z06 17 inch wheels with 275/45s. spacer size??
Old Apr 24, 2013 | 09:46 AM
86Stevo's Avatar
Hey guys.
I tries searching and couldn't find an answer but I am looking to get a set of z06 rims 17 inch with 275/45s on them. Mybuddy came up we put them on the car and they rub front and rear.
Was seeing if any one has this set up or close to it on there car. I wanna no what size spacers I need. I have disc brakes all the way around and stock rear I might swap it out for a 12 bolt but that's no time soon.
Anyideas will help I was thinking 1 inch all the way around but wasn't sure.
Old Apr 24, 2013 | 10:25 AM
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
Re: z06 17 inch wheels with 275/45s. spacer size??
2 inch
if you get a 12 bolt get a 4th gen style it will bolt in and you wont need spacers for newer wheels anymore
Old Apr 24, 2013 | 10:27 AM
lunati397's Avatar
hawks third gen has the spacers
http://www.hawksthirdgenparts.com/pr...Third-Gen.html
Old Apr 24, 2013 | 10:29 AM
86Stevo's Avatar
Alright so ill get 2inch all the way around for now and when i get a rear it will be 4th gen style then no rear spacers.
Do I need to modify the fenders at all so they don't rub? My car isn't lowered yet..
Old Apr 24, 2013 | 10:34 AM
lunati397's Avatar
nope they will fit
this is 17 inch ss wheels with spacers on the front and 4th gen rear 275 tires up front and 315 rear
Old Apr 24, 2013 | 10:35 AM
86Stevo's Avatar
Awesome nice car I like the tail light covers.. can you still see the brake lights threw those ?
Old Apr 24, 2013 | 10:38 AM
lunati397's Avatar
yeah the lights came through pretty good they have been on the car since 99 lol to bad it dosnt look this good now a move and selling the motor that was in it then turned it into a storage rack and it took a beating but its currently getting brought back to life right now and will have new paint better body work and a turbo ls3
Old Apr 24, 2013 | 10:45 AM
86Stevo's Avatar
Sounds nice mine got into an accident Ian preppibg the front for paint and then its all set to go ....again... Haha but atleast it was just a minor accident
Old Apr 24, 2013 | 01:32 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Do you mean 275/40/17?
Old Apr 24, 2013 | 02:38 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
I was just about to ask that question...
Old Jun 6, 2013 | 12:53 PM
86Stevo's Avatar
Yes I did mean 275/40/17 but he's trying to get me to run something like a 275/80/17 but thats going to pretty tall of a tire right?
I'm kinda set on 275/40's I think they look nice on our cars I never really like the super thick tires but i don't like rubber bands either
Old Jun 6, 2013 | 01:17 PM
paul_huryk's Avatar
I've never seen a 275-45 or 275-50 car tire for the 17" size, if that is what you mean...
The 275-40-17 size is excellent for a few reasons:
1) It is 30mm wider than the largest 3rd gen OEM size of 245-50-16
2) There are something like 40 different tires availabile in that size
3) A 17" x 9.5" wheel and tire is not all that much heavier than a 245-50-16 sized one in most cases, once you move up to 18" and larger the weight goes up (more metal than tire)
4) 17" tire with a 25.75" diameter is an excellent tradeoff of sidewall to wheel ratio - add that to a 30mm increase in width and you can totally change the handling of a car - with just a change of shoes
Old Jun 6, 2013 | 02:46 PM
Car: 1971 Camaro
Engine: 427
275/80/17???? Thats a huge tire!
I don' think it even exists.
BFG makes a 275/70/17, in an All Terrain Truck tire!
Thats a 32.2" tall tire!
Old Jun 10, 2013 | 02:45 PM
raiuno81's Avatar
hi everyone, so im looking to put C6 Z06 18x8.5 fr and 18x9.5 re.
does it have to be 2inch spacers or will 1.5in work?
also, does anyone have a similiar setup and with a lowered car and have problems with tires touching the top of the inner fenders or quarters going over speed bumps or small pot holes?
thanks for any info!
Old Oct 16, 2013 | 08:17 PM
91Z06's Avatar
So did the 2 inch spacers all the way around work? i have a 91 rs with a ls1 swap im putting the same rim and tire combo on 275/40/17 kuhmos on it and would like to know the results that you got with the two inch spacers?
Old Oct 17, 2013 | 02:48 PM
llcamaroguy's Avatar
Car: 1986 Camaro Sport Coupe
Engine: First Gen 350
I have an 86 with 18s up front and 19s in the rear and used 2" spacers off ebay and the fronts fit perfect with a 245/30/18 tire on it. The rears however rub somewhere even with a 2.5" spacer. I think 275 out back would not rub on 17s or 18s
Amillionoh7
May 24, 2020 08:01 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
toronto formula
Nov 10, 2015 06:17 AM
knight72
Aug 10, 2015 09:32 PM
TMZIrocZ350
Exterior Parts for Sale
Aug 8, 2015 05:55 PM
