1986 IROC Center Caps w/o IROC Logo
Car: 82 Z28
Engine: 383 SBC
Axle/Gears: 3.50 9 inch
I have a 1982 Z28 with the 16" IROC rims. They look good, but I would like to have center caps that say nothing, or Z28 (preferred). I don't want the IROC logo since it doesn't match and its not an IROC. Does anyone know where I could purchase these? Or perhaps ideas of how to make my own?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 1986 IROC Center Caps w/o IROC Logo
As far as I know, no one manufactures anything like that.
JamesC
JamesC
Car: 89 Firebird
Engine: 5.7
Axle/Gears: unkown
I don't believe any of those will fit an IROC 16" wheel. If so, please confirm.
JamesC
JamesC
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
I have Z28 badges on my 16" IROC rims, the PO did it somehow.. i'll take a look and see if i can figure out what he did.
Yes, weird to have Z28 badges on IROC rims on a RS..
Car: 82 Z28
Engine: 383 SBC
I appreciate the response, and please let me know how you got those Z28 badges on your iroc rims. Something like that would be great.
Car: 89 Firebird
Engine: 5.7
Axle/Gears: unkown
Car: 82 Z28
Engine: 383 SBC
They clip in, but I'm not against a red neck fix if it comes down to that.
Car: 1987 Camaro Z28, 1989 TTA #922
Engine: lb9, 3.8L turbo
Transmission: 700r4, 2004R
what color are your current iroc z badges on the wheels
Engine: 450HP 355
Transmission: TH350
Mine appear to be glued on, looks like some kind of epoxy.
If you want pics just let me know.
Car: 82 Z28
Engine: 383 SBC
Seeing the parts of the cap may be helpful. Check post #6:
https://www.thirdgen.org/forums/body...nter-caps.html
JamesC
JamesC
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Which wheels do you have? the 85-87 style or the later style?
I had a set of the early wheels that I sold because of the lack of any cap availability other than IROC caps. Didn't want to put those on my RS
Car: 82 Z28
Engine: 383 SBC
Well shoot, I read the thread a couple time to look for that information and totally missed it in the title
Engine: 450HP 355
Transmission: TH350
You can kinda see a little bit of epoxy squeezed out the one side.
I keep meaning to take the Z28 ones off of mine, need to just get some bowties or something.
Car: 82 Z28
Engine: 383 SBC
So where did you get those Z28 badges? Are they badges from the 15" wheels just epoxied onto the IROC rims. I am good with this solution, I just need to know what will fit.
Engine: 450HP 355
Transmission: TH350
I do vaguely remember the guy I bought them from saying something about taking the covers off of some other rims and gluing them on. It's been several years though.
If they'll come off i'd just trade you for yours.. lol
They should clean up and look good, i'll have to take a better look though.
Car: '86 Iroc
Transmission: 5-speed
Is this what you are looking for? http://www.gmsportssalvage.com/?q=node/781
I've seen them on Ebay too. I'd be interested in your old ones too.
those are for the 15" wheels with the black plastic caps. too large for the center caps of the iroc wheels
Engine: 450HP 355
Transmission: TH350
Mine will pop right out so if the OP wants them just PM me...
Car: 82 Z28
Engine: 383 SBC
I've been searching for something like this for a while myself. With IROC rims on my sport coupe, a centre cap with no logos is my preference.
One thing I've considered is to have a machine shop produce some from aluminum bar stock. The bar could be turned down to the appropriate O.D. and then parted off at a reasonable thickness. Sort of like a solid aluminum "slug" or disc.
Epoxy would then be the way to go.
I'm just not sure what a shop might charge to slice off four discs though. You would think it wouldn't be much more than what a used set of OEM caps is selling for on E-Bay. Around 60 bucks.
Car: 82 Z28
Engine: 383 SBC
I found a solution that worked well for me (only took me 2 years to find something I liked) and if no logo is what you want skinny z than I found a good solution for that as well. Only thing is you will have to install stang parts on your camaro....
I took these center caps (6.99 a piece): http://www.americanmuscle.com/silver...enter-cap.html
and put a 2-1/4" dia. Z28 decal from a 1996-2002 10 spoke rim (10.99 for 4).
I cut off the tabs on the back since it clearly won't snap in and just put a touch of epoxy on them. They fit nice and tight and this is what it came out like.
nice tip! a chevy bowtie would look nice too
I went through the same dilemma. I wanted IROC wheels, but not to badge them as one. I took the center piece out of the caps and got 4 chevy cruze center caps. Ground the lip off that was crimped around the plastic and the metal face fit perfect inside the old cap. I used stuff called e6000 to glue them, though I cut them so tight it prolly did not need it. It's not easy getting a perfect circle, but that was my solution.
dude.....
but.. those caps wouldn't work on the wheel we are talking about. The 85-87 cap size is different than the 88-90
Car: 82 Z28
Engine: 383 SBC
I'll tell you what. If I had to cut a perfect circle they wouldn't look like that!
thanks. I searched around a lot for stickers and all the other options of caps that fit for a while. Then the wife had a cruze rented when some idiot Tboned her charger and I got to looking at them and did some measurements........
Edit; Sorry just saw the different size quote. Anywho, gives you another option to think about. Measure and check around on other cars.
I went through the same dilemma. I wanted IROC wheels, but not to badge them as one. I took the center piece out of the caps and got 4 chevy cruze center caps. Ground the lip off that was crimped around the plastic and they fit perfect. I used stuff called e6000 to glue them, though I cut them so tight it prolly did not need it. It's not easy getting a perfect circle, but that was my solution.
I like the look of the both of those. Those Mustang caps are cheap too. Did you have to modify them like the Cruz caps were?
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
ambainb
Apr 25, 2016 09:21 PM
kah992
Aug 19, 2015 02:55 PM
mustangman65_79
Aug 11, 2015 03:17 PM
