wheels and tires
Old Aug 14, 2013 | 02:09 AM
camaroman83's Avatar
wheels and tires
hey guys i was just wanting too see a few pictures of the street strip look with a 15x7 inch rim in the front and the smallest tire you could run on that and then a 15x8 inch rim in the rear with the widest tire you could run that doesnt stick out terribly past the wheel well, any body have some pictures? every ones welcome ide love to see!!!!
Old Aug 21, 2013 | 10:19 AM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Re: wheels and tires
No pics, but a 195/70 will fit a 15x7 front, and a 295/50 will fit a 15x8 rear.
Old Aug 23, 2013 | 08:43 AM
Qwietstorm03's Avatar
Car: 91 Camaro RS
What's the backspacing for that rear?
Old Aug 24, 2013 | 07:49 AM
cosmick's Avatar
Order 4.5" or 5", depending on how you feel about them sticking out versus rubbing the inner edges. I'd start with 4.5", but you can always space out the five inchers.
Old Dec 9, 2013 | 06:08 PM
4.5 backspacing for the rear and i want something wide but something that doesnt stick out past the wheel flare at all, sorry for the late response
Old Dec 10, 2013 | 05:37 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
My favorite combination.
235/60r15 on 7in. front and
255/60r15 on 8in. rear
Old Dec 10, 2013 | 07:16 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Front wheels are 15x4's (can't remember the tire size, but they are skinny)
Back wheels are 15x8's with 275/60/R15's.
No clearance or rubbing issues.
Old Dec 10, 2013 | 11:42 AM
Engine: TBI,5.0
RedLeader289,
What is the BS on your rear wheels in the photo above ?
Old Dec 10, 2013 | 11:52 AM
Car: 1983 Z28
Ron: The bs on my rear wheels is 4.5" I believe.
Old Dec 10, 2013 | 03:50 PM
what is the backspacing on your rear wheel?
Old Dec 10, 2013 | 03:51 PM
what kind of tire are you running in the rear?
Old Dec 10, 2013 | 04:40 PM
Car: 1983 Z28
Verified and my rear wheels have a 4.5" backspacing.
As for the tires, they aren't anything special, just a generic radial, I think they are rated to 120 or 130mph or something, just a street tire. They are 275/60/R15.
Old Dec 10, 2013 | 06:02 PM
oh okay now, do you have any rear end work or is it all stock? and do the tire stick out past the wheel flare? do you possibly have any side angles or a strait view from the rear?
Old Dec 10, 2013 | 07:42 PM
Car: 1983 Z28
No rear end work, it is a stock 9 bolt out of (I think) an 87 IROC, but I never saw the rest of the car (just came across the rear end, if you follow me). It all bolted up just fine with no adjustments, so that leads me to believe it hasn't been modified.
The only thing is that I have monroe shocks, they are the OEM size, but are gas shocks so they provide the tiniest amount of air. (NOT to be confused with air shocks).
The tires are tucked nicely inside the lip of the fender, I've attached some pics. I apologize for the lighting.
Attached Thumbnails wheels and tires-img_20131210_191934_159.jpg   wheels and tires-img_20131210_192025_084.jpg   wheels and tires-img_20131210_192142_136.jpg
Old Dec 10, 2013 | 07:43 PM
Car: 1983 Z28
Also, here is a pic that verifies my tire size
Old Dec 10, 2013 | 09:27 PM
very nice, so i guess ill go with the, 275/60 as well because i have american racing 23 rims on my car 15 x 8 with the same 4.5 backspacing i was just worried that the 275 tire would run past the lip and look like a 4x4 pick up if you know what i mean, and if you would ever be interested in selling your draglites let me know ide love to have some draglites but there more expensive than how much i paid for the car once you get some tires on them, and i aprieciate the pictures
Old Dec 10, 2013 | 09:29 PM
btw you dont have any wheels spacers? i have half inch wheels spacers on each side of my rear
Old Dec 10, 2013 | 09:30 PM
since you have the same wheels as me have you had expieriance with 275/60/r15 and on your 255s do you have wheel spacers?
Old Dec 10, 2013 | 09:42 PM
Car: 1983 Z28
No problem, and if I decide to sell them I'll definitely post them up on here, that might be a while down the road though. Can't tell if you're asking me about the wheel spacers or Ron, but I can say that I don't have any wheel spacers. The "quote" button helps to direct your specific question to people. Post some pics when you put the new tires on!!
