Another XXR 521 third gen - 1992 Firebird
Old Feb 18, 2014 | 02:47 PM
FooFighters92's Avatar
Car: 1992 Firebird & 2009 Nissan 370Z
Engine: 305 TBI
Transmission: W.C. T5
Axle/Gears: 4th Gen Posi, Disc Break/3.42
Just got them in the mail today. Still need to measure for tires, but will post pics as soon as they are on! P.S.- sorry for pics, just from my Note II will get better ones soon.
Specs are 18x10 all around with a +12 offset and a 3.5" lip. They are flat black with chrome rivets.
Suggestions on tires?
Old Feb 18, 2014 | 08:49 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Re: Another XXR 521 third gen - 1992 Firebird
Nice do they come in 17X12 with the offset we need for our cars and can you get them with just our bolt pattern
Old Feb 18, 2014 | 08:55 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
You can go 275s or 285s all around
like in my thread I had 285/35s , price difference is minimal so I got wider tire tad more grip lol
Unless you want to run larger rear tire like a 295 and 285 front
Old Feb 18, 2014 | 09:08 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
275 or 285 fits on the 10". Suggest you get 4 of the same size to rotate...
Old Feb 18, 2014 | 09:17 PM
Engine: LQ4 ls 6.0
Thats the way I have always done in the past I will be doing a lot of mods soon and that will include 76 mm turbo so Im looking for as much rubber as I can get under the car do you think I can get away with 335 in the front that would be sick if I could
Old Feb 18, 2014 | 09:31 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
I agree, but it is a option as some people like a larger rear tire
Old Feb 18, 2014 | 09:32 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
I think that would be a pinch with a 335
Old Feb 18, 2014 | 09:53 PM
Engine: LQ4 ls 6.0
Its not that Im looking for a badass look I just think that I will have a hard time trying to put the power to the ground
Old Feb 18, 2014 | 10:22 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
To fit 12in wide going to need to alot work to inner wheel on the rear ,
and street legal drag radial
But can accomplish in a 10" or 11" wheel
Old Feb 18, 2014 | 11:17 PM
Engine: LQ4 ls 6.0
Hey I have tools I can move things if need be but I dont think it would be that bad and as far as tires go I think Im going with the Bridgestone RE11 they seem to like them at the track
Old Feb 19, 2014 | 12:47 AM
Engine: 305 to 350
Axle/Gears: 10 Bolt
Cool should be fun project then , mini tub with 12in , theres a thread on it
xxr 521 doesn't come that wide tho in a 17in
http://www.nlmotoring.com/XXR-521-Wheels-s/1521.htm
Old Feb 24, 2014 | 06:07 PM
Engine: 305 TBI
As stated in my other thread for my car, I have a 4th gen rear end which sticks out an extra 2in or so than the 3rd gen rear ends, so when I mounted my wheels they stuck out quuuuite a bit. So I may have to switch back to a third gen rear end because I'm not a fan of that look.
Well anyway, my tires will be here on the 27th and I'm off all day so I will have pics then.
Old Feb 25, 2014 | 01:41 AM
Slash's Avatar
Car: 1988 Camaro IrocZ
Engine: Holley Stealth Ram 385 Stroker
Transmission: Redline Performance 700r4 Trans
Axle/Gears: Bulletproof 4thGen Ls1 SS Rear 3.73
That was my major concern on Zach's thread and why I didn't go through with them.. And i was only looking at the rims he got.. you got the better offset and they still stuck out alot? Damn i dodged a bullet... Sorry to hear of the misfortune man. My 4th gen rear is built up too much to just switch back to a 3rd gen rear.
Old Feb 25, 2014 | 09:20 AM
Engine: 305 to 350
Axle/Gears: 10 Bolt
Yea +12 offset is more ideal , can redrill bolt pattern and will be a direct bolt on but once you have 4th gen rear than they wont fit
Old Mar 16, 2014 | 10:18 AM
Engine: 305 TBI
Oops I completely forgot to post pictures...here you go!
Engine: 305 TBI
Old Mar 16, 2014 | 10:19 AM
Engine: 305 TBI
Old Mar 16, 2014 | 05:22 PM
lb9 GTA's Avatar
Car: '88 Trans Am GTA
Stretch and poke guys add negative camber to eliminate rubbing like that. Curious what's done to your suspension. I like how it sits though I wouldn't go that low with mine. The roads in Toronto are no where near good enough.
Old Mar 16, 2014 | 05:38 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Love the rims. Needs more tire for my taste. I don't care for the stretched look. Car looks great.
Old Mar 17, 2014 | 01:57 AM
Engine: 305 TBI
My fronts do have slight camber adjustment on them. Plus that buildup was just a small amount and was only after driving for about 5 minutes and never built up again, just wore a small path for clearance. My suspension is stock aside from springs, Eibach lowering springs, which have been cut. I do plan on building suspension at some point to soften the ride and hopefully maintain lowered stance.
