C5 Z06 or SS SLP wheels?
Car: 1991 RS/1991 Z28
Engine: 305 TBI/350 TPI
Transmission: 700 R4
Axle/Gears: 373
Looking at wheels lately. Thinking of some C5 Z06 or 2002 SS SLP wheels. What size adaptors will I need? If you have pics of these wheels on your car please feel free to post. Any suggestions or tips will help. Thanks!
Car: 1992 Chevrolet Camaro Z28
Engine: 5.7 TPI
Transmission: 700R4 Overdrive Automatic
Axle/Gears: 3.23:1 Positraction
Re: C5 Z06 or SS SLP wheels?
Honestly I like the '91-'92 wheels so much I wouldn't Really ever change them, and if I did I would keep the originals. But ZR1s are usually swapped onto thirdgens.
Axle/Gears: 373
Thanks for the input. I'm open for any wheel suggestions as well. I really like the ZR1's, but I think the only look good in chrome/polished. Not sure if I want to go that way yet. I just had a bunch of suspension stuff done and dropped the car a bit. I think it needs a new look.
Axle/Gears: 373
I also am a big fan of the 91-92 wheels. I just wish I could get a bigger tire on them. From what I have been told, a 255 is as wide as I can go. With the offset they have I wonder if having the wheels widened is an option? I will definitely be keeping my original wheels no matter what decision I make. Everyone here in Michigan is doing the really big iroc wheels, 18's and 20's. That is a bit much for me. If I go with 18's I really like the C-5 wheels. We shall see..
Car: 88 Iroc Z, 00 SS
Engine: 5.7 HSR, 5.7 LS1
Transmission: 700r4, T56
Axle/Gears: 3.23, 3.42
Zr1 wheels make these cars look really wide, these are 17x9.5 up front and 17x11 out back, get compliments all the time around town even tho my paint is junk, lol
Axle/Gears: 373
I used a 2 1/4" up front and im running a 4th gen rear end so no adapters out back, although I want to swap an LS1 rear end in there because those are a 1/4" narrower on both sides then the LT1 rear that I've got and that would tuck the wheels in more and look better
Axle/Gears: 373
instead of replacing all that stuff, why not just swap in a 4th gen rear? You will get better rear brakes out of it
Axle/Gears: 373
I'm planning on a Moser 9 inch in the spring. I will probably do the disc brake upgrade then. Just trying to get what I have to make it til its time to store the car for the winter. I just bought all the parts today, minus the axles. Hopefully I didnt scrap mine by driving the car with a bad bearing.
Car: 92 camaro
Engine: stroker
Transmission: Megaraptor
here's a pic of my c5 z06...
before paint with the ZR1's
a buddy of mines, with the ZR1's
IMO i would go with the ZR1, (not the slp for 3rd gens though)
Axle/Gears: 373
Nice man! I think they all look pretty good! I'll see if I can find a picture of the slp ones that I am talking about. What about the adapters? What size did you use?
Car: 92 camaro
Engine: stroker
i wanna say i got my adaptors from third gen ranch or hawks. i believe those adaptors will allow you to mount the 4th gen wheels on a third gen. if you go aftermarket, you just need to make sure you get the offsets for a fourth gen.
Axle/Gears: 373
the wheels your put up are 35th anniversary Camaro wheels I think
edit: whoops, that's what you asked for in the first place, my bad
punkmaster98
Sep 8, 2015 09:45 PM
