XXR 531 18x9.5/11
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
XXR 531 18x9.5/11
As my swap comes to a end and finish small details
As you guys may know or seen is that I get bored easy with my wheels and haven't fully like a set of wheels fully . So decided to start saving for some custom ones probably issforged or something after I deploy. But in the mean time have bartered different sets of wheels
The 19s would fit perfectly and be easier but I'm biased towards 18s and I'm not fully sold on19 inch wheels I like more tire
I got the chromium black
How setup looks
http://www.horsepowerjunkies.com/for...d.php?t=141527
How setup looks
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
Axle/Gears: disk rear, 10bolt.
Re: XXR 531 18x9.5/11
i want to see these on there.. i wanted a set for my evo but ended up going a diffrent xxr route now that the evo is out of the pic i plan on these for my third gen.
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
those wheels are nice bro! i was looking for new wheels for mine as well and i ended up buying some hre wheels. Did you already buy those wheels or not yet i seeing some similar on craigslist
Engine: 305 to 350
Axle/Gears: 10 Bolt
Should look clean once mounted
I didn't really buy just did a little trade/barter but yes I have them pic posted is actual wheel
Engine: 305 to 350
Axle/Gears: 10 Bolt
Oh really yea I talk to a guy there seemed like a good guy and company I'll pm you tomorrow
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re drilled
Have a close retired military friend that does machine work for me mainly wheels
Engine: 305 to 350
Axle/Gears: 10 Bolt
I have 2 sets of adapters that go to 114.3
The selection of wheels are more available and easier to sell or barter that bolt pattern , especially out here in cali
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
I'm wondering about the 55lbs that a set of 9.5" with the 275-35-18s weight - ouch...
Engine: 305 to 350
Axle/Gears: 10 Bolt
Lol yea Paul but not to worried about that to much , been looking for track wheels for little events here and there but that's not priority right now and isn't a track only car so I keep that I mind
My xxr 521 where about the same weight and have no major complaints
The gain in width and larger tires and improved responsiveness feel and extra grip is worth it in my books for a daily driver
But you make a valid point
I believe stock wheels "iroc" weigh in about 22-24 lbs iirc with out tires
Car: 87 IROC,
Engine: 370 LSx With Boost
Transmission: 4L80E
Axle/Gears: S-60 with 3.50s
Engine: 305 to 350
Axle/Gears: 10 Bolt
Lol been searching for couple years now lol but been having funny trading and trying new wheels
Engine: 305 to 350
Axle/Gears: 10 Bolt
XXR 521 18x10
Budnik Gasser 18x8/18x10
Irocs 16x8
Varrestoen ES2 18x9.5/18x10.5
also had Vossen CV5 ,that i tried out that a friend had lying around really like them would look killer with brembos on front and rear they where 20" but im kinda bias to 18" size dont have pics but look like this
also had bbs reps kinda like the the XXR 521 18x10.5 all around no pics of those as they look similar to the XXRs
Irocs 16x8
Engine: 305 to 350
Axle/Gears: 10 Bolt
I had some steel wheels also when i first got the car but i wont post pics of that lol
Ideally i would like a retro iroc style wheel concave with lip 18x10 all around using a step lip
Was thinking of getting 18" irocs and widening them to 9.5 and do stock like color using gunmetal for the color with machined finish
Engine: 305 to 350
Axle/Gears: 10 Bolt
been saving for real set of wheels either ccw, rotiform, and I like one style from adv1 the list was alot longer lol
Just waiting after deployment...
Engine: 305 to 350
Axle/Gears: 10 Bolt
Regular brembo brake upgrade
What exactly you want to know ?
1 Post
Car: 2004 Mazda RX-8
Engine: 1.3l Renesis
Axle/Gears: \
Did you put it together or get it from a vendor? I had been looking at these wheels for a while but the fact that they don't make them in 5x120 turned me off... it never occurred to me to redrill them.
Engine: 305 to 350
Axle/Gears: 10 Bolt
What brake upgrade do you want ?
I kept on searching and always on Craigslist and eBay and other forum classifieds and scored a deal got both calipers forward under 200 if I remember all I did was painted and got new rotors and pads I probably have less than 400-500 into everything , I just gathered here and there only think I hot was hubs and bracket
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Wow, these wheels, your car, amazing. I'm looking to go 18's as well and would like all 4 corners to be the same for ease of tire rotation and buying sets of 4 rather than 2 and 2. Anyway, thanks for the great pictures. Looks like 18x9.5 is what I'll end up going with, stretched tires and rolling the fenders. Can I get a shot with the car on the move? Would like to see the suspension travel and how the wheels tuck when the suspension is working. Or maybe tighter pictures of the fender to tire gap. Thanks a lot.
Engine: 305 to 350
Axle/Gears: 10 Bolt
Don't need to roll fender for 9.5 fits well within fender
I would recommend 19x10 setup as it comes in 5x120 pattern and would be simple setup
Car: 89' IROC-Z
Engine: LO3
I'm looking into extended a-arms and will try and match the spacing in the rear. A differential swap may change this. Thanks for the info. I know 9.5" fit fine, but I don't like the lip in the fender, nor do I like bubble tires. You may be thinking of 'pulling' the fender, I'm just looking to 'roll' that lip up, not pull it out for clearance. Going for the "Hella Flush" look, just not so much like the "Hella Flush" style you see when searching those words. I just want the tire to just miss the fender during travel into the fender well. Thanks again for the info. 19's may be going to the bigger side of things. I was thinking 17's in the beginning. 18's are right there in the middle.
Engine: 305 to 350
Axle/Gears: 10 Bolt
I'm very aware of what you going for
Honestly extended a arms would be custom suspension route and the amount of money you would invest since there's no over the counter a arm like that is just waste time and money ,
Upgrading your brakes to ls1 setup pushes out front about .3"
A brembo setup and 1le hub pushes front out about .6"
And that matches the rear width but not exactly
Your better off just getting custom wheel adapters to exactly what you want
Search xxr 521 there a member that posted xxr 521 18x10 setup that was pretty flush and looks good
I think a 18x10 setup would look far better for what you going for than a 9.5 to get the look you want you going to need a narrow tire like 235 or 245 the narrower the wheel the even more narrow the tire needs to be , hence why all the Stanced imports are running at least a 10" wide wheel unless your a civic , and it's going to look more like a low rider with 13" spokes than any thing else which is really distasteful on a larger car ,
That's my opinion
but it's up to you
My sig pic are 18x10 285/35
He is running same wheels but with 235/45 iirc
https://www.thirdgen.org/forums/whee...521-third.html
That's my opinion
but it's up to you
Car: 1986 Camaro IROC Z
Engine: 1995 LT1
hey man sorry to bring up an old thread but i just got the xxr 531 19x10 et15 for the iroc but the centerbore is definitely the wrong size. did you use spacers? if so, how thick? thanks man
Car: 91 Camaro RS
Engine: 5.0 tbi
Transmission: 5 speed
Axle/Gears: 3.08
When you do buy the spacers don't buy the ones with the hub centric ring on them they won't clear your hub , I'm not sure what the xxr 531s require for spacer depends on which offset you chose. I'm running the xxr 526 18x9 up front with +35 mm offset . I use a 1.5" adapter spacer for the front I bought on eBay .
Engine: 1995 LT1
Engine: 305 to 350
Axle/Gears: 10 Bolt
Marchosias
09-01-2011 10:10 PM
