19 wheel tire combo
Car: 1989 IROC-Z
Engine: 5.7
Transmission: T56 6 Spd
Axle/Gears: 9 Bolt 3.70
19 wheel tire combo
I have read threads until my mind is about to explode trying to figure out tire fitment for my 89 IROC. Car will be lowerd on Hotchkiss springs. Want to have good tuck and little or no rub under normal driving/parking circumstances. Can roll front and rear lips and don't mind some light hammer work to clearance. Would prefer not to run spacers. From what I have looked at, it looks like 19x10 rears with 295/35/19 and 5.5 backspacing should give me what I want in the back. On the the fronts, I'm looking at 19x8 with 245/35/19 and 4.5 backspacing. Probably most unsure if I am doing the right backspacing. Likely doing a Boyds wheel, so I have some flexibility with Back Spacing. Has anyone got any pics with this tire/wheel size combo? I have looked but haven't seen much with 19. thanks!!
Should also note that car has factory rear disc brakes and I am upgrading to LS1 brakes for the front.
Car: 1989 Formula 350
Engine: 383ci, +150hp N20
Transmission: Built 700R4
Axle/Gears: Moser 9", 3.73 Detroit locker
Re: 19 wheel tire combo
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
6-6.5" would tuck them in. My 19x10's are c6 vette take offs and are 8.11" or so backspaced i believe 79mm offset so it should be 8.11". I have 4th gen spec rear which is almost 2" wider, probably 1.875" wider per side and i have a .625" spacer on wheel. So thats almost 2.5-2.625" of space added, which should mean 5.5-5.6" backspacing would work for a 3rd gen rear. Mine are just inside fender lip, with 305/35 tire. Heavvvvy inner well work to prevent rub
Car: 1989 IROC-Z
Engine: 5.7
Car: 89 Iroc-z
Transmission: TH400
Heavy hammering with 2-3 lb sledge and some minor cutting to clear my 27.5" tall drag radials. It only has maybe finger thickness of room still before touching well, but doesnt rub from what i can tell. Tire is just under outer lip tho. Didnt roll lip but looks like it will clear if it ever squatted down that low
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
I have 19s all the way around, but my bs and mounting pad were altered to accept the Brembo brakes off the new SS. I have a nice tuck, with no rub at any corner. An adjustable panhard bar makes life a lil easier also.
Car: 1989 IROC-Z
Engine: 5.7
Copchaser - Do you know what your rim sizes, backspacing, and tire sizes are? I have seen you car and like the combo you are using. What type of mounting pad mods did you do? I already have an adjustable panhard bar to install with the rest of the suspension mods next month.
It's been a while, but I believe the front bs was 5.75 and the rear was 6.0. Mounting pad is .5inch on all four. 19x8 255/35s.. 19x10 295/30s
The sheet metal is 2 or three layers thick..(can't remember) in the bumpstop area. I cut it out and welded in a patch panel. I've got and extra 2-2.5". No fender rolling was required. 6.25" bs and a rolled fender should be fine....with some inner hammering or cutting but definitely the best look in my opinion. Either way if you go less I don't think you'll be happy with the look. (Based on what I've gathered from this brief post)
