
Differential: stock 10 bolt
Notes:
Rear:
Rear and front fitment:
Old Jun 6, 2012 | 04:42 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: Fitment Thread
Front - CTW Wheel
Wheel diameter: 17"
Wheel width: 9.5"
Wheel offset: 0mm
Wheel backspace: 5"
Tire size: 275-40-17
Front brakes: Baer Track 13" 2 piston
Special modifications required: None
Notes: Baer system pushes out track 5/16" past stock -
Rear - CTW Wheel
Wheel diameter: 17"
Wheel width: 9.5"
Wheel offset: 0mm
Wheel backspace: 5"
Rear brakes: Baer one piston 12" kit
Differential: Strange 12 bolt, stock width
Notes:
See pics on car at the CTW Website: http://www.ctw-motorsports.com/products/
Old Jun 6, 2012 | 06:04 PM
DBLTKE's Avatar
Engine: LB9, LB9
Re: Fitment Thread
My autocross set up, '01 Camaro SS wheels.
Front
Wheel diameter: 17"
Wheel width: 9"
Wheel offset: +50 (effectively -1)
Wheel backspace:
Tire size: 285/40/17 Nitto NT555
Front brakes: stock
Notes: I rolled my front fenders, removed my fender liners and had to BFH the battery tray for tire clearance.
Rear
Wheel diameter: 17"
Wheel width: 9"
Wheel backspace:
Notes: recommend rolling the rear fenders if you plan on running low or soft spring rates.
Front fitment
Rear fitment
Old Jun 8, 2012 | 12:02 AM
DBLTKE's Avatar
Engine: LB9, LB9
Re: Fitment Thread
Corvette Salad Shooters (ignore the tire size, these were on a MK2 GTI)
Front
Wheel diameter: 16"
Wheel width: 8.5"
Wheel offset: +32 (effectively -19)
Wheel backspace:
Tire size: 205/40/16
Front brakes: stock
Notes: this set up is extremely flush with the fenders, if you plan to run super low then expect to roll the fenders and maybe run a slightly stretched tire.
Rear
Wheel diameter: 16"
Wheel width: 8.5"
Wheel backspace:
Notes: just like the fronts you will definitely need to roll the fenders if lowered and possibly run a stretched tire.
Front fitment:
Rear fitment:
Old Jun 8, 2012 | 12:18 AM
DBLTKE's Avatar
Engine: LB9, LB9
Re: Fitment Thread
Trans Am GTA wheels
Front
Wheel diameter: 16"
Wheel width: 8"
Wheel offset:+16 (-35)
Wheel backspace:
Tire size: 245/50/16
Front brakes: stock
Notes: this is with 2" bolt on adapters, they would definitely require at least a good fender pull to run like this. I also have -1.6* of camber up front.
Rear
Wheel diameter: 16"
Wheel width: 8"
Wheel offset: +16 (-35)
Wheel backspace:
Tire size: 245/40/16
Notes: again I have 2" bolt on adapters in these pics, recommend decent fender pull unless running stretched tires.
Front fitment
Rear fitment
Old Jun 8, 2012 | 01:02 AM
DBLTKE's Avatar
Engine: LB9, LB9
Re: Fitment Thread
LT1 4th gen Camaro SS wheels up front and OEM ZR1 wheels out back.
Front
Wheel diameter: 17"
Wheel width: 9"
Wheel offset: +50 (-1)
Wheel backspace:
Tire size:
Front brakes: stock
Notes: looks to be a perfect fit. Maybe a fender roll for peace of mind.
Rear
Wheel diameter: 17"
Wheel width: 11"
Wheel offset: +36 (-15)
Wheel backspace:
Tire size:
Notes: this is with 2" bolt on adapters. Definitely too much poke. 1" or .75" spacers would be better.
Front fitment
Rear fitment
Old Jun 8, 2012 | 09:26 AM
paul_huryk's Avatar
Re: Fitment Thread
Front
Wheel diameter: 16"
Wheel width: 8.5"
Wheel backspace:
Front brakes: stock
Rear
Wheel diameter: 16"
Wheel width: 8.5"
Wheel backspace:
Front fitment:
Rear fitment:
Those Vette wheels used 255-50-16 tires stock, a full 2" wider than what you have in the pictures. The use of a 1.25" spacer would make them work perfect and you can run 245-50 or 255-50 tires easily.
Old Jun 14, 2012 | 08:57 PM
DBLTKE's Avatar
Engine: LB9, LB9
Re: Fitment Thread
Anyone else have any contributions?