Thanks man!
Old Mar 26, 2014 | 12:36 PM
Iroc Ant's Avatar
Car: 1990 Iroc Z G92
Engine: 350 5.7 TPI
Axle/Gears: 3:23
Hey guys,Thought I would share my 3rd gen on XXR 521s. Has a bit of poke on the rear, I know some folks aren't fans of that look, but I dig it.
Old Mar 26, 2014 | 12:40 PM
Iroc Ant's Avatar
Engine: 350 5.7 TPI
Axle/Gears: 3:23
Sorry for the horrible thumbnail post, I'm pretty new to the forum, not to savvy with it yet.
Old Mar 27, 2014 | 02:31 PM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Looks pretty good. What size and type of tires do you have? And those are +12 all around with no spacers, or is that a 4th gen rear?
Old Mar 27, 2014 | 05:19 PM
Engine: 305 TBI
If you're talking to me and not the guy above, I am running Dunlop Direzza 101's which are, aside from Falken 512's, the best tire to use for stretching. 235/45/18 all around. I have a 2" spacer up front and a 4th gen rear end.
Wheel specs are 18x10 with a +12 offset and a 3.5" lip
Old Mar 27, 2014 | 05:39 PM
Iroc Ant's Avatar
Engine: 350 5.7 TPI
Axle/Gears: 3:23
Thanks man. All 4 rims are 18x8.5 tires are 235 40 18. I'm running a 1.25" adapter for the front and a 2" adapter for the rear.. I plan to go with a 18x10 for the rear in the future with the +12 offset, possibly a 20x10, cuz I would like to run a fatter tire than a 235.
Old Mar 27, 2014 | 05:42 PM
Iroc Ant's Avatar
Engine: 350 5.7 TPI
Axle/Gears: 3:23
And the offset is +25 all around
Old Jun 25, 2014 | 01:07 AM
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
Once you stand on your head, it looks great!
Old Jun 25, 2014 | 03:15 AM
Engine: 305 to 350
Axle/Gears: 10 Bolt
Go get 10s all around sell those whimpy 8.5 lol
Looks god besides the near stock width
Old Jun 25, 2014 | 01:21 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I think it's a really nice look. Not something I would go out of my way to do but it definitely works on your car. I'd rock that look no problem.
What size tires did you end up going with? Did you end up using adapters? I was always worried the proper offset adjustment for BMW wheels would be somewhere in that no man's land between spacers and adapters.
And for the record, 17x12's are a complete waste of time. You're gonna have a REAL hard time finding anything wider than a 315 in 17s, and there's only 4 or 5 options in that size and most of them are Nitto. 315s fit on a 17x11 and a 17x11 is really the only thing that's going to fit well in a 3rd gen fender without a minitub.
Old Jul 13, 2014 | 12:37 AM
Rice01's Avatar
Car: 1988 IROC-Z Camaro
Engine: 383ci SBC
Axle/Gears: 2.77 9 bolt borg warner
Do you have part numbers and where you got those, they look amazing. also do you have to run spacers on third gen rear ends or was that just for a wider track
Old Jul 31, 2014 | 04:51 AM
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Not a huge fan of stretched tires but the car looks good!
I was looking at the same rims 12mm (5.97" BS) offset all around. Did you try them without the 2" Spacers up front? I'm sure they would fit almost perfect without rolling the lip etc on my car since I have C5 Z06 brakes which push out the track width 0.300 per side. If im doing my math right 12mm offset should be pretty damn close to perfect with a 10" wheel.
I know with a stock width rear they will fit perfect in the rear since i ran 15x10" rims on my last iroc with 6" backspace.
Either way looks awesome with that colour combo.
Jay
Old Jul 31, 2014 | 02:21 PM
Iroc Ant's Avatar
Engine: 350 5.7 TPI
Axle/Gears: 3:23
Hey buddy try this website http://www.nlmotoring.com/XXR-521-Wheels-s/1521.htm. And for the spacers it depends on the offset, if you get the +25 offset like I did you will need at least a 1.25" spacer on a 3rd gen rear, I'm running a 2" spacer cuz that's what I had to work with :/ Lol..... +12 offset you should be able to run them without any spacers
Old Aug 2, 2014 | 10:40 AM
Engine: 305 to 350
Axle/Gears: 10 Bolt
You can run less than a 1.25" spacer with +25 offset
Old Feb 21, 2015 | 11:05 PM
Justin69's Avatar
Car: 89 Camaro RS
Engine: LT1 w/ 70mm Turbo
Transmission: Stage 3 TR6060
Axle/Gears: 4:10
That looks awesome !
Old Aug 9, 2017 | 06:30 PM
rgauder's Avatar
Car: 1987 Trans Am
Will the +12mm offset fit over the front hub without a spacer?
Vintageracer
Jan 10, 2020 05:33 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
the_nikfive
Aug 11, 2015 02:46 AM
