My new wheels. 17x9 & 17x10 OG San (cross-lace style)
#101
Car: 1986 IROC-Z28 & 1987 GTA
Engine: 305 TPI & 350 TPI
Re: My new wheels. 17x9 & 17x10 OG San (cross-lace style)
I'll have some pics up this evening.
I read that if you use 1/4in spacer its okay not to install xtended wheels studs. The one recomended by the OP is 5/16.
I'm gonna try & use a 1/4in.
I dont have anything against extended wheels studs, I just dont have time to get it done this wk. I'm going to that MHTG meet in colorado & I have to leave friday 4a!
To OP:
Did you use 5/16 to get a desired look? Or will they not fit properly with anything less?
To OP:
#102
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
You should be fine with using a 1/4" spacer.
If the OP (original poster) only had 1/16" of clearance with the 5/16" spacer, he has problems.
The only clearance item on the front with these wheels is the end of the tie rod. I know with 18" rims the tie rod end fits inside the wheel, not sure about 17s.
#103
Car: 1987 GTA Vert & 1991 GTA 5 Speed
Engine: 87 GTA-L98 91 GTA LB9
Transmission: GTA-700R4 & GTA T5
1st: These wheels look fabulous!
2nd: I will probably end up buying them if wobble nuts will remedy the issue with the difference in our bolt pattern and theirs.
3rd: Why is it so hard to get a company to make these mesh wheels in 18s? Just make the darn things! Is the market that small for these in 18s? I mean damn!
#104
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
there are 18" versions out there and larger but they are going to be 2 piece wheels and are going to cost at least $1000 per wheel , that's why you don't see them lol , rotiform is one company that I know off the top of my head I'm sure there are others
#105
Engine: 4++,350 & 305 CIs
Both cars look great! Cant wait to see the others!
#106
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
3rd gen wheels have a very specific offset and when you start talking 9.5" wheels, they don't fit much else. So you are almost automatically talking multi-piece wheels that are going to start at $750/each and up.
Yes, the market is tiny for $750/each 18" x 9.5" wheels in a mesh pattern to fit the 3rd gen applications.
#107
1 Post
Car: 1989 G92 IROC-Z
Engine: 5 Liter 305
Axle/Gears: 3.45
I was gonna say the Firebird guys are going to be all over this, but they already are! lol
#108
Problem is that you have to do a lot of engineering to make mesh wheels work - forged or cast - or if you CNC them it takes a lot more machine time to cut them compared to a 5 spoke wheel of the same diameter.
#109
But if you can make them at will from different hoops and sections like a 3pc wheel is made, then you can make them as ordered. Of course that type of manufacturing is super expensive and is based on convenience, not volume.
#110
Here is another since I could only put 3 in that post. This one is expensive too. I think almost 3k for 4. They offer our bolt pattern on the wheels though, if I read their info correctly. These come in 19" only by SSR wheels.
By the way I'm itching to see these on a GTA. Is there two guys now with birds waiting to mount the OG wheels on them?
#111
Car: 91 Camaro Z28
Engine: 5.0L LB9 305 TPI
Transmission: 5 spd
Axle/Gears: 3.42 Rear End
Slowridr, I sent you a reply. You will love them. Post pics once you mount them. Can't wait to see them on.
#112
#113
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
so heres my question people keep talking about the spacer but if my math serves me right a 9 inch wheel with 10mm offset should be around 5.325 backspacing. should take much for a spacer on front or rear correct?
downshift which wheel size and offset did you go with because you car looks great.
#114
Engine: 305 to 350
Axle/Gears: 10 Bolt
You can run more backspacing than that but depends on a number of things like how much you want to tuck or be flush with fender also rim size and design to include rim specs as there some limitation like front hub etc and among other things also if you want to do inner fender work Also plays a part
#115
Car: 91 Camaro Z28
Transmission: 5 spd
Thanks ziggy89, the set up on front is a 17x9 +10 and rear is 17x10 +15.
#118
Car: 1988 trans am gta 5 speed t top
Engine: 5.0
Axle/Gears: 373
I'm liking the gold wheels man I just finished my new wheels and tire setup. What you think ?
#119
Car: 91 Camaro Z28
Transmission: 5 spd
#121
Engine: 5.0
Axle/Gears: 373
#123
Engine: 5.0
Axle/Gears: 373
Thanks man...I feel that it's wrong to take away gold from a gta that's why I got rid of the draglites
#124
they took the page down...did they stop makeing them i realy want these wheels for my 1992 t/a anyone know a reputable dealer were you can get these
#125
1 Post
Car: '88 Trans Am GTA
If they did stop, that really sucks. I was thinking of these when I replace my tires since I don't think I'll be able to afford Rotiform LHRs any time soon.
#126
i talked to people on tire rack they have discontinued them
#127
Car: 91 Camaro Z28
Transmission: 5 spd
Bummer, I was not aware they discontinued them. I would have picked up a set of gold ones had i known.
#128
Car: 91 Camaro Z28
Transmission: 5 spd
7 years later these are still in great shape and now for sale. Link below.
https://losangeles.craigslist.org/la...110787029.html