Old Jun 29, 2012 | 12:09 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: Fitment Thread
Budnik Gasser
Front
Wheel diameter:18
Wheel width:8
Wheel offset:0
Wheel backspace:unknow
Tire size: 255/40/18
Front brakes: stock
Special modifications required:none
Notes:
Rear
Wheel diameter:18
Wheel width:10
Wheel offset:unknown
Wheel backspace:unknown
Tire size:275/45
Rear brakes:stock
Differential: 10bolt
Notes:
Wheels came with car but I sold to a member on here
Old Jun 29, 2012 | 12:26 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: Fitment Thread
Iroc Reproduction
Front
Wheel diameter:16
Wheel width:8
Wheel offset:stock
Wheel backspace:stock
Tire size:225/50
Front brakes: stock
Notes:
Rear
Wheel diameter:16
Wheel width:8
Wheel offset:stock
Wheel backspace:stocky
Tire size:225/55
Rear brakes:stock
Differential: 10 bolt
Notes:
Old Jun 29, 2012 | 12:41 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: Fitment Thread
Front
Wheel diameter:16
Wheel width:8
Wheel offset:stock
Tire size:245/50
Front brakes: stock
Notes:
Rear
Wheel diameter:16
Wheel width:8
Wheel offset:stock
Tire size:245/50
Rear brakes:stock
Next up 18x10 all around xxr 521 !!!!!
Teaser pic
Old Jun 30, 2012 | 02:19 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
Re: Fitment Thread
MOREEEEEEEEE!
Old Mar 9, 2014 | 09:00 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
Re: Fitment Thread
ahem
Old Mar 9, 2014 | 01:15 PM
Teal92's Avatar
Re: Fitment Thread
Originally Posted by Zach/90\irocZ
Front
Wheel diameter:16
Wheel width:8
Wheel offset:stock
Tire size:245/50
Front brakes: stock
Notes:
Rear
Wheel diameter:16
Wheel width:8
Wheel offset:stock
Tire size:245/50
Rear brakes:stock
Teaser pic
Backspacing and tire size of the 18x10's please
Old Mar 9, 2014 | 07:12 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: Fitment Thread
I have a thread on them search 521
Old Mar 9, 2014 | 08:01 PM
Blue 90 RS's Avatar
Car: 1990 Camaro RS
Engine: 5.0L
Transmission: WC T5 5-speed
Re: Fitment Thread
Aftermarket/Replica ZR1 wheels from OE Wheels, LLC
Car is lowered 1" on Eibach Pro-Kit springs
Front
Wheel diameter: 17"
Wheel width: 9.5"
Wheel offset: +56mm
Wheel backspace: 7.45"
Tire size: 275/40R17 BF Goodrich geforce Sport Comp II
Front brakes: Stock discs
Special modifications required: 2.25" adapters
Notes: An adapter of any less than 2.25" would have let the wheel rub the steering/suspension
Rear
Wheel diameter: 17"
Wheel width: 9.5"
Wheel offset: +56mm
Rear brakes: Stock drums
Differential: 3.73 from 1989 Firebird (optional ratio)
Special modifications required: 2.00" adapters
Notes: N/A
Old Mar 11, 2014 | 12:39 PM
Roostmeyer's Avatar
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
Re: Fitment Thread
This is a race only fitment
Front
Wheel diameter: 18"
Wheel width: 11.5"
Wheel offset: 25
Wheel backspace:7.25 (front brakes are ~1/2" wider)
Tire size: 315/30R18 Hoosier A6
Front brakes: JRZ aluminum hubs, 12.2" rotors
No fender liners, fenders pulled out on mounts, close to 3° of negative camber, aggressive fender roll, pinch seam rolled, and a loss of full lock steering angle.
Notes:These pictures are with a 1/2" spacer, Parts have been bought to change wheels to 12" wide, I still need to buy some 335 A6's. Will probably need more camber and cutting the fenders down low.
Rear
Wheel diameter: 18"
Wheel width: 11.5"
Wheel offset: 38
Wheel backspace:7.75
Rear brakes: PBR 11.67"
Differential: 9-bolt
Special modifications required: Rear fenderwells are sectioned in to the frame rails, fenders are rolled. For 345's I may need to cut the lip, re-roll the fenders, and weld the inner fender further up the wheel arch.
Notes: hoping to go to 18x12's in back with 345/35R18 A6's.
Old Mar 11, 2014 | 04:49 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Fitment Thread
Roostmeyer, those wheels look so incredibly good. Wow.... CCWs?
Anyway I just got some ZR1's.
Front
Wheel diameter: 17
Wheel width: 9.5
Wheel offset: 56
Tire size: 275/40/17
Front brakes: LS1 brakes (LS1 rotors are supposedly .300 inches thick)
Special modifications required: 2 inch adapter.
Notes: 2 inch adapter plus LS1 rotor is 2.3 inches total. Clearance to strut and tie rod end is VERY tight. Less than 1/8 of an inch by my estimation, but it does clear.
Rear
Wheel diameter: 17
Wheel width: 11
Wheel offset: 36.5
Wheel backspace: 7.397
Tire size: 315/35/17 (Nitto NT555, these are supposed to run narrow)
Rear brakes: 89 PBR discs
Differential: thirdgen 9-bolt
Special modifications required: 1.25 inch adapter, minor clearancing of inner fender, adjustable panhard bar. Any PHB with 1 rod end will suffice.
Notes: I had to BFH the inner fender in front of the tire above the LCA and I tried to hammer in some of the "Ridges" above the bump stop. Most people cut these and the bump stops off, but I don't see that as necessary at all. I didnt really even need to hammer in those ridges, I just wanted to take a 16th of an inch off of them just for my own peace of mind.
