Quick Question About Stock Z28 Wheels.
Car: 1991 Z-28
Engine: 5.7L(350ci) TPI L98
Axle/Gears: G92
http://i65.photobucket.com/albums/h2...aropics018.jpg
Were those wheels made in more than one size?
I just want to make sure they didn't make different widths of those wheels if I am buying them online and don't have an opportunity to measure them.
Thank you for any help.
Car: 1991 Z-28
Axle/Gears: G92
Re: Quick Question About Stock Z28 Wheels.
Thank you, saw a set online that had a set of 225 tires on them, just wanted to make sure the rims didn't come in a 6 or 7 inch width.
Thanks again
Thanks again
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
Just to make sure all bases are covered, the front and rear have different offsets on factory sets. The front offset is 0 and the rears are deeper(can't remember measurement but it's on this site). The rears won't work on the front but you can run as many fronts as you like.
I really love those wheels, best looking stock camaro wheels in my opinion. I run a 245 front and 255 rear tire on mine. Difference is minimal, but nice.
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Yep, 16x8 They also used that wheel on some of the S10 SS trucks and the S10 ZQ8 package.
Car: 1988 camaro sports coupe
Engine: Fast Burn 385
Axle/Gears: 9 bolt w/ 3.27 gears
The wheels used on trucks have the same offset all around, front and rear. That offset (on the truck) differs from both front and rear Z28 wheels. They're specific for trucks. The differance is minimal though, the wheels should still fit. Also, I think there may be an issue with camaro center caps fitting those wheels.
I have no first hand knowledge, but I was trying to replace a messed up Z28 wheel with a truck wheel, going back a while. Decided againt it based on info from this site. I think it was a post in the for sale section, with the seller explaining the wheels, in detail, in his description.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
