zo6 spyder wheels, need help
Old Nov 19, 2013 | 06:03 PM
morrow's Avatar
Car: 92 Camaro Rs.R
Transmission: wc t-5
ok im thinking about going to a 19 inch wheel
the set i found are the z06 spyder wheels. i would like to do 19x10 up front and 19x12 in the rear, currently im using z06 motorsport wheels 18x 10 all the way around... i would realy like to get away from the 2 inch spacers i amusing and find a wheel with the correct offset and bs...
i can live with using a 1 inch spacer up front but if i can find a rear with the right spacing or atleast very close that would be nice... the wheels state to be 19x12 with +59mm i found a chart that states that is about 4.18 inches of back spacing, im using a iroc rear end... ummm anyone have any idea how this will fit up?
Old Nov 19, 2013 | 06:34 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: zo6 spyder wheels, need help
No, that 19x12 has a little over 8.5" or back spacing. It will NOT fit the car without a minitub. But oddly enough thats aboit perfect backspacing to fit on a 3 rd gen rear once the car is minitubbed. They would fit my car perfectly
Old Nov 19, 2013 | 06:40 PM
morrow's Avatar
Car: 92 Camaro Rs.R
what spacing would i need to make the wheel fit without a mini tube, im thinking of cutting and pulling fenders, wider is always better lol
Old Nov 19, 2013 | 08:41 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
6.5 is the most you will fit with only some hammering, but it will stick out quite a bit
Old Nov 19, 2013 | 08:51 PM
morrow's Avatar
Car: 92 Camaro Rs.R
im sorry its -59mm not pos 59....
Old Nov 19, 2013 | 08:53 PM
morrow's Avatar
Car: 92 Camaro Rs.R
so with a 12 inch wide wheel, i would need like -6 mm ... which should make 6 inch back spacing
Old Nov 19, 2013 | 09:15 PM
morrow's Avatar
Car: 92 Camaro Rs.R
i also just found another wheel i like, its 19x10.5 with +25mm offset... the chart says 6.75 inches of back spacing
Old Nov 20, 2013 | 08:36 AM
86iroct5's Avatar
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
a link to the rims would help, -59mm will in no way work unless you narrow th rear and tub it. typically vette rims have high offsets, +59mm sounds right. -59 sounds wayyyyy off
Old Nov 20, 2013 | 12:42 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
That wheel will work with a 10mm spacer and some really light hammering
Old Nov 21, 2013 | 08:34 PM
morrow's Avatar
Car: 92 Camaro Rs.R
good cuz that whhel is sick, ill post a link
http://www.ebay.com/itm/19-MRR-GF6-CONCAVE-WHEELS-RIMS-BMW-E60-525-528-530-535-545-550-/281165629100?pt=Motors_Car_Truck_Wheels&vxp=mtr&hash=item4176c706ac
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
drptop70ss
Oct 4, 2015 09:44 PM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