If you do cut the bump stop area off and plate it in and make sure you clearance the area in the front a little more you may be able to run a 1 inch spacer and tuck these in VERY tight. These would not work with a 4th gen rear axle.
This is the front of the fenderwell, that black bar is my lower control arm and you're looking up towards the spring pocket and shock mounts on the car. This is the area of most concern, and my front 17x9.5's would have rubbed here also with 2 inch spacers.
Old Mar 14, 2014 | 08:17 PM
TheNobleOne's Avatar
Car: 1985 Camaro Z28 - T-Tops
Engine: 357ci 5.7L
Transmission: 6 Speed T56
Re: Fitment Thread
I Really Hope Someone Can Clear This Up...
I am about to purchase 18x9.5 C5 wheels and i need to see who here is using the Hubcentric adapters and who is using the Lugcentric adapters.
Also can you share your experiences with EZAccessory or Motorsport-tech in regards to your Hubcentric or Lugcentric adapters.
Thank you,
Your help is greatly appreciated.
Old Mar 14, 2014 | 08:33 PM
Blue 90 RS's Avatar
Car: 1990 Camaro RS
Engine: 5.0L
I am using adapters from EZAccessories. The rears are 2.00" and are both hub-centric as well as wheel-centric. The fronts are 2.25" and are hub-centric on the car side, but lug-centric on the wheel side. They can't be wheel-centric on the front because of the spindle hub sticking out. I am running 17 x 9.5, +56mm offset, 7.45" backspace ZR1 replicas from OE Wheels, LLC. I have no complaints with the quality of the adapters, but I did buy replacement Dorman lugs to use with the adapters because I thought the ones shipped with them looked cheap. Made me feel better, anyways. I used blue Loctite when installing the adapters. YMMV
Old Mar 14, 2014 | 09:14 PM
Engine: 357ci 5.7L
Re: Fitment Thread
Wow, Thanks for the quick response.
Would you happen to have the part numbers? I will get the exact same ones.
I could only see the 70.3mm -> 70.3mm and 73mm ->73mm options.
Hubcentric
http://www.ezaccessory.com/Hub_Centr...475-5475hv.htm
Lugcentric
http://www.ezaccessory.com/Wheel_Ada...5475-5475c.htm
Old Mar 14, 2014 | 09:24 PM
Blue 90 RS's Avatar
Car: 1990 Camaro RS
Engine: 5.0L
Those are the same part numbers I ordered. I had to take a Dremel to the inside of the rear adapters and to the rear axle hub to free up just a hair more space for proper fitment. They fit a little too tight, which would have made removing them very difficult. Fronts fit fine after a good cleaning of the hubs. All fit nice and snug, with no room for movement.
Old Mar 14, 2014 | 09:32 PM
Blue 90 RS's Avatar
Car: 1990 Camaro RS
Engine: 5.0L
You should be able to run 2.00" adapters front and rear if you're going with 18" wheels. You'll have an additional 1/2" clearance from the tie rod end than I do with my 17" wheels. FYI
Old Nov 14, 2021 | 09:18 PM
adrianthecamaro's Avatar
Re: Fitment Thread
Wait, your running the same wheels in front and back, yet the rear has spacers, how do they line up equally then? My camaro has the same wheels (z28 wheels) on front and back, they’re even, but I don’t run spacers?
Old Nov 15, 2021 | 07:29 AM
Abubaca's Avatar
Re: Fitment Thread
You're responding to a 7 year old thread. Who/what post # is your comment in reference to?
Welcome to TGO!
Old Nov 17, 2021 | 01:18 PM
cpdin2011's Avatar
Car: 92 z28 LS2 swapped t56
Engine: Ls2
Transmission: T56 6 speed
Axle/Gears: 323
Re: Fitment Thread
Front
Wheel diameter:18
Wheel width:8.5
Wheel offset: -6mm
Wheel backspace: 4.5
Tire size: 245 45 18
Front brakes: disc oem
Notes:
Rear
Wheel diameter: 18
Wheel width:8.5
Wheel offset: +32mm
Wheel backspace: 6
Tire size:28x10.5x18
Rear brakes: oem disc brakes
Differentialem 373 rear
used a 1 inch wheel spacer to fit the tire.
Old Nov 18, 2021 | 12:49 AM
Swapper's Avatar
Re: Fitment Thread
OEm c5 z06 wheels 18x10.5 squared
Front
Wheel diameter: 18
Wheel width: 10.5
Wheel offset: +58
Wheel backspace: 204.05mm
Front brakes: 6th gen Camaro Brembos
Special modifications required: 2" spacers
Notes: think i need a small height tire. rubs bad on full turn
Rear
Wheel diameter: 18
Wheel width: 10.5
Wheel offset: 58
Tire size: 295/40/18
Rear brakes: lt1
Differential: strange 12 bolt 4th gen length
Notes:
looking for different wheel at the moment.
LGS_18
Wheels and Tires
Feb 20, 2025 04:39 PM
knapper79
Wheels and Tires
Jan 4, 2010 07:22 PM
omss1969
Feb 11, 2007 03:10 PM
Jim85IROC
Mar 12, 2002 07:15 AM
