Lost rim key
Car: 84 Camaro Berlinetta
Engine: 350 bored and stroked
Car: 1987 IROC Z
Transmission: Automatic
Re: Lost rim key
Just had to do the same thing yesterday for mine. I had realized I didn't have a key to my rims when I bought the car. Getting the lock off was the easy part. It was getting the lock out of the socket that was he work. Mind you it was 37 degrees here in Chicago.
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
Re: Lost rim key
the key for my RS matched my Iroc, go to a junk yard and try to find one, im almost positive they are all the same, or there are only a few variations like the ignition key values
Car: 89 Camaro RS
Engine: 2.8 V6
Re: Lost rim key
I needed tire replacement the other day.... Had found the packaging with old lug nuts but no key... No problem, they just did the 20mm 12pt socket routine for me at no charge
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Re: Lost rim key
Autozone used to sell and rent a set of lock removers. Maybe they arent allowed to sell them anymore...but they seemed to work well. I have a set that I picked up when I worked there and they were "manager dispose". No one else there knew what they were, and the label fell off the box...hence them being damaged out LOL.
Socket will work though.
J.
J.
Car: Pontiac 89 GTA
Engine: 350 TPI 5.7L V8
Re: Lost rim key
My GTA didn't came with the key so I look on ebay and found some original Key with the Original Nut. I bought them thinking the key will fit and it didn't so I put a 21MM with a hammer an took Out the old and put the new and know have the new original Key.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Lost rim key
Might I suggest covering the rest of the wheel with towels/etc. in case you slip with the tools. I would be very upset if I damaged my wheel in any way.
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
If u can't get it off with a socket use a cold chisel and a beater ... Use the chisel to make a notch in the lock nut and tap (beat) it around in a circle ... BE CAREFULL !!!! .... A shorty 2lb beater works good
Engine: TBI,5.0
Re: Lost rim key
So you have actually done this?
It takes a "considerable" amount of pressure with a "lug wrench" to remove lug nuts that have been tightened by using a lug wrench.
Engine: L03, LB9
Re: Lost rim key
if you are willing to take a chisel and hammer to the lug nut you might as well split the whole thing off and buy a set of 4 lug's to replace the keyed lugs with