Old Dec 10, 2013 | 09:54 PM
oh i definitely will, and i appreiciate the help freind!!
Old Dec 10, 2013 | 10:18 PM
Engine: TBI,5.0
No spacers. If you running AR-23s in 15in. then you have a 3.75 backspacing. They are in the same class as the AR-Outlaw series that also only come that way. The 255/60r15 is the largest tire I can fit without it sticking out to far. At least for me it is. I got lucky because the AR-23s in that BS are perfect. The bulge of the tire is flush with the flair and the tread just tucked into the well. Exactly the way I like them.
You might call around to shops and see if they have that 275/60r15 in a used tire and have them mount one on your wheel just to look if that's acceptable. If they charge you $20.00 to rebalance the one you have now so what. Don't spend good money on a nice set of tires just to find out they don't fit. Once you have mounted a new tire it’s yours.
As you can see in the last photo the 255/60r15s are not small tires. Those are 235/60r15 front.IMO anything more than that belongs on a track car.
Old Dec 10, 2013 | 10:27 PM
okay, i love your car, so if the 255/60/r15 is flush on your car then the 275/60/r15 would stick out about an inch or two wouldnt it?
Old Dec 10, 2013 | 11:30 PM
Engine: TBI,5.0
According to Summit Racing =
255/60r15s
Section width = 10.2in
tread width = 8.2in
overall diameter = 27in.
275/60r15s
section width = 11in.
tread width = 8.9in
overall diameter = 28in.
section width = .7in difference
tread width = .7in difference
diameter =1in difference.
So they might be out around 3/4in. further .
If they rub at all I would say install some Moog 5665 springs rear and a set of KYB Gas-a-just shocks. That should give you a nice stiff ride with very little bounce.
Old Dec 11, 2013 | 01:08 AM
okay thanks i appreiciate it im gonna try that out by buying one used tire and see what happens
Old Dec 11, 2013 | 09:52 PM
i decided to order a set of the draglites, do you drive on the 15x4s alot? and do you have any different angled shots of your car like a strait front end and a side shot?
Old Dec 11, 2013 | 10:58 PM
Engine: TBI,5.0
A 15in.x4in. wheel on a street car is really pushing it. You’re talking about a typical tread width of 4in. on the ground. On a straight track yes but jumping on the freeway at 55/65 on a circle ramp in the rain is just asking to slide into the wall/rail etc. I don't know what you're going to use this car for or how much HP you have but IMO a street car needs to have some tread on the ground. With the large 275s and a decent amount of power every time you accelerate at WOT or anywhere near that the car wants to lift the front. That means less downward force holding the car on the ground. 4in wheels and a tiny tire = trouble on the street.
Those that only use their cars as "weekend warriors" in perfect weather or trailer queens that only see a track than you might get away with it. If you drive your car like me, every day, rain or shine then wheel and tire size is very important for safety reasons.
I found this photo and even though its a very nice car I would think twice about driving it in the conditions described above. =
http://carphotos.cardomain.com/ride_...0064_large.jpg
Old Dec 12, 2013 | 07:11 AM
Car: 1983 Z28
I totally agree with Ron on this one, man. My car is simply a weekend warrior, never gets driven in the rain, etc. Even though I only drive it once or twice a week I still plan on swapping my 15x4's to a 15x7 up front this spring just so I can have some cornering ability(and make it safe to drive in the rain if I ever had to). I love the look of the skinny's, but after having them for a few years now I'm kind of over it. I still plan on keeping the meat in the back but that's just my personal view.
I couldn't get a good shot of the front of my car (it's in the garage, taking it's winter nap....nose first, so I can't really get a pic of the front lol). But it looks EXACTLY like the pic that Ron just linked in his post. It's a mean look, but you may wanna consider a wider front.
Also, I got my 'draglites' from Jegs, their name brand runs a little cheaper than the Weld's do, and look just as good IMO.
Plus the skinny's make braking harder (sudden stops that is).
Old Dec 12, 2013 | 09:03 PM
yeah thats what i was afraid of maybe ill just keep my american racing and see if i can get a 275/60 rear tire that looks decent i really apprieciate your help guys
Polo Z03
Wheels and Tires
49
Jul 21, 2017 12:31 AM
LT1Formula
Nov 16, 2015 01:13 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
overdriv
Aug 20, 2015 03:52 PM
forstral
Aug 19, 2015 03:20 PM
