Road Racing on 17's
Old Feb 17, 2013 | 09:55 PM
wastntim's Avatar
Road Racing on 17's
Check out my new 17" 20.4# wheels which I will be road racing with for the first time this coming racing season.
I've teamed up with CTW Motorsports to try to give the 4th gens a run for their money. These new rims that Paul has produced will finally allow me to run 275's on a light, economical rim all while giving me room to step up to a big brake package. Plus they look killer too.
During the season, I plan to get real data utilizing my traqmate which should prove the benefit of running the beefier 275s over my previous 16" GTA rims on 255s.
If you want to see my video's during the year and see some results check out my facebook page:
http://www.facebook.com/pages/Heavy-...30987883613405
To find more about these rims check out :
http://www.ctw-motorsports.com
Here's some more pics:
Old Feb 18, 2013 | 08:36 AM
peterc005's Avatar
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
Re: Road Racing on 17's
Subscribed.
Old Feb 18, 2013 | 04:47 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Sweet!
Old Feb 18, 2013 | 05:07 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Is 20.4# the weight? What tires are you running and what's the combined weight of a wheel and tire? What are the wheels? Size? How much? Where'd you get them?
Old Feb 19, 2013 | 01:18 PM
wastntim's Avatar
I'm running shaved 275 40 RA1's. Unshaved they are listed at 29#s. I think mounted they came in at just under 50# mounted. The wheels are 17x9.5 and are by CTW motorsports. They are $1,125 per set plus shippping.
Old Feb 19, 2013 | 03:08 PM
paul_huryk's Avatar
These tires are very heavy and are meant for racing use only.
As an example in our shop, I have a set of Continental Extreme Contact DW in 275-40-17 and they come in at 45lbs each, one pound less than a stock 1992 Z28 wheel with a 245-50-16 tire. With the Falken 615k tires, they come in at 47lbs each.
Old Feb 19, 2013 | 03:12 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
stock IROCs with 245/50/16 tires come in around that same weight I think?
Old Feb 19, 2013 | 08:24 PM
paul_huryk's Avatar
Depends on the tires, but yes they do come within a # or two.
But lace TA wheels with a 245-50-16 will come in lighter - but the advantage of brake clearance and tire width is too much to overcome.
83RDRACR
Mar 26, 2016 08:13 PM
Damon
Sep 26, 2015 04:29 PM
JSDaddy189
Sep 26, 2015 03:50 PM
wstephan96
Sep 25, 2015 04:28 PM
abray1
Sep 14, 2015 08:18 AM
