Does 235/60/15 fit on a stock height camaro?
Old Dec 7, 2013 | 07:08 PM
JessieJames's Avatar
Car: 88 Camaro
Engine: 305 TBI
Does 235/60/15 fit on a stock height camaro? its 1988, order new tires soon, looking a bf goodrich for my 15 inch rims. i know this tire will fit in front and rear as is. however can they fit in the front of the car without rubbing if wheel is cut all the way?
thanks
mark
Old Dec 7, 2013 | 07:42 PM
bedbed's Avatar
Car: '82 Z28
Engine: 305 LG4
Transmission: 200c
Re: Does 235/60/15 fit on a stock height camaro?
Mark
Running that size front/back on my '82 Z28 with stock 15" rims. No clearance issues. Look good IMO. Will, although put your speedo out about 10%. Not much difference cruising around town but flying down the highway?
Ron
Old Dec 7, 2013 | 07:50 PM
Car: 88 Camaro
Engine: 305 TBI
Originally Posted by bedbed
Mark
Ron
look good IMO, as well. i also run 37's on my uncalibrated silverado speedo which has 30's factory so I'm use to an inaccurate speedo, running 235/60-15 on my camaro will be running around 26's on a speedo calibrated for 23 inch tires about. will cause my speedo to be around 5% off, (speedo will read lower then I'm actually going). this doesn't bother me, as long as i don't trash my new tires as they rub on my frame as soon as I'm trying to pull into a parking spot. thank you for information.
thank you Ron!
Old Dec 7, 2013 | 10:20 PM
Blue 90 RS's Avatar
Car: 1990 Camaro RS
Engine: 5.0L
Transmission: WC T5 5-speed
I run 235/60R15 BF Goodrich Radial T/A's on my 1990 RS that's been lowered one inch with Eibach springs and have no issues whatsoever. No rubbing at all and look pretty good, too.
Old Dec 7, 2013 | 10:30 PM
Car: 88 Camaro
Engine: 305 TBI
thanks for input, i was thinking about buying "cooper cobra radial GT" instead of the bf goodrich on the count of them being about 30+ dollars cheaper per tire. and still have the raised white letters i was looking for. the tire tread pattern isn't the same, although is similar. discount tire direct has the cooper cobra radial GT's for around about 410$ shipped to my door. where the bf goodrichs are around $500+ to my door. car is not my all season daily driver therefore all season traction is not a concern.
Old Dec 7, 2013 | 11:31 PM
nhgator's Avatar
Car: 1985 T/A
You can get t/a's at $128 each from tirerack,with shipping to my zip code it runs out to $138 each.
My X-mas present to myself is a new set of t/a's but I am going to take the tirerack price to my local shops and see if they can come close before I order them.
Old Dec 7, 2013 | 11:53 PM
Car: 88 Camaro
Engine: 305 TBI
What's price per tire of your local shop ? Mainstream /franchise shop like Ntb ? Or mom and pop ?
Thanks mark
Old Dec 8, 2013 | 06:48 AM
nhgator's Avatar
Car: 1985 T/A
Thanks mark
I haven't made any calls yet but the ones with internet prices run $145-$165 per tire,next week I am going to check 3 or 4 local places.
Old Dec 10, 2013 | 03:55 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Bfg>Coopers
Old Dec 10, 2013 | 04:31 PM
Cosmik Debris's Avatar
I thought 235/60/15 was standard on some models. The 215/65/15 is 26" the 235/60/15 is 26.1, so unless you've re-calibrated your speedo it should be good to go.
Old Oct 22, 2014 | 05:48 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
How are the cooper cobras?
Old Oct 22, 2014 | 07:36 AM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
they were. I have the sales brochure to prove it
Old Oct 22, 2014 | 09:43 PM
85_ZED28's Avatar
Car: '85 Z28
They will fit perfectly and not affect your speedometer.
Jeremys87
Jul 14, 2022 09:08 PM
customblackbird
Aug 15, 2021 10:16 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
sailtexas186548
Aug 26, 2015 03:32 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
