tire rub front drivers fender shroud
Car: 91 Camaro RS
Engine: GM PP crate 350
Axle/Gears: 3:42 spooled 10 bolt
rubs plastic trim nearest the door when turning left.
it does not on passenger side ,i got a BFH, but idk
where to hit anything.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: tire rub front drivers fender shroud
What wheels do you have. How is your alignment. Too much caster can cause this problem. Don't hammer anything. If its a light rub, I would not even worry about it
Car: 91 Camaro RS
Car: 86 Trans Am
What are the wheel specs, width offset backspacing? Don't hammer anyything in the front, there is never a need to.
If its only one side, you should have the alignment checked
The wheels look like they are out a little too far, but I can't tell from the pic. Don't hammer things.
